NEW MOTOR WONT START !!!!!! HELP
Old February 10th, 2012, 03:18 PM   #1
bamasundown71's Avatar
12.37@105.63
bamasundown71 is on a distinguished road
I just got a used motor with 70k miles on it with 6 month warranty that came out of a grand marquis i swapped everything over i needed to which was exhaust manifolds intake with the bells and whistles i went and got fuel put in the car after installing it and the car turns over just fine... no problems with that i kept trying to crank and got nothing so i checked the frps and i cant press the botton down but i checked if i had fuel at the fpr and fuel drips out and i hear the fp prime... i kept researching and found maybe the crank position sensor... i went and checked it and it was unplugged.... so i plugged it back up and tried to start again and it still will not start... ive checked all my connections for the injector and the COP and still wont start i got the code that for high pressure at the regulator before i checked the crank sensor... i swapped them out and cleared the codes and put the stock tune back in it then checked the crank sensor and plugged it back in and still no luck the car has been down 2 years and i cant wait anymore... please somebody help me im still throwing the code p1000 but i believe it should still start with it...
04 GT 5-Speed, Underdrive Pullys, Mac CAI, Flowmaster 10's, 75mm intake and plenum, O/R X-Pipe, SCT Programmed, 18" bullit rims.
Old February 10th, 2012, 03:46 PM   #2
1999 Mustang GT
bsap0941 is on a distinguished road
have you checked the cam sensor ? Are you getting spark i would check that out
Old February 10th, 2012, 03:49 PM   #3
12.37@105.63
cam sensor is plugged in idk if it works or not though whats best way to check for spark?
Old February 10th, 2012, 04:04 PM   #4
MM's king of Neon's
WickedSnake00's Avatar
404 - car not found
17.81@87
WickedSnake00 has much to be proud ofWickedSnake00 has much to be proud ofWickedSnake00 has much to be proud ofWickedSnake00 has much to be proud ofWickedSnake00 has much to be proud ofWickedSnake00 has much to be proud ofWickedSnake00 has much to be proud ofWickedSnake00 has much to be proud of
P1000 will not cause a no-start condition. It simply means that all the readiness monitors have not gone through their checks.
Also I'm surprised it would crank without a crank position signal. Most motors will not crank without one.
Start with the basics. It won't crank. Why might it not crank? Check power to the starter, jump it if need be. Check your grounds.
Official Secondhand Snake Build Thread Here
Looks Like a Cobra, Sounds Like a Cobra, Tastes Like a Cobra, Not a Cobra.
For Sale: P71 Interceptor motor
Old February 10th, 2012, 04:29 PM   #5
Mustang46's Avatar
11.85 @ 125
Mustang46 has a spectacular aura aboutMustang46 has a spectacular aura about
Make sure that your engine harness is well connected and that others are too. Also check your grounds to the engine.
Old February 10th, 2012, 04:39 PM   #6
MMM JELLO!!!
esonu's Avatar
2003 mustang GT
esonu is on a distinguished road
i have no input on this but is ur car in the avatar? put a bigger pic up cuz that looks nice.
2003 Mustang GT Manual
18in staggered fr500s,Mach 1 lip, mach 1 grill
Old February 10th, 2012, 05:48 PM   #7
12.37@105.63
Yes my avatar is my car... UPDATE!!!!!
Old February 10th, 2012, 05:51 PM   #8
termi_GT's Avatar
12.41@114
termi_GT has a spectacular aura abouttermi_GT has a spectacular aura about
Have the sparks hooked up to the correct firing order?
MM FOBRA CLUB CO-FOUNDER
Old February 10th, 2012, 05:54 PM   #9
12.37@105.63
The car started and then idled real rough and the throttle cable is real loose with the gas peddle.... also somethings wrong and the clutch will not engage real well... i can drive it but it has no power whats so ever... i cant even get over 20mph even in 3rd.... im not sure what that issue is plus im leaking antifreeze pretty bad too... im not real sure where from but i got an idea i reused the old gaskets... so im guessing thats where its leaking from... also it through 5 codes... im checking on them now... p0117 p1000 p1117 p2195 p2197. any help on the tranny issue will be grand cause 1 im new with trannys never really fooled with them always had my friend do it but hes in bama and 2 i wanna drive my damn car! i did not change the throwout bearing because i was using the same clutch and pressure plate... maybe that is the issue??? any help would be grand i plan on having the car running by monday at the latest and on the road...
Old February 10th, 2012, 06:07 PM   #10
MM's king of Neon's
404 - car not found
17.81@87
P0117 Engine Coolant Temperature circuit Low Input
P1000 System readiness
P1117 Engine Coolant Temperature Sensor Intermittent.
P2195/2197 HOS stuck lean, both banks
Sounds like your coolant sensor is not connected properly, or effed up.
Also check to make sure the upstream oxygen sensors are hooked up, not damaged, you don't have vacuum leaks or an exhaust leak. Lean could also be caused by insufficient fuel pressure.
Old February 10th, 2012, 06:33 PM   #11
12.37@105.63
i broke the one that was on my mustang intake and used the one off the crown vic... maybe its screwed up too ill have to get me one my biggest concern though is the tranny... im gonna have to pull the intake back off anyways to either make my own gasket or buy new ones...
Old February 10th, 2012, 07:08 PM   #12
12.37@105.63
ok so new coolant sensor and intake gaskets are on there way and will be here tomorrow.... now the issue is the transmission.... really need help with this issue guys if you dont mind....
Threads Similar to: NEW MOTOR WONT START !!!!!! HELP
Motor wont start jesusm3 5.0 Mustangs 13 March 26th, 2011 12:47 AM
Theft Light Flashing After Pulling The Motor And Car Wont Start. Help tkrizzy3 99-04 3 June 21st, 2010 11:17 PM
new motor wont start sniperrider 5.0 Mustangs 12 March 8th, 2009 01:33 AM
motor wont start HELP!!! P.O.S-GT 5.0 Mustangs 7 February 10th, 2007 12:24 PM
