2002 Mustang GT won't start!
Home Register FAQ Members List Calendar Timeslips Blogs Garage Gallery Auto Loans Search Today's Posts Mark Forums Read Auto Escrow
Go Back   Forums at Modded Mustangs > Mustang Forums > Modular Mustangs > 99 - 04
Old April 3rd, 2012, 10:47 PM   #1
alfredobu4 is on a distinguished road
First post ever made so help me out.
Well, my 02 mustang gt won't start. After a new fuel pump, fuel filter, fuel pump module, spark plugs, fuel pressure sensor, fuel pressure regulator, new fuses & relays, & even a PCM, it still wouldn't start. The reason for most of this is because of the signs the car was giving us. Any ideas of what the problem is?? The old & new PCM make a humming/buzzing noise. As soon as that stops, a few clicks comes from a little box below the cold air intake. I'm not sure what it is. Looks like it leads to the brakes?? Also, I was opening the ignition switch off & on for about 5 times or so, & all of a sudden my doors locked then unlocked. Is that normal??
Please help!
2002 Mustang GT (Black)
1996 GT Shortblock (4.6L V8 SOHC) w/ PI Heads
5 Speed
91,000 Miles On Body & Counting.
Motor Rebuilt at 84,000 Miles
270 Comp Cam
Throttle Body & Plenum
Steeda Underdrive Pullies
K&N Cold Air Intake
AJE Tubular K Member
Stage 2 Clutch
Pro 5.0 Short Throw Shifter
Aluminum Flywheel
Catless H Pipe
Magnaflow Polished Exhaust
Mac Longtube Headers
Eibach Springs & Shocks
Lowered 1 1/4 Inch
Cobra Bumper & Sideskirts
Smoked Head Lights w/ HIDs & Orange/Amber Accent LED Strips
Smoke Tail Lights & Third Brake Light
Blue Accent LED Strips (In Hood Scoop & Side Scoops)
Blue Interior Light
Chrome, Silver, & Black Interior
Deep Dish Bullit Rims 10.5 ( rear) w/ Nitto NT05 (315/30/17)
Sony Double Din
Pioneer Speakers
2 12" JL Audio Subwoofers
500 Watt Alpine Amp
  Reply With Quote Quick reply to this message
Old April 3rd, 2012, 10:54 PM   #2
Harvester of Sorrow
WickedSnake00's Avatar
404-car not found
WickedSnake00 has a reputation beyond reputeWickedSnake00 has a reputation beyond reputeWickedSnake00 has a reputation beyond reputeWickedSnake00 has a reputation beyond reputeWickedSnake00 has a reputation beyond reputeWickedSnake00 has a reputation beyond reputeWickedSnake00 has a reputation beyond reputeWickedSnake00 has a reputation beyond reputeWickedSnake00 has a reputation beyond reputeWickedSnake00 has a reputation beyond reputeWickedSnake00 has a reputation beyond repute
I think someone else just posted up a similar problem.
I ran into the same thing after my swap.
Do you get the theft light blinking, or dashes for the odometer at all?
Is the buzzing/clicking coming from under the passenger fender, near the wheelwell? It could be the CCRM. The CCRM controls the power relays to the starter and PCM. If it doesn't get a good ground, you get neither. Check to make sure pin 15 of the CCRM gets ground, and make sure all other grounds are snug and present.
Here's the thread with my issue-
No Start Condition, Weird Symptoms
See if that sounds anything like yours.
Old April 3rd, 2012, 11:21 PM   #3
Checked that thread out. Same problem as me for the most part. I put in a new CCRM. It didn't fix anything. It still buzzes/hums, then something clicks.
Normally, my theft like blinked all the time. Not rapidly though. So I don't know about that. Dashes only come on if I take the CCRM off. & I'm new at this, but how do I check the grounds? Test light?
Old April 3rd, 2012, 11:23 PM   #4
cschoening09's Avatar
2007 Mustang GT
8.90@88mph 1/8th
cschoening09 has a spectacular aura aboutcschoening09 has a spectacular aura about
iTrader: 10 reviews
mine did this. i ended up jackin up my underhood fuse box and accidentally pulling some wires out when i did my engine swap.. it would crank and crank and crank and never start. checked everything up till that...
anyways , to keep it simple....are you getting fuel?...spark? the basics to life in a cylinder?
2014 A6 GT Sterling Gray.
Old April 3rd, 2012, 11:24 PM   #5
SSG Pate's Avatar
00 Mustang GT Vert/88 5.0
SSG Pate has a reputation beyond reputeSSG Pate has a reputation beyond reputeSSG Pate has a reputation beyond reputeSSG Pate has a reputation beyond reputeSSG Pate has a reputation beyond reputeSSG Pate has a reputation beyond reputeSSG Pate has a reputation beyond reputeSSG Pate has a reputation beyond reputeSSG Pate has a reputation beyond reputeSSG Pate has a reputation beyond reputeSSG Pate has a reputation beyond repute
iTrader: 9 reviews
Camshaft position sensor there are two of them have you checked them?
