What is the widest tire I can put on stock rims - Forums at Modded Mustangs
post #1 of 14 Old March 28th, 2012, 06:06 PM Thread Starter
Send a message via AIM to bigballers351
What is the widest tire i can put on a stock 2000gt rim? I believe it is 17x8. I don't want to stretch it to the limit and be unsafe for every day driving. But something that would look better than the stock 245/45/17
bigballers351 is offline
post #2 of 14 Old March 28th, 2012, 06:13 PM
Priest of the Car Gods
ReverendDexter's Avatar
You want more than a 245, you really need wider wheels. You can run a 255, and hell a 275 will mount up on a 8" wheel, but it's just really not proper fitment and not something I'd recommend.
Function > Form, always
ReverendDexter is offline
post #3 of 14 Old March 28th, 2012, 06:18 PM
Get urself some wider wheels
Sent from my PH44100 using AutoGuide.com App
2vStangGt is offline
post #4 of 14 Old March 28th, 2012, 06:24 PM Thread Starter
What would be good if i upgraded to a 9 inch rim? 275?
post #5 of 14 Old March 28th, 2012, 06:51 PM
275s are the stock size with a 9" wheel, so yes I run 255s on my 9s, but my wants out of a tire are a bit different that the average bear around here.
post #6 of 14 Old March 28th, 2012, 07:02 PM
275/40/17 and never turn back
6ER THEN I 8ER! is offline
post #7 of 14 Old March 28th, 2012, 07:04 PM
MM's V6 Hater
iTrader: 31 reviews
I've had 285/35/18 on 18x9 wheel. Now I have 255's
2010 GT500
2013 GT
2012 Dodge Ram 3500
Cabikejumper is offline
post #8 of 14 Old March 28th, 2012, 07:11 PM Thread Starter
Why would you run a tire that is narrower than stock? just wondering
post #9 of 14 Old March 28th, 2012, 08:22 PM
255s are actually straight up and down on the rim. Stock tire size is too big IMO, generally 120% of the wheel width. Narrower tire has less slop in the sidewalls and reduces unsprung/rotating mass. It also allows running higher pressure in the tires (wider tire on the same size wheel requires lower air pressure to maintain maximum traction patch) which again helps up the effective spring rate from the tire.
tl;dr - better for handling
post #10 of 14 Old March 29th, 2012, 12:31 PM
a.k.a. Racecougar
Tang Stang's Avatar
BTW, this question has been asked and answered many times here.
Rod @ AzzKicker Cars
2004 Ford Mustang GT-The Driver-BBK CAI, PP TB & Inlet, Steeda UD's, SLP LM1, & 3.73's.
1990 Mercury Cougar XR7-The Meth Addict-5.0L DOHC Stroker w/2.1L KB SC.
1995 Ford F150-Mud Toy-5.0L, 4x4, 33's, & Warn 8274 Winch
Tang Stang is offline
post #11 of 14 Old March 29th, 2012, 12:43 PM
US Air Force (retired)
Eagle2000GT's Avatar
+1 That pretty much sums it up. Drag racers will usually run a wider tire though because they don't care so much about slop in the sidewalls.
ProCharger P-1SC, 9 psi, STD 396/383; Uncorrected 388/375; SAE 383/370.
USAF 1969-1996: Vietnam veteran. Aircraft maintenance. ICBM Operations. Research & Development.
Eagle2000GT is offline
post #12 of 14 Old March 29th, 2012, 01:12 PM
Abyssinian of AX
Jazzer The Cat's Avatar
God how many times does this come up where bad information is often given and the proper information is just as often ignored
Un-Official Suspension Guide | Choosing a new tire | Brakes upgrade ~ Speeding up slowing down | T-3650 ~ T-56 swap | Tire and Wheel Fitment Guide | The Kitty makes front page news
It would still be fun to have a truck that poops speed bumps in fast succession.
Jazzer The Cat is offline
post #13 of 14 Old March 29th, 2012, 01:15 PM
Abyssinian of AX
Who you callin' average, pal?
post #14 of 14 Old March 29th, 2012, 01:34 PM
Broke as F*ck!!
townaj's Avatar
I'm running 275s all around, but I bought them keeping in mind that I'll be getting 10.5" rear wheels eventually. They also said it was a pain in the ass to mount them because of the extra width of the tire and super stiff sidewalls. Its not recommended to go that big on stock, as stated by those above. I would listen to them, they know their shit.
Black 2003 Cobra
Turbos in progress.
Twin Turbo Cobra Build
townaj is offline
Human Verification
LinkBack to this Thread: http://www.moddedmustangs.com/forums/99-04/256099-what-widest-tire-i-can-put-stock-rims.html
Thread Widest tire size for CS rims? | Mustang Forums for All lFord Mustangs | BoardReader This thread Refback May 5th, 2012 07:51 PM
