13.364@105
Built NA 2v not making power
*****UPDATE ON PAGE 4******
Just finished up this build and was a little dissapointed with the results. I know dyno #'s dont tell you everything, but I was hoping they'd be alot higher. built shorblock 11.1:1 compression stage 2 patriot heads Bullet cams (227, 228 @.050) lift 24 lb injectors, focus pump etc. ford racing intake 75mm tb/plenum JLT Cai o/r midpipe tr 3650 made 286rwhp and about 305 trq. ![]() Suppose I were to add LT's, bigger cams (stage 2?) and maybe udps and possibly a trickflow or edlebrock intake... DO you think not having these things is really holding it back? I was on a budget and tried to save some money, but now I'm wishing I had gotten LT's at least. And with the cams, we were trying to watch the clearance...
|Forged Motor||11.1:1 CR||Stage 2 Heads||Custom Bullet Cams||MAC o/r H and CB||75mm TB/Plenum||JLT Cai| 290rwhp 307 rwtq |WTB Longtubes| Last edited by Mike113; July 8th, 2012 at 01:15 PM. |
2003 Mustang GT
11.98 @ 118.68mph
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: 23 reviews
Auto or stick? Regardless those are low numbers.
![]() 2013 Mustang GT/CS - Stock 2003 Mustang GT - Vortech 415rwhp SOLD |
13.364@105
swapped to a tr-3650
|Forged Motor||11.1:1 CR||Stage 2 Heads||Custom Bullet Cams||MAC o/r H and CB||75mm TB/Plenum||JLT Cai| 290rwhp 307 rwtq |WTB Longtubes| |
2003 Mustang GT
11.98 @ 118.68mph
Idk, numbers seem low. Could do a compression check. Did you degree the cams?
13.364@105
yea they're degreed and everything. I just had someone down here in Fl build it for me. He's awesome. I think its just missing some important components...
MM's V6 Hater
2000 Mustang GT 5spd
96.49@ 3mph
![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: 27 reviews
Baznasty got. 305 with bolt on plus cams.
WANTED: STOCK GT SPRINGS, headlights, tail lights. 2000 5.1 built supercharged GT. 463/454 2006 GTO. SOLD 2008 F350- 12k pounds of slowness |
13.364@105
and so have alot of other people...I did ported heads, cams, and increased compression...I was hoping for 320-330...I really think the lack of Long tubes and larger cams are holding it back.
Anyone have a 330hp na 2v combo?
MM's V6 Hater
96.49@ 3mph
He was only s/n I could remember. I would think your numbers would be higher too.
![]() ![]() ![]() iTrader: -1 reviews
#10 | |
13.364@105
I think the cams are a bit on the small size as well. They compare very similar to a stage 1 comp shelf cam.
2004 mustang gt
12.1@110
![]() iTrader: 4 reviews
I would look in to mhs cams
04 mustang gt- true forged rims,procharger d1,t-56, stinger ect 408whp 390tq 10psi Awaiting a built motor 03 duramax- suncoast stage 6 tranny, 100 injector, air dog,arp headstuds, efi live, s&b, 5inch exhaust ect.. 531whp 900+ tq |
2007 Mustang GT
Dunno yet
![]() ![]() iTrader: 9 reviews
Id think with that setup u would have at least 375 to the wheels. Maybe its outflowing the stick intake? What injectors. U running?
Proofs in Performance
02 Mustang GT
9.99@137
What pistons are you running?
Did yoi make sure the valves were sealing befote installing? Post the graph.
2002 GT PI heads Edelbrock TH400 Twin 60mm turbos E85 ![]() Hatters GONNA Hate |
375 to the wheels?! Ya ok...
What kind of dyno did you tune on? Whats the weather like? How many miles on the new motor? It will loosen up and pick up some hp.
99 Mustang GT 560rwhp on STOCK HEADS, 4.75L, Kenne Bell Mammoth 2.1, Killer Chiller @16lbs, Cobra Inlet, LFP Throttle Body, JLT High Boost CAI, CMS Stage 2 Blower Cams, HPX, 3.55s, MGW, Battery Relocation, Intercooler Tank Relocated, CF DF clutch |
13.364@105
umm def not 375...
24 lb injectors tuned on a dynojet in Fl. Wasnt to hot out really... We tuned it after I broke it in at around 1300 miles on the new motor. Maybe some more miles will help?
13.364@105
Pistons are probe 4.5cc dish. forged. I dont have a graph handy :/ I could possibly have it emailed to me or something...
2007 Mustang GT
Dunno yet
Well jesus christ..with that much shit into the motor its sad it wont
2007 Mustang GT
Dunno yet
Spray that mother fucker then with a 200 shot and call it a day
What timing are you running and what a/f? Post up a datalog screenshot so we can see spark and a/f.
Your cam selection should be fine. You don't want to got big with cams unless you want to essentially bleed off cylinder pressure (torque) under 4500 rpms. If I was in your situation, I would save for a centri blower setup. Your engine is setup almost perfect for low boost and high rwhp. Or you could spray it as mentioned, I recommend a progressive controller. Good luck.
1999 gt
Don't know 13s
Wow that's really low with just the bolt ons injave I out down 267 and 307 and I don't have cams or heads or headers. There is deff something goin wrong with that setup. If you checked the compression ratio and that was good how else would you be able to tell what the problem is? Do you have a mid pipe and cat back as well still would only be worth maybe 10-12 hp you should be easily in the 320-330 range. Long tubes and full exhaust should bump u up maybe another 20 so you would be at 300 by then ur still seems low maybe the air fuel is off or something or the timming is messed up cause that engine is def sick and no feelin well
bbk CAI, bbk throttle intake, frpp, 3.73s, sct 91 oct tune, steeda upd, magnaflow cat back, magnaflow O/R X pipe, MM Flsfc, Lakewood LCA, mgw shifter, king cobra clutch, 18"rims nt 555 Nittos 245, 285, halo angel eyes, autometer guages.
Threads Similar to: Built NA 2v not making power
| How much power do you think im making? | SneakyFox | 5.0 Mustangs | 9 | January 16th, 2012 02:16 AM |
| Car making too much power | 96 S281 | 96-98 | 12 | April 6th, 2011 09:56 PM |
| what are you making for power with your cam? | built4ford | 2005 - 2010 | 4 | July 19th, 2010 03:48 PM |
| What power should I be making? | TimboStang | 2005 - 2010 | 11 | May 6th, 2009 07:44 PM |
| 1995 3.8L / 232 SFI - making more power | ProwlerGT | V6 Mustangs | 16 | November 7th, 2007 12:59 AM |
