diff between pi and non pi motor
Old June 12th, 2007, 12:38 AM   #1
BoostHard1210's Avatar
13.000
BoostHard1210 is on a distinguished road
Hi does anyone know the differnce between the non pi motor and the pi motor ? is the block the same.. someone is trying to seel me a motor out of a lincoln town car and it looks like the 4.6 non pi. i want to buy and rebuild.. will it bolt right up???....thanks
Abe
Old June 12th, 2007, 12:40 AM   #2
droppedbass87 is an unknown quantity at this point
Send a message via AIM to droppedbass87
well pi is better of course but yeah you take your stuff off your motor and put it on there..
Old June 12th, 2007, 12:43 AM   #3
13.000
So if i take my heads and ignition ,intake manifold and put it on that block it will still be the same???
Abe
Old June 12th, 2007, 12:48 AM   #4
yeah man..how much they giving you that other engine for??
Old June 12th, 2007, 12:50 AM   #5
13.000
150$$ and 55k miles i want to forge the bottom end and put it in my car for more boost.. cheap tho huh
Abe
Old June 12th, 2007, 01:09 AM   #6
yeah man do it..put your heads on it and everything else and forge that thing..and go ahead and see if you can port and polish those heads...and paint everything nice you know so it looks goooooood...
Old June 12th, 2007, 09:23 AM   #7
13.000
will do thanks ... i want to build a zo6 eater so will see....
Abe
Old June 12th, 2007, 10:47 AM   #8
The Hammer
G.T. Rags's Avatar
Millenium Falcon
G.T. Rags has a brilliant futureG.T. Rags has a brilliant futureG.T. Rags has a brilliant futureG.T. Rags has a brilliant futureG.T. Rags has a brilliant futureG.T. Rags has a brilliant futureG.T. Rags has a brilliant futureG.T. Rags has a brilliant futureG.T. Rags has a brilliant futureG.T. Rags has a brilliant futureG.T. Rags has a brilliant future
if it is npi keep in mind ur compression is gonna be 10:4:1 which is not good for running Forced INduction. You can remedy this by changing the pistons i believe. Anyone wanna back my up on this or correct me, theres a 5% chance im wrong about the pistons.
I would eat the peanuts out of her shit
Car Salesman Club - The Hammer
ModdedMustangs Conspiracy Group: President
Old June 12th, 2007, 11:04 AM   #9
2003 DSG Mustang Cobra
LeadFoot_GT is on a distinguished road
he can still have forced induction it's just that he wont be able to go past 10-12 psi if not lower unless he wants to risk detonation from the high compression pistons...if he wants to just stay at a conservative boost those pistons will do with low boost but anything higher then 12psi (correct if im wrong please) then it would be recommended to lower to either 8.0-9.0 compression ratio for high boost levels.
whatever floats your Boost, and since your gonna be forging you shouldnt worry about internal failure unless its tuned wrong so GL bro.
Old June 12th, 2007, 12:22 PM   #10
The Hammer
G.T. Rags's Avatar
Millenium Falcon
I apoligize for not being more clear in my post. I just waddled out of bed to drive my gf to work and came home. It takes me like, atleast 2 hours in the morning before i can begin to function properly. Don't get me wrong, if i roll outa bed at 12 im good to go, but anything sooner then that it's like my body is just in sleep mode.
Old June 12th, 2007, 12:31 PM   #11
Proud American
MustangMatt96GT's Avatar
Well since he has a PI motor right now and wants to put the PI crap on the NPI block he will have a 10.4:1 compression ratio, because of the decrease in combustion chamber in the PI heads along with the smaller dished pistons. To rememdy this he just needs to put in different larger dished pistons, or he could use SVO heads which have the same combustion chamber size, and then use a nice intake manifold using the stickey on the 96-98 page. Those SVO heads ported and polished are the best you can buy for these car IMO. You have a lot of options, but Jump on that motor it has a great price!
