Strut Question
Old February 10th, 2012, 08:18 PM   #1
jonnyspeed is on a distinguished road
Strut Question
My mechanic told me my struts are bad, isnt a strut same as a shock or damper?
The guy before me put in eibachs so idk why its bad, how can he even tell when its on the lift?
What are good replacements for the front struts?
Old February 10th, 2012, 08:27 PM   #2
1_nice_03_gt's Avatar
2003 ford mustang gt
13.9 stock
1_nice_03_gt has a spectacular aura about1_nice_03_gt has a spectacular aura about
i got kyb's all around, fronts are struts rears are shocks. how many miles on your car and are they your stock struts?
k&n cai, mangaflows exhaust, summit udp's, 24lb injectors, 78mm bbk plenun, tri-ax s/s, a/c delete,3.73's, aluminum drive shaft, upr upper/lower control arms, solid motor mounts, bbk heades, upr xpipe,bbk cc plates, camber bolts.bama tune
Old February 10th, 2012, 09:27 PM   #3
70kmi and someone before me put eibachs all the way around
Old February 10th, 2012, 09:33 PM   #4
13.9 stock
eibach struts? does it look like it might be leaking on the strut
Old February 10th, 2012, 09:49 PM   #5
95mustangGT/SVT's Avatar
2001 Gt
95mustangGT/SVT will become famous soon enough
You can blow a shock or strut out at anytime. Just because you got a name brand product on your car doesn't mean it has any life left in it. I would guess that the last guy enjoyed those struts and now you need new ones. Even the cheapest new struts are better than worn out ones.
Old February 10th, 2012, 10:19 PM   #6
Nitmare67 is a jewel in the roughNitmare67 is a jewel in the roughNitmare67 is a jewel in the rough
I've heard nothing but good reviews from eibach pro dampers. They arent the most aggressive shock but they'll get the car lower, handle better and still ride well. If thats what you want buy new ones. If not then go with some tokicos or something. I had the pleasure of riding in 3 different cars with 3 different shock and spring packages. I liked the eibach package more than the rest by far... but I like a good ride more that eating corners for breakfast.
99 Mustang GT 446rwhp, Vortech Aftercooled, Killer Chiller @12lbs, HPX, 3.73s, MGW, Battery Relocation, Intercooler Tank Relocated, CF DF clutch, Steeda Quick Release Quadrant, 75mm TB, Ported C&L Plenum, Stock PI Cams Advance 4 degrees, Pro Chamber
Old February 11th, 2012, 04:02 PM   #7
he says that the front wheels are leaving the ground when i go over bumps and the struts arent holding the tires down
Old February 11th, 2012, 05:27 PM   #8
also i have eibach springs so wont i have to get a certain size strut? like smaller than stock since its lowered?
Old February 11th, 2012, 05:45 PM   #9
Aristeros is on a distinguished road
No, just order an eibach pro front strut(if you can find one) All I can find online is a kit for all 4 corners.
Old February 11th, 2012, 05:46 PM   #10
Here:
Eibach Pro-Damper Mustang Shock & Struts (94-04 V6, 79-04 V8 excl. IRS cobra) 3514.840 - Free Shipping!
Old February 11th, 2012, 06:29 PM   #11
Tokico HP Series Strut (94-04 Mustang) HB3140 - Free Shipping!
Will two of these work with my eibach springs?
Old February 11th, 2012, 06:43 PM   #12
12.35@114.08 w/ 1.88 60'
dcook_14 is a splendid one to beholddcook_14 is a splendid one to beholddcook_14 is a splendid one to beholddcook_14 is a splendid one to beholddcook_14 is a splendid one to beholddcook_14 is a splendid one to beholddcook_14 is a splendid one to beholddcook_14 is a splendid one to behold
iTrader: 7 reviews
I'm not a mechanic but I'm pretty sure it's your spring that holds your tire to the road when going over bumps. I guess if your strut was valved for a really stiff spring and you used it on a soft spring, that would cause the problem you described. If your shock was blown out, then your tire would stay planted to the road but it'd be bouncy
Do the Right Thing, Cook. ~Zip.
Old February 12th, 2012, 04:22 AM   #13
idk bump on my last question that no one seems to know reps.
Old February 12th, 2012, 10:56 AM   #14
jeep45238's Avatar
2003 Mustang GT
jeep45238 is on a distinguished road
Yes, the HP series will work fine.
Old February 13th, 2012, 01:32 AM   #15
yea i dont have any bounce just my mech said theyre bad n he didnt even take it for a ride so idk how he can tell?
Old February 13th, 2012, 03:59 AM   #16
jeep45238's Avatar
2003 Mustang GT
If you are questioning your mechanic, maybe it's time to seek a second opinion, and maybe a mechanic you trust.
Old February 23rd, 2012, 09:36 PM   #17
Abyssinian of AX
Jazzer The Cat's Avatar
'02 Saleen
19.34@42.259
Jazzer The Cat has a brilliant futureJazzer The Cat has a brilliant futureJazzer The Cat has a brilliant futureJazzer The Cat has a brilliant futureJazzer The Cat has a brilliant futureJazzer The Cat has a brilliant futureJazzer The Cat has a brilliant futureJazzer The Cat has a brilliant futureJazzer The Cat has a brilliant futureJazzer The Cat has a brilliant futureJazzer The Cat has a brilliant future
Originally Posted by 1_nice_03_gt View Post
"... fronts are struts rears are shocks.. "
I have shocks at all four corners
Un-Official Suspension Guide | Choosing a new tire | Brakes upgrade ~ Speeding up slowing down | T-3650 ~ T-56 swap | Tire and Wheel Fitment Guide | The Kitty makes front page news
Originally Posted by Novanutcase View Post
"... although Jazzer's view is a little skewed since he pushes his car HARD so his opinion as to what works is more rooted in extreme circumstances!
Threads Similar to: Strut Question
Strut Question 03stanggg V6 Mustangs 2 August 12th, 2011 07:29 PM
Drag strut question mr.mike 99-04 5 February 28th, 2011 09:46 PM
strut question free2.3 2.3 Mustangs 4 December 28th, 2010 07:55 PM
Strut question Gunny 2005 - 2010 9 July 20th, 2007 11:17 PM
'65 Strut Rod Question doc540 General Tech 1 April 5th, 2007 07:53 AM
