"CHECK FUEL CAP" dash light?
OK, I have this light lit on the dash of my '99 GT and canot figure how I got it nor how to delete it!
I was told by a Ford tech I must have added fuel with the car running. Not likely but could have added an additive with it running. I noticed it after I changed the coolant to a non-antifreeze type for summer use, could that have affected anything, seems unlikely? I have NO CEL's and the car runs fine except for this one problem. If there was a small leak in the EVAP system I would get a CEL! Could the charcoal canister be plugged? I have added octane boosters a fedw times but not around the time the light came on so any suggestions? Thanks, mark
'99 Convertible. 4.10's, PYPES catted X-pipe and catback. UDP's. 75mmBBK TB/plenum. JLT CAI. UDP's, Brenspeed custom tuned SCT. SVO intake & SHM cams this winter! Lord willing. |
IBEATU
06 GT, 98 GT, & 93 Notch
Could just be that you tightened the fuel cap on a little cooked and wasnt a tight seal. Check the cap, make sure its on straight and tight then clear the code with a handheld or have a parts store do it for you. If it comes back on then you have a prob but my guess is that it won't
![]() 98 GT: some stuff 06 GT: more stuff 93 Notch: 4 cyl at birth, now 5.0 drivetrain and stock exterior and interior= True Sleeper Paxton/Vortech Crew Member #3 FRPP's #1 Dealer Injected Engineering BMR Suspension |
1999 Mustang GT
mine did the same thing and it was the rubber seal that is used to seal the fuel tank to the fuel inlet hose/pipe what ever you want to call it that you put the gas nozzle in when you fill up. just buy a new seal and replace it takes about 30 minutes and is a bitch to pop in.
Mamma I wanna go FAST!
mine did the samething when i first got it i turned the light off 2 times then i just bought a new gas cap and i bought a vented one not thinking.. so then the cel came on with a large evac leak went back bought a non vented gas cap problem solved.. so i would get the light turned off and then if it come's back try a new gas cap..
yeah that most newer cars have that nowadays, its either ou dont have it tight enough or you need a new one cause the seal is bad.
Mine did it for the first three weeks that I had it and then it stopped. All that I did was pull the neg cable off to let the comp reset and it cleared it.
#7 | |
That is the quickest way to clear the code or you can leave it and the next time the car runs through it's cycle it will clear.
Threads Similar to: "CHECK FUEL CAP" dash light?
| Any 2005+ 'Vert owners with a "light bar"? | TCSoff | 2005 - 2010 | 4 | July 11th, 2007 10:28 AM |
| Another Gas Mileage Topic... ["fuel used"] | goodeye | 2005 - 2010 | 9 | June 27th, 2007 06:36 PM |
| "CHECK ENGINE" [on] after installing JLT RAI | jEEd | Modular Mustangs | 8 | January 7th, 2007 06:03 AM |
