#21 |
'99 GT 35th Anniversary
14.266 @ 103.41
Should the pedal have some play at the top when it is at rest? The engagement point is roughly half the length of pedal travel.
SMR #2043 |
#22 |
14.266 @ 103.41
I just tried to see if the clutch would adjust. The cable must be where it needs to be because when I pulled up on the pedal, it would pull up an inch or so but no clicks even after depressing the pedal.
SMR #2043 |
Threads Similar to: Trouble shifting into 1st from neutral
| DD shifting vs. redlining/racing shifting | ihavefat | The Clubhouse | 16 | January 10th, 2012 04:39 PM |
| Trouble shifting from 2nd to 3rd at high rpm's. | 04GTNAustin | 99-04 | 26 | June 4th, 2010 11:00 AM |
| neutral switch???? | Frankenstang | 5.0 Mustangs | 3 | September 8th, 2008 02:46 PM |
| trouble shifting.... | lwhitetrash88l | V6 Mustangs | 32 | March 24th, 2008 01:57 PM |
| Neutral Into Gear | 98Stang | V6 Mustangs | 14 | October 1st, 2006 10:00 PM |
