Kenne bell vs. centrifugal vs. Turbo - Page 3
Old June 16th, 2007, 06:23 PM   #41
droppedbass87 is an unknown quantity at this point
Send a message via AIM to droppedbass87
well i would only hop everyone in here would want a twin turbo setup..really you can get to it with anything else..if you didnt have to change out your kmember and other things it wouldnt be exspensive at all...the spool up is bad azz..people frak out when they hear and see it...my vote is turbo only if you cn afford it or if you have good patience and buy it piece by piece
Old June 16th, 2007, 06:34 PM   #42
mm's nitrous mod
SWEET2KSTANG's Avatar
2000 mustang gt
11.79@115.83 (old set up)
iTrader: 8 reviews
i wouldnt ever run a turbo set up with less than 12+ psi. the 2v's just dont have the air flow. the efficiency of a turbo would be less than a s/c. but for anything above 12psi the tubo would be able to get efficient and usable power.
Old June 17th, 2007, 01:48 AM   #43
jivepepper's Avatar
jivepepper is a jewel in the roughjivepepper is a jewel in the roughjivepepper is a jewel in the roughjivepepper is a jewel in the rough
Originally Posted by limited
my vote goes for the KB,if all you want is your power at wot,high rpm,then turbo is the way to go followed by centri.I love my KB on the street because you have much more power at all pedal positions other than wot.giving it half throttle at 2000 rpm in 2nd or third,you see between 2 to 5 psi and puts a smile on your face thats hard to remove.boost is addicting and why only have it at wot and high rpm were you may draw a lot of unneeded attention? this is were I think The KB is the only way to go on the street,it makes every time you drive it an experience without always having to go wot/balls out when you want that put you back in the seat feel. and btw the Kb whine is awsum and very audible when in boost.
One mashed together statement..
2000 GT 665/540rwhp/rwtq
Best 1/4:
AT 431HP 12.29 @ 124
AT 515HP 11.24 @ 129
AT 638HP 11.01 @ 135
AT 665HP ??.?? @ ???
80*+day, 1400' track, 10.5" DD Cobra R's & 315/35/17DR'S
Trap speed = true measurement of HP.
Threads Similar to: Kenne bell vs. centrifugal vs. Turbo
twin turbo or Kenne Bell or vorteck what is better!! mustangdevil69 V6 Mustangs 58 January 7th, 2008 04:32 AM
HP Twin Turbo Kit or Kenne Bell Supercharger??? HELP! Chris02 99-04 10 January 6th, 2008 01:20 PM
Gettin a S/C in about a year. A kenne bell or a centrifugal? mustangmanic 99-04 30 August 21st, 2007 02:37 PM
Kenne Bell, Procharger or turbo 89fox5.0 5.0 Mustangs 12 February 15th, 2007 11:11 AM
Kenne Bell Supercharger or Hellion Turbo? Chris02 99-04 29 November 20th, 2006 02:37 AM
