unstoppable @ speed of light
n2o and n/a tune help.
Can a flip switch SCT tune get stuck on the wrong tune? I was running at the track last night, and the first run on nitrous felt incredibly weak, so I closed the bottle, and put the switch back to the n/a tune. The next run felt horrible. My MPH was way off, and the e.t. reflected that. It doesn't feel like it's pulling the way it should on the n/a tune. Kina feels like the nitrous tune, but without the nitrous. Maybe the timing didn't reset when I threw the swtich? Can that happen?
Political correctness is a doctrine fostered by a delusional, illogical, liberal minority, and rabidly promoted by an unscrupulous mainstream media, which holds forth the proposition that it is entirely possible to pick up a turd by the clean end. |
MM's nicest mod, :)
your switch could have went bad, but really the nitrous tune shouldn't be that much different, a couple of degrees of timing only pulls maybe 10or 15 hp max
06 Dodge MegaCab Diesel 455rwhp/815rwtq REAL TRUCKS DON'T USE SPARK PLUGS |
Yeah, I was thinking only a couple degrees of timming... Maybe I'm just being paranoid and over reacted. If I am right about it not running the same, what else could it be... Not a fuel filter or a mis fire cause it's got a smooth even pull through the rpm's. Like I said, it just feels like it lost power.
![]() Oh yeah, I never heard any detonation during either run, so I don't think it's the computer pulling any more timing...
MM's Mad Scientist
Slow Fella
![]() ![]() ![]() ![]() ![]() ![]() iTrader: 2 reviews
Did you get a check engine light? If so, pull your kick panel and make sure your chip is still pushed all the way into the housing. On second thought, you may not have gotten a check engine light depending on what mods you have. Mine came out a litte one time and tripped back into the factory settings- I thought my motor was F-ed up.
I'll check that in the morning.
You could have got some bad nitrous, i have a buddy down here in Ada and he got a bottle of bad juice.
03 GT 5sp, K&N FIPK, MAC LT ceramic coated headers, MAC Prochamber, Steeda Tri-ax, 3.73, SCT X-cal2 tuned by D&G Dyno Tune, NX plate Kit, Eibach Pro Springs, CMS Stage 2 cams. STRIKE design from MK Motorsports. |
MM's Mad Scientist
Slow Fella
Did you figure anything out?
Nope, I got drun last night and woke up late this morning and left for Daytona... I need to get out there and look at it. But I'm really tired right now! I'm thinking it was just in my head when I made the N/A run after the nitrous stopped working like it should. Just gotta figure out if the bottle maybe has a slow leak and it ran out and I didn't know it. Even if there is just a little bit if nitrous left the pressure gauge can still read 900psi on a hot day right?
MM's Mad Scientist
Slow Fella
Yeah, it can read the correct PSI even on a bottle that is almost empty. That is why it is important to have a gauge you can see in the cockpit. If the pressure drops quickly into a run, your bottle is getting low. If the bottle is almost out, the psi will drop noticably after a short purge.
Threads Similar to: n2o and n/a tune help.
| JLT Tune | 06GT300 | 2005 - 2010 | 8 | November 14th, 2007 01:24 PM |
| tune up for my 04 | tjames | V6 Mustangs | 3 | August 21st, 2007 02:28 PM |
| dyno tune & flash tune | miafan | 2005 - 2010 | 4 | May 31st, 2007 05:05 AM |
| To Tune or not to Tune? That is the Question! | kevnsue | 5.0 Mustangs | 24 | May 10th, 2007 08:22 PM |
| How much for a tune up! | dmachine22 | 99-04 | 17 | March 27th, 2007 08:36 PM |
