Kenne bell vs. centrifugal vs. Turbo
Old June 15th, 2007, 11:57 AM   #1
hubba076's Avatar
hubba076 is on a distinguished road
Does anybody have any opinions on these. I have been pondering for a while what to do. Originally I wanted to get a procharger, then was intrigued by the Twin Turbos, now I'm thinking about a Kenne bell twin screw.
What I've considered:
Procharger, Vortech, etc.: Great horsepower, but can lag almost as much as a turbo at times. Seemingly limited boost (correct me if I'm wrong). Less expensive method.
Turbos: Again great performance, but as stated above are known for lagging (gotta stay on that throttle), especially at idle, but insane after they wind up. Very difficult and expensive installations.
Kenne bell: Great overall performers, variable boost ranges, expensive but installation is easier compared to other methods. Oh and immediate exponential power throughout powerband.
Don't get me wrong...all three are great performers, but based on some of the numbers I've seen I think the Kenne bell is the best option. I think I will go with the 2.6l model (for 1999-2004 gt's 9-26psi).
Anyone else want to comment or have opposing views Id really like to hear them.
2003 Mustang GT. Red HOT Bitch! Many mods to come...
Old June 15th, 2007, 01:22 PM   #2
sonicblue's Avatar
1990 GT
sonicblue is on a distinguished road
hope you have a built motor if you are gonna use the 2.6 what are your plans with the car? if its mostly a street car the kenne bell is cool cause its instant boost. i like the procharger or centrifigal style because the power comes on gradual which makes it easier to launch in my opinion. and it pulls like hell above 3k rpms. but if you just plan on messing around on the streets the kenne bell will prolly make you happier. turbo is going to make the most power but like you said its more expensive.
getting all fixed up for next season
2004 mustang gt 520rwhp, 491 trq sold
Old June 15th, 2007, 01:45 PM   #3
2000 GT
RyanGT is a jewel in the roughRyanGT is a jewel in the roughRyanGT is a jewel in the rough
i have the 2.1 9psi and its great! ill probably do the pulley swap for the 14 psi . Was at 400+ horses with 9 psi
Old June 15th, 2007, 01:46 PM   #4
hubba076's Avatar
I don't have a built (forged) motor yet...but plan to soon. I plan on using the car on the strip and on weekends.
What makes you say that Kenne bells are meant for messing around on the streets? The particular application that I inquired to (2.6l) has a 850+ hp potential if it is set up right: forged rotating assemblies, cams, heads, etc.
I've seen some vids, one of them was a Kenne bell GT taking on a turbocharged car and it definately wasn't messing around at all.
How has the procharger worked out for you as far as performance, etc. ???
Old June 15th, 2007, 01:55 PM   #5
hubba076's Avatar
Just out of curiousity how much did the 2.1 run you $$$. Intercooled or not?
Old June 15th, 2007, 01:57 PM   #6
sonicblue's Avatar
1990 GT
i just meant by messing around that if you just plan on a lot of street driving and wanted to play with other cars on the street its a fun blower cause of the instant power. if you just wanted to put a blower on it and be done and do nothing else to the car i like the kennebell. i just drive my car once and a while and at the track whenever i can and i love the procharger for that. it pulls hard all the way to redline. i love the procharger, the only thing i would say if you are going witha procharger get the d series.
Old June 15th, 2007, 01:58 PM   #7
hubba076's Avatar
You've got a nice setup going with that procharger. Whats the max boost potential you can get out of that procharger? I see you are a running 13 psi.
Old June 15th, 2007, 02:08 PM   #8
2000 GT
Was intercooled and Is about 5k for just the kit (without tax or shipping). I got the 90mm mass air and cold air intake though too. Which was about 600 more i think...
Old June 15th, 2007, 02:54 PM   #9
sonicblue's Avatar
1990 GT
its gonna depend on your engine set up how much boost you get. for the p series i am about maxed out on boost. when i upgrade to the d series with the same size pulley i will be running about 18-19 pounds.
Old June 15th, 2007, 03:08 PM   #10
DrHolliday is on a distinguished road
I've also got the 2.1L KB @ 9psi. It is intercooled.
I love thet thing, it made the car a absolute blast to drive. I'm also planning on uping the boost on mine to 14psi after a forge the block, and install some heads and cams. My goal is to be over 600 rwhp witch I think is very possible.
Are you planning on doing the work yourself or having a shop install it?
And like RyanGT said, the kit was 5k, the 90mm MAF and CAI was an extra 600, total with shipping to hawaii cost my 6k.
