STFT's high at idle, regular when vacuum to fuel pressure sensor disconnected
Hey guys i put a post about High short term fuel trims (~28%) on my 03 gt. This happened soon after replacing my upper plenum and cai. Well i did some digging and found out that after removing vaccum to the fuel rail pressure sensor they dropped to normal. I also did a resistance and voltage test on the sensor and everything was to spec exactly. After using a vaccum pump on the fuel pressure sensor I found out it was slowly loosing vaccum. What originally caused me to do the tests were a slightly choppy idle and bucking at W.O.T. Any help would be awesome.
![]() 1988 LX auto- Pypes violator cat-back, UPR X-Pipe, Shift Kit, 4.10 Gears, Pulleys, Suspension upgraded, CAI 1999 GT 5spd- CAI, Pypes violator cat-back |
Did you check to make sure you have no vacuum leaks?
yeah checked all of the lines and they are good. The only way the SFT's go to normal is when i disconnect the vaccum line going to the fuel pressure sensor and plug the line with my finger
2003 Mustang Fauxbra
N/T @ Fast
Since you changed the upper plenum it sounds as if you have a vacuum leak. Short term fuel trim is adjusted either positive or negative depending on the inputs from Bank 1 & 2 upstream O2 sensors (typically listed as 1x1 and 2x1). A vacuum leak at the base of the newly replaced plenum will show the O2s the engine is running lean and increase the short term fuel trim to balance the AFR.
![]() All the typical bolt-ons, well a lot are welded on. Bone stock I tell ya. First time at the track, what do I do now? 03 Silver Fauxbra; 06 Legend Lime GT, 89 Outwlaw 10.5W Coupe, 93 Teal Cobra, 93 Red GT, 93 Teal LX - All Sold |
Yeah i already know i have a vacuum leak. I already said i tracked the leak to the Fuel Pressure sensor on sensor. STFT's dropped to normal when i unplugged and plugged with finger at #1, so i traced the leak to #2, because out of the 3 vacuum wires only that one brings the STFT's down. When i used a vacuum pump at #2 the Vacuum doesn't hold it slowly drops. The pic isnt my car btw
![]() Uploaded with ImageShack.us
Threads Similar to: STFT's high at idle, regular when vacuum to fuel pressure sensor disconnected
| Help!! Low Fuel Pressure At Sensor | sxc2961 | V6 Mustangs | 1 | January 4th, 2012 04:39 PM |
| disconnected vacuum lines | MallyMall7 | 5.0 Mustangs | 3 | June 8th, 2011 09:07 PM |
| need help with my fuel pressure regulator vacuum line | brharris777 | 4V / SVT | 1 | February 14th, 2011 04:23 AM |
| Idle Vacuum and fuel pressure | NDblackstang | 2005 - 2010 | 17 | September 1st, 2008 01:04 PM |
| Fuel Pressure Regulator Vacuum Line | mscribellito | V6 Mustangs | 7 | December 20th, 2007 02:18 AM |
