Voodoo or Comp?
Old June 18th, 2007, 04:38 PM   #1
Hasselm8's Avatar
'99 Mustang Gt
IDK
Hasselm8 is on a distinguished road
Voodoo or Comp?
Im pretty new here, and just wondering if anyone knows who is better in this field of hp. My next upgrade will be awhile, but I wanna have as much of an informed decision as possible...1. Can voodoo cams be purchased for my 99 Gt? 2. What if anything, is the better choice? 3. Can anyone tell me what would be involved when you switch cams, do you need to change heads...etc.? If anyone has any better options for cams, let me know.....
Thanx in advance...
"A wise man can learn more from a foolish question than a fool can learn from a wise answer. "
Old June 18th, 2007, 07:46 PM   #2
mm's nitrous mod
SWEET2KSTANG's Avatar
2000 mustang gt
11.79@115.83 (old set up)
iTrader: 8 reviews
i am 99% sure that lunati doesnt mak a cam for the 4.6. comp and vt are the ones everyone seems to go with. as for which one, it depends on application.
Old June 20th, 2007, 12:32 PM   #3
02steedagt is on a distinguished road
Send a message via AIM to 02steedagt
comp cams are the best IMO. install is apparently not a big deal on these mopors, all you have to do is take the valve covers off (and I think the taking the front cover off helps to line the cam up properly). You do not need to change your heads/springs etc if you go with a very mild cam, like the comp 262 or 270. The 270 or higher, however, will require a dyno tune. The 262's will not. That's what I'm going with.
"America is all about speed. Hot, nasty, bad ass speed."
Eleanor Roosevelt, 1936
Old June 20th, 2007, 12:53 PM   #4
matrixpuba is on a distinguished road
Send a message via AIM to matrixpuba Send a message via MSN to matrixpuba Send a message via Yahoo to matrixpuba
comp, vt, crowler are all reputable. im running cops in mine but had vt cams
Old June 20th, 2007, 11:57 PM   #5
Hasselm8's Avatar
'99 Mustang Gt
IDK
Thanks for the input...I will definately check into Comp for an upgrade...Thanks again!
Threads Similar to: Voodoo or Comp?
242/246 comp cam vs the 234/238 ? greenstallion 99-04 1 April 20th, 2010 12:09 PM
i need some comp. help weems The Clubhouse 16 October 17th, 2007 10:45 AM
Comp Cam 92mustanglx 5.0 Mustangs 2 August 21st, 2007 08:18 PM
Voodoo Dick 06RedfireGT The Clubhouse 13 August 16th, 2007 10:37 PM
Comp Cam ih8chevy 5.0 Mustangs 3 February 25th, 2007 12:16 AM
