'99 GT 35th Anniversary
14.266 @ 103.41
Trouble shifting into 1st from neutral
This may not be an issue but has got me wondering about my clutch and transmission. When I am in stop and go traffic, I usually put the car in neutral when I'm at a standstill for a minute or two instead of keeping the clutch in. When I go to put it back in first from neutral, it is sometimes very difficult. However, when I go from second to first, it is completely normal and synchronized. I have the clutch pressed in all the way, so I don't have it partially engaging. I have noticed that there is some heat built up around my e-brake when in stop and go traffic. Could the additional heat from traffic cause the clutch to heat up and cause this? Maybe I need to adjust the clutch? I changed the fluid with Mercon V when I put the MGW on a month or so ago, but it was doing this before I changed all of that. If any of you have any ideas let me know. Thanks!
SMR #2043 |
I like boobs!!!
2000 GT convertible
dunno
That just happens sometimes when you idle it for a while. I use synchomesh and have no problems anymore.
Last time you voted to prove you aren't racist. This time prove you're not an IDIOT!!! ![]() My Garage--->http://www.moddedmustangs.com/forums...-member-46919/ |
14.266 @ 103.41
Well I guess it's normal then. lol I have noticed a slight 2-3 grind when shifting quickly when it's first warming up. Maybe I should go ahead and switch to synchromesh. Pennzoil right?
SMR #2043 |
I like boobs!!!
2000 GT convertible
dunno
Yeah, that's the stuff. Penzoil Synchromesh, 3.5 qts.
14.266 @ 103.41
Alright, so I guess instead of taking the shifter back off, I need to get a hand pump. You used any that you'd recommend?
SMR #2043 |
I like boobs!!!
2000 GT convertible
dunno
Take the shifter off. Its very easy and you will save yourself a lot of headache and mess.
14.266 @ 103.41
I suppose so. I just fought so damn hard for an hour to seat the rubber boot it had! lol
SMR #2043 |
2002 mustang gt
![]() iTrader: 1 reviews
3-3.2 quarts to be exact!
Rock stock
14.266 @ 103.41
I put in 3.2 of the Mercon V, guess the trans just doesn't care for it.
SMR #2043 |
Chitty Chitty Bang Bang
2001 Mustang GT
Doing some googling on this synchromesh- they say not to run it in t45 transmissions as the seals are organic material versus other transmissions that are kevlar based?
Also based on numerous threads including this one http://mustangforums.com/forum/oil-a...id-in-t45.html our T45 transmissions call for ATF not Mercon V. Isn't Mercon V an automatic transmission fluid? I could be wrong. Again, this is just simple googling here.
2001 Mustang GT 5-Speed ![]() God Created Man, but Sam Colt Made Them Equal |
I like boobs!!!
2000 GT convertible
dunno
TheOdessa, I have the Crimson Trace laser that's in your sig on my .380. That thing is sweet, the pistol is a piece of shit though.
Off topic, I know. Sorry.
2001 Mustang GT
LOL Which .380 do you have? I own an LCP.
The pistol is a PF9. Not a Keltec fan?
#13 | |
!FACEPLATED!
![]() MM Bracket Racing Crew Co-Founder ~Its a Drag Car, Not a Show Car~ LINK-->Custom Race Transmission Build<--LINK
#14 | |||
April 2012 ROTM
I like the LCP's with the CT sights though too...not a keltec fan at all...
True blue crew founder/member #1378/442 rwhp/rwtq*on a Mustang dyno* cams are in..#'s coming this summer |
2001 Mustang GT
F8L GT- Like I said, just simple googling. What's the difference between standard ATF and Mercon V? I remember when I had an automatic Ford Explorer, I had to run Mercon V in it, nothing else.
WishIhad- A lot of people do not like Keltecs. I can see why - they are cheaper, and tend to break after a lot of use. Just around 900 rounds the slide developed a crack. Shortly after the firing pin broke. Keltec send parts for both 100% free of charge. It's still my favorite gun though. Light, compact, and has a nice little kick to it. It just requires a bit more TLC then other guns. My LCP can be fired, dropped, and abused with no probs.
!FACEPLATED!
They have different ingredients in them but both are automatic transmission fluids. The older cars take ATF where newer ones take Merc V. Both of which can be ran in a manual
#17 | |
April 2012 ROTM
back on topic.... I had mercon v in my 3650 for a summer and hated it...it wanted to nibble 2-3 and it seemed to growl more. The synchromesh has made it buttery at any operating temp
#18 | |
12.73@111.36
"Ensure the correct automatic transmission fluid is used. Transmission fluid requirements are indicated on the dipstick or on the dipstick handle. MERCON and MERCON V are not interchangeable. DO NOT mix MERCON and MERCONt V."
ProCharger P-1SC, 9 psi, STD 396/383; Uncorrected 388/375; SAE 383/370 Mods list in Garage. |
14.266 @ 103.41
Well it was an all around ATF. Probably was a mistake. I had it around the house and was sure it would work after referring to my manual. Maybe I misunderstood it. It shifts like butter until the stop and go traffic begins and the heat goes up.
Just on a side note, what are the signs that a clutch needs adjustment? (for future reference) Is it mostly the engagement point?
SMR #2043 |
2003 gt
5.4 32v on the way
It kind of sounds like the clutch isnt completely disengaging. If you have the stock pedal stuff, try to pull up on the pedal to tighten the cable. The stock clutch pedal has some ratchet thing so you can remove any slack, not the best setup you can have but not too bad of a trick from ford.
2003 Mustang gt - usual mods - slowly working on 5.4 swap 2004 srt4 - Stock DD/winter beater Click here for your tuning needs Before asking a gearing related question click THIS link and enjoy all your saved time. |
Threads Similar to: Trouble shifting into 1st from neutral
| DD shifting vs. redlining/racing shifting | ihavefat | The Clubhouse | 16 | January 10th, 2012 04:39 PM |
| Trouble shifting from 2nd to 3rd at high rpm's. | 04GTNAustin | 99-04 | 26 | June 4th, 2010 11:00 AM |
| neutral switch???? | Frankenstang | 5.0 Mustangs | 3 | September 8th, 2008 02:46 PM |
| trouble shifting.... | lwhitetrash88l | V6 Mustangs | 32 | March 24th, 2008 01:57 PM |
| Neutral Into Gear | 98Stang | V6 Mustangs | 14 | October 1st, 2006 10:00 PM |
