2000 GT Convertable
14.03@99.41
PCM compatibility
I have reason to believe my car needs a PCM. Is it true I can pick up a used one from any V8 5speed coupe or convertible? My car is a V8 5speed convertible. Thanks?
Triple Black GT "Jenny" : http://www.moddedmustangs.com/forums...-up-jenny.html Full exhaust, hurst shifter, JLT CAI, staggered nittos, brembo brakes, and some other little things |
2003 ford mustang gt
13.9 stock
ya but maybe your pats system will start to act up and will need to either take it to the dealers to reprogram or disable pats altogether
k&n cai, mangaflows exhaust, summit udp's, 24lb injectors, 78mm bbk plenun, tri-ax s/s, a/c delete,3.73's, aluminum drive shaft, upr upper/lower control arms, solid motor mounts, bbk heades, upr xpipe,bbk cc plates, camber bolts.bama tune
2000 GT Convertable
14.03@99.41
What is the pats system
12.9 @ 111.44
Passive Anti Theft System
![]() l Custom Hotside l TurboSmart l MHS l Hallman l On3 l BBK l Hellion l SCT l Flowmaster l Steeda l AEM l Tial l HPX l Hawk l Trickflow |
King Sisyphus
1999 Mustang GT
![]() iTrader: 2 reviews
+1 to all the above with one exception...its not a matter of it "might act up". It's going to act up. on a 2000 GT...you will not be able to just plug and play the new one. Unless you get a used one and get all the other stuff that can not be turned off when you disable PATS system. For example...if you get a used one you will also have to get the speedometer cluster and a few other things to make it a plug and play. If you get a new pcm, take the PCM to the ford dealer and have them reprogram it for your car. If you don't...the car will not start when you plug in the new one. SO you have to be mindful of where you are when you swap it out.
![]() "Mustang, Noun: Meaning; An indocile horse of the western plains, In English society, The American wife of an English nobleman" |
2000 GT Convertable
14.03@99.41
Ok, where is the PCM in the car? Passenger kick panel?
I like boobs!!!
2000 GT convertible
dunno
Passenger kick panel. It a lil tricky to get out, but not too bad. Each ECU has a 4 character box code. Ford has about 9000 different box codes, so good luck finding the same one. However, if you disable PATS there should be no issues
Last time you voted to prove you aren't racist. This time prove you're not an IDIOT!!! ![]() My Garage--->http://www.moddedmustangs.com/forums...-member-46919/ |
2000 GT Convertable
14.03@99.41
I'm going to try and find a cheap one online, have ford program it, than install it.
Threads Similar to: PCM compatibility
| Rim Compatibility | tshrake521 | 2005 - 2010 V6 | 5 | September 18th, 2010 12:52 PM |
| 8.8 compatibility | DegralDan | 99-04 | 11 | May 23rd, 2010 12:57 PM |
| compatibility | Imran | 99-04 | 32 | February 16th, 2010 07:28 PM |
| What is this value and compatibility? | INSTALLER020 | 5.0 Mustangs | 14 | September 13th, 2008 06:32 PM |
| S/C Compatibility... | G.T. Rags | 99-04 | 11 | December 15th, 2007 12:35 AM |
