Piston rings bad? - Forums at Modded Mustangs
post #1 of 9 Old March 5th, 2012, 03:51 AM Thread Starter
Garhfer's Avatar
Send a message via AIM to Garhfer
Piston rings bad?
I rebuilt the engine with forged internals 0.20" overpistons and speed pro rings anyway I started the engine up and it ran good started right up but after letting it idle Like 10 minutes i noticed antifreeze coming out of the tail pipe did a compression test and all of the driver's side were so i took the heads off to replace the head gaskets and while taking the heads off i sprayed wd-40 into the cylinders to prevent rust well i noticed that only in one cylinder the wd-40 oil leaked passed the rings after like an hr and a half or so but all the rest would be the same, is it normal that the ring hasn't seated yet or should i take it apart since it's already apart? Also if i have to take it apart could i just redo the one piston with a hone or would all have to be done?
2004 GT Boosted by Vortech
Garhfer is offline
post #2 of 9 Old March 5th, 2012, 04:24 AM
how many miles since the rebuild? So only one piston is leaking WD40 past the rings?
Built 4V Motor with Sullivan Single Plane Intake
Custom 66MM BB TT kit
Borla XR-1 Dumped before rear
Moser built 9" Rear
35 spline WaveTrac Diff with 3.75s
35 spline Moser axles
14PT roll cage and minitubbed :rockon
CobraStang161 is offline
post #3 of 9 Old March 5th, 2012, 04:48 AM Thread Starter
Garhfer's Avatar
0 miles idled 10 minutes and took apart for a bad head gasket install yeah only one cylinder wd-40 leaks passed
Garhfer is offline
post #4 of 9 Old March 5th, 2012, 06:04 AM
i would just replace the HG, i wouldnt worry about the ring. Its main job is to scrape oil off the cylinder walls. Since WD-40 is a liquid it is bound to seep past a ring or two.
Moser built 9" Rear
post #5 of 9 Old March 5th, 2012, 08:49 AM
is Torgo
WickedSnake00's Avatar
Rings aren't great at stopping solvent. Solvents like WD-40 are meant to be VERY thin and penetrate just about any crevice.
However due to your question, did you stagger the gaps on all the rings by any chance?
WickedSnake00 is offline
post #6 of 9 Old March 5th, 2012, 10:15 AM Thread Starter
Garhfer's Avatar
Yeah the rings are staggered, I hope you guys are right only thing i question is because of this video on youtube
And i was like if gas is test and it has less viscosity then wd-40 has to be worse but if what that youtube video is saying is a bunch of horse shit then i'm happy lol
Garhfer is offline
post #7 of 9 Old March 5th, 2012, 11:03 AM
BakerFX4's Avatar
iTrader: 15 reviews
as long as you staggered them and they are filed to your application, shouldnt be any issues bruh!
4.75 MMR 900se
Livernois ported heads
HP 292s blower cams
Procharger D1sc at 20+ psi
IW 15% OD pulley
(and more bolt ons)
E85
Tune/numbers coming shortly!!
BakerFX4 is offline
post #8 of 9 Old March 5th, 2012, 11:09 AM
BakerFX4's Avatar
iTrader: 15 reviews
since the cylinder is angled, maybe you have the top ring gap on that piston at the bottom and fluid drained past, whereas the others gap may be at the top toward the intake so its sealed all the way where the fluid is sitting.
4.75 MMR 900se
HP 292s blower cams
IW 15% OD pulley
(and more bolt ons)
E85
BakerFX4 is offline
post #9 of 9 Old March 5th, 2012, 11:55 AM Thread Starter
Garhfer's Avatar
Ok thanks, i'll just put it back together then
Garhfer is offline
Human Verification