Mustangless atm
2006 2500 HD Diesel. Built allison trans and other goodies
Old June 15th, 2007, 03:17 PM   #11
Garhfer's Avatar
2004 Mustang GT Conv.
Garhfer is on a distinguished road
Send a message via AIM to Garhfer
you'd rather go kb than twin turbo'd are you crazy? Twin Turbos have a lot more potential
2004 GT Boosted by Vortech
Old June 15th, 2007, 03:50 PM   #12
mm's nitrous mod
SWEET2KSTANG's Avatar
2000 mustang gt
11.79@115.83 (old set up)
iTrader: 8 reviews
you can limit the lag with turbos with t4 headunits, ceramic coated headers and piping, and turbo wrap. centrifugals have very little lag, make good power on the higher rpm's, efficient, and are great for street strip applications. kenne bell is powerful on the bottom end, efficient, but has power drop off in the higher rpm's. if you go with a s/c and a lot of boost you will need to invest into bottom end, head work, and an 8 rib conversion. if a street monster is what you want with a lot of boost, go with a centr. if you want a s/c with a$$ loads of bottom end torque and grunt go with a twin screw. if over all power numbers is all you are after, turbos.
Old June 15th, 2007, 03:54 PM   #13
I know the roots style blower drop off in the high rpm's but I've never heard of a twin screw dropping off.
I have the dyno sheet to mine and it hit its peak HP right around 5900 and didn't drop off. The rev limiter is at 6200 and I was in the 360-370hp range from from 5500 up
Mustangless atm
Old June 15th, 2007, 04:01 PM   #14
mm's nitrous mod
2000 mustang gt
iTrader: 8 reviews
it also depends on the blower size and how much boost you run through it. if you have for example a 2.6 at 10psi. there shouldnt be any drop off just for the fact the blower is hardly turning. a 2.1 would give a faster 10lbs without dropping off, but power would start to level out at the top. this theory would be better looked at a terminator with an eaton and a terminator with a kenne. same rule, not trying to start a riot or opening a can of worms. the twin screws are the same way, but the drop off isnt anywhere near as bad.
Old June 15th, 2007, 04:06 PM   #15
I know what your saying. I've just read too many post where people think the roots style and twinscrew style are one in the same.
I'll have to see if mine drops off when I up it to 14 psi. But my build still won't take me past 6,200 rpms so I still might be too low to see a drop off.
Mustangless atm
Old June 15th, 2007, 04:10 PM   #16
mm's nitrous mod
2000 mustang gt
iTrader: 8 reviews
that sounds about right, the 2.1 will take power up quiet a ways but will peak somewhere as with all superchargers. my buddy went to school for forced induction and nitrous applications, and we been dealing with this kind of stuff for our builds that we do.
Old June 15th, 2007, 04:35 PM   #17
hubba076's Avatar
Glad to hear you like it. I'm looking forward to getting it done...with the 2.6l though I have a long way to go, with forged internals, tranny mods, etc.
I plan on doing the work with the help from an experience family mechanic. He's done numerous s/c and turbo systems throughout the years. He really knows his shit. I do to an extent, but experience is always gonna beat general knowledge. Plus, I can get all my stuff done for dirt cheap.
btw: Does anybody know why in the hell I have advertisements on my posts???
Old June 15th, 2007, 04:40 PM   #18
hubba076's Avatar
I have to do something more practical financially as well as something that will suit my needs (weekend driver/daily driver and some strip).
I know that some day I will have another car that I will have Twin turbo charger put in, but for now I going with a supercharger.
Old June 15th, 2007, 04:40 PM   #19
I don't see any advertisements?
How much boost are you planning to run?
And something to keep in mind, but you seem to be doing your homework. The 2.6L won't fit under the stock hood, good reason to get something better!
Mustangless atm
Old June 15th, 2007, 04:46 PM   #20
hubba076's Avatar
I plan on starting out with 9 or 10 and will slowly work my way up. I have to buy the pulley kit kenne bell offers.
Hood won't fit??? Thats an easy one that I have already looked into. All I have to do is get a Cobra R hood. Looks badass and is about 20-30lbs lighter than stock. (fiberglass or carbon fiber)
Threads Similar to: Kenne bell vs. centrifugal vs. Turbo
twin turbo or Kenne Bell or vorteck what is better!! mustangdevil69 V6 Mustangs 58 January 7th, 2008 04:32 AM
HP Twin Turbo Kit or Kenne Bell Supercharger??? HELP! Chris02 99-04 10 January 6th, 2008 01:20 PM
Gettin a S/C in about a year. A kenne bell or a centrifugal? mustangmanic 99-04 30 August 21st, 2007 02:37 PM
Kenne Bell, Procharger or turbo 89fox5.0 5.0 Mustangs 12 February 15th, 2007 11:11 AM
Kenne Bell Supercharger or Hellion Turbo? Chris02 99-04 29 November 20th, 2006 02:37 AM
