What are symptoms of a differential going bad? - Forums at Modded Mustangs
post #1 of 7 Old February 27th, 2012, 07:43 PM Thread Starter
HamToast's Avatar
I've been posting a bunch lately on troubleshooting noises my car makes because, well, it makes a lot of them. I've been having issues with this sorta scraping noise for a while and thought it might be the clutch or TOB or something like that, but this week I noticed a clunking/grinding sound from the center area of my car.
I couldn't really tell where exactly the clunks and grinds were coming from except that it was near the center of the car. It only made the noise for a few moments, and has continued to do so occasionally at low speeds (making it difficult to pinpoint since it is not constant). I spent a while looking on youtube for a good clip of the sound my car periodically makes and it sounds identical to a bad differential, only its not a constant sound when in gear. Could my rear diff be going bad? Or would that be a constant noise? Could it be an axle bearing? Bad U joint? I'm really at a loss here but I'm getting sick of hunting down these noises.
For reference, this is the main video I'm basing my sound analysis on:
HamToast is offline
post #2 of 7 Old February 27th, 2012, 09:16 PM Thread Starter
HamToast's Avatar
I haven't been able to hear the noise any time I'm listening for it lately. All I know is I'm beginning to really hate all these mystery noises.
Wish my apartment complex would let me drain fluids so I could open up the differential and have a look.
HamToast is offline
post #3 of 7 Old February 27th, 2012, 09:32 PM
NOR*CAL's FINEST
3valveStallion's Avatar
my best guesses: axle bearings, clutch packs in the diff, pinion gear and any number of rear end differential problems. unfortunately this noise is not uncommon for your generation of mustang, but I dont really no what it is for sure
3valveStallion is offline
post #4 of 7 Old February 27th, 2012, 11:07 PM
Procrastinator
if its kind of a popping noise and you have stock suspension it could be your bushings. if you suspect its your differential do a short burn out on clean pavement and look at your marks, if one is lighter than the other your clutch parks are worn.
DickH is offline
post #5 of 7 Old February 28th, 2012, 03:42 PM Thread Starter
HamToast's Avatar
I haven't heard the noise again since I've been trying to listen for it. I'm going to open up the differential and have a look inside, change the fluid and add some friction modifier. Beyond that all I think I can do is give it time and listen.
HamToast is offline
post #6 of 7 Old February 28th, 2012, 04:18 PM
.//Animosity
I have a really good suspicion mine is gone in mine to. I was coming home on the highway, and all of a sudden I heard a loud humming noise so I pulled over. I put it in park, and checked it out no fluids leaking or anything. Just a loud howling noise.
Soon as I got back on the highway I started going, and from 30-70 it hounded, and sounded like a bloodey brake lathe going on. I've drove it a few times back, and forth between places just to get it to a shop, and back to the garage. It has fluid in it. So I'm not to sure what exactly is going on with it.
Far as I know I'm pretty sure I warped the ring, and pinion or did something under load. So I'm having it rebuilt here sometime in march after I see if gears/tuners/ etc go on sale for March.
Wildhardt is offline
post #7 of 7 Old February 29th, 2012, 09:10 AM Thread Starter
HamToast's Avatar
That howling is a classic symptom. It'd be simple for me if mine were howling...
Have you added friction modifier to see if that helps? Lots of guys have good luck with that stuff.
HamToast is offline
Human Verification