RIP Travis Billings
Special Thanks to:
Andrews Racing Transmissions
Baseline Suspensions
25.3 SFI Chassis Build
Never Lift Racecars
Old June 12th, 2007, 01:16 PM   #12
The Hammer
G.T. Rags's Avatar
Millenium Falcon
are SVO heads npi matt?
Old June 12th, 2007, 01:29 PM   #13
Proud American
SVO heads have the same combustion chamber size as NPI and they have NPI ports on them. But SVO heads are the best you can get and when they are ported and polished they really shine! Also you can get them port matched for a PI intake, but thats a lot of money when the silicon works just fine! I just whish I had the bills to get a set!
RIP Travis Billings
Special Thanks to:
Never Lift Racecars
Old June 12th, 2007, 02:46 PM   #14
Casper98GT's Avatar
I dont really think any of this is even relivant.
If you are going to a Npi block and you wanna go internals...then the pistons wont matter because you would change them anyways.
The blocks are the same, except the winsor and romeo. they are different. you have a winsor block with winsor heads and cams. you are going to a romeo block. This would be a wonderful time to go aftermarket heads and cams. If you want a z06 killer...then you better build it right.
there is just alot to consider when going from winsor to romeo. thats why i recommend people staying away from 99-01 1/2 motors when going PI swap. You may have to do some drilling and such. But you can get it to work for what you want it to.
91 LX, 5spd.
Ex:Toyota/Ford tech
Old June 12th, 2007, 05:52 PM   #15
+1..hes going forged anyways..and yeah some stage 2 heads and cams would be good wouldnt it...
Old June 12th, 2007, 07:07 PM   #16
MM's Mad Scientist
acmillr's Avatar
Slow Fella
acmillr is a splendid one to beholdacmillr is a splendid one to beholdacmillr is a splendid one to beholdacmillr is a splendid one to beholdacmillr is a splendid one to beholdacmillr is a splendid one to behold
I don't see where you are going to get a very good deal.
Let's draw this out..........
You're not going to use the heads and upper end of the donor engine.
You're not going to use the pistons.
You're not going to use the rods if you want a forged bottom end.
You're not going to use the crank because it is also cast.
You ARE going to use the block- which you will want to take to the machine shop to have checked and cleaned up. Let's say the shop charges you the typical minimum fee of about $200.
Now, what you have is $350 used block. Keep in mind that a new block will only run you about $360 with the standard bore.
I would pay the extra $10 and not deal with the hassle of tear down that, machine shop this, so on and so forth.
Old June 12th, 2007, 10:53 PM   #17
Proud American
Acmillr has a great point I never thought about it that way!
And I forgot about the windsor and romeo crap! Srry!
RIP Travis Billings
Special Thanks to:
Never Lift Racecars
Old June 13th, 2007, 12:35 AM   #18
13.000
So what if i were just to swap motors would a romero bolt right up to a windsor???? are the blocks the same??
Abe
Old June 13th, 2007, 12:41 AM   #19
13.000
What i was planning on doing is take that other motor and put good rods and pistons for about 15 PSI and a cam job... keep the crank and stuff or am i full of crap talk??
Abe
Old June 13th, 2007, 12:43 AM   #20
Proud American
If you and doing a stroker kit like you said, you have to get a new crank as well! And if you are in there you might as well put in a forged crank as well!
RIP Travis Billings
Special Thanks to:
Never Lift Racecars
Threads Similar to: diff between pi and non pi motor
help with rear diff blown96stang V6 Mustangs 4 June 29th, 2007 08:31 PM
How much diff will it get you? scxc15 V6 Mustangs 8 May 20th, 2007 02:38 AM
diff noise amber Modular Mustangs 4 February 27th, 2007 03:39 PM
7.5 Rear Diff bhsAuto All Other Vehicles 6 November 17th, 2006 10:13 PM
diff Wheels on my car Drgnracin72 Chopshop 2 August 11th, 2006 10:57 PM
