T-45 to Tr3650 question. - Forums at Modded Mustangs
post #1 of 11 Old March 21st, 2012, 08:03 PM Thread Starter
July '14 ROTM Winner
SunnyD's Avatar
Okay guys, I have a 2000 GT with the T-45 and a 2002 GT with the TR3650.
My shift fork from 3/4 went out in the '02 and so I am going in to replace that and put some new syncros in and stuffs like that.
The '02 is mostly stock while the '00 has full exhaust, and your run of the mill bolt-on.
Long story short, I want the TR-3650 that I'm building in my '00.
All I'm wanting to know is "Are they interchangeable"?
I know theres that one issue with the electronic/mechanical speedo gear, but I was told that they switched over to electronic in 99 so my '00 is electronic.
Any ideas? also, just as a driver preference thing, I've owned the '02 with the tr3650 for about 2 years, and have always loved my tr3650, NEVER had a problem with it.
I just recently got this '00 with the t-45 and it pops out of 4th intermittently which is really annoying, and I plan on making it my weekend warrior anyways, so I'd rather have the built tranny in it, plus I absolutely hate the way it shifts, so this is also a preference issue also.
So but anyways, I've rambled enough, the simplicity of my question is, can I swap the tranny's between the cars fairly easy?
If anything, what needs to be changed to make the swap work?
2015 Mustang GT - Performance Package, Muffler delete, Eibach Pro-kit springs, Driver Mod, Lund Racing Tuned!
SunnyD is offline
post #2 of 11 Old March 21st, 2012, 09:06 PM Thread Starter
SunnyD's Avatar
Bump.
SunnyD is offline
post #3 of 11 Old March 21st, 2012, 10:02 PM
ruger226's Avatar
Rebuilt TR3650 Transmissions in Atlanta Georgia
The 3650 will go in the 00 im not sure about the t-45 in the 02.... Scrool to the bottom of the link it will tell you.
P.S. good luck asking for tranny help on this forum.
Anyone know if you can swap a T-5 in a 03??
ruger226 is offline
post #4 of 11 Old March 22nd, 2012, 01:35 PM Thread Starter
SunnyD's Avatar
Thank you Ruger!
Also any idea if I will have to swap the clutches? anything else extra that I'm gunna have to do/replace/buy?
Any tips are definitely welcome.
SunnyD is offline
post #5 of 11 Old March 22nd, 2012, 09:55 PM
4 cam 4 life
NeverEnuff's Avatar
Yes you can swap a T5 in a newer car. Don't know how well the speedo will work, but they make adapter bellhousing for the T5 on a mod motor.
Or...what you could do is source out a early early Grand Marquis 4.6 block, the had the 5.0 bell housing pattern on the back. Meaning all transmissions and bellhousing that bolted to a 5.0, will bolt to that.
89 Coupe-Worlds Fastest NA Modular build in progress
http://www.moddedmustangs.com/forums...lar-build.html
01 Lightning-Ported Eaton, Comp 278s, Exhaust, daily
NeverEnuff is offline
post #6 of 11 Old March 22nd, 2012, 10:26 PM
!FACEPLATED!
F8L GT's Avatar
iTrader: 13 reviews
since you have both cars, you have everything you need right in front of you to do the swap.
Teksid short block, Ported 2v heads, Custom ground cams, Edelbrock Vic Jr intake, Brandon Alsept tuned
F8L GT is offline
post #7 of 11 Old March 23rd, 2012, 12:31 PM Thread Starter
SunnyD's Avatar
Well that's what I'm wondering f8l, what exactly needs to be swapped between the cars?
Both speedos run off electronics.. so no worries there, but when it comes to the drivetrain, will I have to swap clutches or anything like that?
SunnyD is offline
post #8 of 11 Old March 23rd, 2012, 12:58 PM
!FACEPLATED!
F8L GT's Avatar
iTrader: 13 reviews
No the clutches, pressure plates and flywheel can stay on the vehicles they are originally on
Sent from my HERO200 using AutoGuide.com App
F8L GT is offline
post #9 of 11 Old March 23rd, 2012, 01:39 PM
has five of broats
WickedSnake00's Avatar
Yup. I had a T3650 in my 00 GT. Even looked like the factory harness on it.
...in fact it's still sitting there taking up space. Hint hint anyone near Indiana.
WickedSnake00 is offline
post #10 of 11 Old March 23rd, 2012, 02:06 PM Thread Starter
SunnyD's Avatar
Alright Thanks a bunch guys!
Swap should happen either this weekend or next weekend, then I'll start building that T3650.. should be interesting!
SunnyD is offline
post #11 of 11 Old March 23rd, 2012, 02:18 PM
gt_andy's Avatar
Send a message via AIM to gt_andy
I did this swap in my 00. I got a t3650 from a 02 and put it in my 00. It was a straight swap. the only thing i had an issue with was the REV lights switch. I had to use the one from my t45 trans in my 3650. Everything else was a straight swap!
2000 Ford Mustang GT 5spd (TOY)
1999 Merc Grand Marquis = Daily Driver
gt_andy is offline
Human Verification