Convertible Crew Founder
Proud Iraq and Afghanistan War veteran
Vortech T Trim @18 PSI
604 RWHP 516 FT LB
11.50@121.77@ 523RWHP
Precision Turbo 7675 CEA @ 00 PSI
000 RWHP 000 FT LB
0.00 @ 000.00 MPH
Old April 3rd, 2012, 11:26 PM   #6
SSG Pate's Avatar
iTrader: 9 reviews
Did you check your FPDM fuse in the engine bay? I know you said you changed your fuses but that one 20 AMP will cause a no start issue as well.
604 RWHP 516 FT LB
000 RWHP 000 FT LB
0.00 @ 000.00 MPH
Old April 4th, 2012, 12:09 AM   #7
Fuel: Check!
Spark: Check!
Fuses are fine.
Camshaft sensors? Haven't tried. Should I replace or?..
Old April 4th, 2012, 12:18 AM   #8
SSG Pate's Avatar
iTrader: 9 reviews
AHHH we may be onto something then you could always buy then take em back if they dont work. If you have replaced everything else I do not see it being anything other then these sensors, Or one of them anyhow.
604 RWHP 516 FT LB
000 RWHP 000 FT LB
0.00 @ 000.00 MPH
Old April 4th, 2012, 12:21 AM   #9
Where exactly are these located?
Old April 4th, 2012, 12:25 AM   #10
SSG Pate's Avatar
iTrader: 9 reviews
on the drivers side look directly below the valve cover behind the brake reservoir, on the passenger side the sonsor looks identical.
604 RWHP 516 FT LB
000 RWHP 000 FT LB
0.00 @ 000.00 MPH
Old April 4th, 2012, 12:25 AM   #11
2007 Mustang GT
8.90@88mph 1/8th
iTrader: 10 reviews
i always thought there was only one cam position sensor? one on the driver side bank ..then theres a crank sensor....where's the other cam sensor?
Old April 4th, 2012, 12:27 AM   #12
2007 Mustang GT
8.90@88mph 1/8th
iTrader: 10 reviews
im almost 100% sure theres only one cam position sensor on my romeo motor. its on the driver side behind ps resivour as you described. but nothing on pass side. i guarrantee it. just had the front cover off over christmas.
Old April 4th, 2012, 12:28 AM   #13
SSG Pate's Avatar
iTrader: 9 reviews
Yes there is a crank shaft sensor too, I cant remember on the passenger side if there was a Cam sensor there or not now that you bring this up. i have a vortech sitting there so i cant see nothing behind it. but when i built my engine seems like I put one on each side aomeone help me out on this passenger side sensor. has your engine ran since the swap?
604 RWHP 516 FT LB
000 RWHP 000 FT LB
0.00 @ 000.00 MPH
Old April 4th, 2012, 12:30 AM   #14
SSG Pate's Avatar
iTrader: 9 reviews
I have a windsor, but I do beleive your right there only being one cam sensor. check out that driver sensor tomorrow, and report back to us to let us know if that cured the cold.
604 RWHP 516 FT LB
000 RWHP 000 FT LB
0.00 @ 000.00 MPH
Old April 4th, 2012, 09:32 AM   #15
Harvester of Sorrow
404-car not found
I would still want to resolve that buzzing sound in the CCRM since you already know that something with that needs to be fixed.
You can check the ground with a digital volt meter (DVM), and check either continuity or resistance from the wire to a ground point on the chassis.
FWIW, I didn't change my CCRM, it was just a bad ground to it.
And +1 to there only being one cam sensor, at least on both of my Romeo's.
Old April 4th, 2012, 07:10 PM   #16
Alright, today the car started. After messing with a few things, of course. but now it won't!
I messed with these here. I don't know exactly what they are. (green arrow)
It's connected by a gray plug. (blue arrows)
I disconnected them, then connected them again. It started.
Old April 4th, 2012, 07:33 PM   #17
When it idles, it black smokes????
What could be the problem now?
Human Verification
Threads Similar to: 2002 Mustang GT won't start!
2002 mustang gt rough cold start!!! bigchapp 99 - 04 3 March 29th, 2011 11:30 AM
2002 mustang gt rough cold start!!! bigchapp 5.0 Mustangs 1 March 27th, 2011 04:16 AM
2002 GT Clicks once, then doesnt start? Miller220 99 - 04 15 August 16th, 2010 11:04 PM
2002 gt no start foxcruzin91lx 99 - 04 3 July 19th, 2010 08:42 PM
2002 Mustang Won't Start gremvic General Tech 3 February 24th, 2010 07:01 AM
Forum is powered by vBulletin ©2000 - 2015, Jelsoft Ent. Ltd. & SEO by vBSEO 3.3.2 ©2009, Crawlability, Inc.
