32V 5.4 Licolin Navigator engine
Old June 17th, 2007, 09:14 PM   #1
mrnewall is on a distinguished road
So some of you may know i blew my engine wile on nitrous very annoying and expensive. But iv found a Lincoln Navigator engine and have been told i can swap it in relatively easily into my car. This is a truck engine though so how would it be compared to our 4.6 for preformance? I had a full exhaust with a OR x pipe Magnaflow mufflers and a big cold air intake. I know this engine has lots of torque but i want my car to accelerate and go! Would the mechanic be able to mabie change the engines dynamics so its more of a car engine versus truck wile putting it in? Mabie less torwue more hp? Do you think 350 hp from this would be even possible
thanks very much hope you can help as im wanting to go buy an engine from he scrap yard asap!!
Old June 17th, 2007, 10:23 PM   #2
mm's nitrous mod
SWEET2KSTANG's Avatar
2000 mustang gt
11.79@115.83 (old set up)
iTrader: 8 reviews
its the same basic principal as the cobra r. they are strong stock to be putting in a mustang. a set of cams with a tune will get the power and torque where you want it. cams are a key to where and how power is put down.
Old June 17th, 2007, 10:33 PM   #3
02StangGToWNEr's Avatar
2006 Mustang GT
02StangGToWNEr is on a distinguished road
Re: 32V 5.4 Licolin Navigator engine
Torque is for acceleration, torque is what moves your car forward faster, Horse Power is for Top Speed. So even though you want more HP, you definatly dont wanna get rid of any TQ either. So just do what Sweet said!
Old June 17th, 2007, 10:42 PM   #4
MM's Mad Scientist
acmillr's Avatar
Slow Fella
acmillr is a splendid one to beholdacmillr is a splendid one to beholdacmillr is a splendid one to beholdacmillr is a splendid one to beholdacmillr is a splendid one to beholdacmillr is a splendid one to behold
Maybe you worded that wrong or maybe you just don't understand the principles behind HP/TQ. Either way, that was some pretty good misinformation.
TQ is power. (period) HP is only a calculation of how fast TQ can be made. Basically, you make alot of TQ and be able to achieve max TQ in as small a window of time as possible.
On the subject, the Lincoln Navigator engine should serve you well, because it is not an engine built strictly for pulling. It is made with daily driving in mind, and you wil probably be surprised at the amount of TQ you will be able to rapidly put to the back tires.
Old June 17th, 2007, 11:52 PM   #5
1999 Mustang GT
red99geetee is on a distinguished road
so while we are on the subject... how easy and how much would this cost for the swap and materials?
i'll have some pics here soon..
Old June 18th, 2007, 12:31 AM   #6
Proud American
MustangMatt96GT's Avatar
The intake manifold on the 5.4 truck engines is what changes the dynamics of the motor from what I have heard, so It may be the same with the Navigator engine. Also I think stepping up to the 4V will be great for you, but I personally like the challenge of the 2V and getting large numbers out of it! The 4V will flow much more air than the 2V and therefore can make more power! I also think that if you were to put some C casting heads on there with a matching intake you would have a wicked motor! ( I dont know if the heads would work because C casting cobra heads are for the 4.6, but it should work on a 5.4) Any way it will be a good motor for you and it would be relatively easy!
RIP Travis Billings
Special Thanks to:
Andrews Racing Transmissions
Baseline Suspensions
Never Lift Racecars
Old June 18th, 2007, 02:01 AM   #7
thanks for your help boys ill let u know how i get on
Threads Similar to: 32V 5.4 Licolin Navigator engine
Engine Build Up or Engine Replacement... OcOnnor220 99-04 8 July 27th, 2008 04:54 PM
1990 GT NO Engine Will 96 4.6 licolin town car engine FIT?? zygo4406 5.0 Mustangs 10 June 4th, 2007 06:53 AM
Swapping '99 v6 engine with '02 v6 engine elmills V6 Mustangs 63 May 25th, 2007 03:13 PM
Will a 2002 Gt Engine Directly Replace a 2000GT engine? Bigb2000GT 99-04 7 April 22nd, 2007 06:09 PM
Navigator Engine. blitzed589 Modular Mustangs 7 December 28th, 2006 01:52 AM
