Upgrading Rear-end
Old June 19th, 2007, 08:03 PM   #1
DrHolliday is on a distinguished road
Upgrading Rear-end
I want to upgrade my mostly stock rear end before I ship the car back to the east coast and put some slicks on it.
I'm thinking 31 spline Forged Mosers. Just not sure what type of posi to get. Thinking the Detroit true-trac.
What else would I need other then the axels and the differential? Just asking so I can look into ordering all the stuff I need.
Mustangless atm
2006 2500 HD Diesel. Built allison trans and other goodies
Old June 20th, 2007, 01:58 AM   #2
01GT is on a distinguished road
Welded axle tubes, and a differential cover with an integrated girdle (TA, FRPP, UPR, just to name a couple)
Don't buy from this guy: 1fstmach1
Old June 20th, 2007, 06:42 AM   #3
mm's nitrous mod
SWEET2KSTANG's Avatar
2000 mustang gt
11.79@115.83 (old set up)
iTrader: 8 reviews
most axles come with axle bearings and seals. you will need to go buy inner and outer pinion bearings, diff and gears. if you want welded axle tubes, then you would want to do it at installation. how much power you going to be running? i have a t-lok, alloy axles, and jegs gears.
Old June 20th, 2007, 07:39 AM   #4
MM's nicest mod, :)
White99stang's Avatar
White99stang is a name known to allWhite99stang is a name known to allWhite99stang is a name known to allWhite99stang is a name known to allWhite99stang is a name known to allWhite99stang is a name known to all
33 spline mosers with a spool hehe
06 Dodge MegaCab Diesel 455rwhp/815rwtq
REAL TRUCKS DON'T USE SPARK PLUGS
Old June 20th, 2007, 10:09 AM   #5
RLY SRS
ChrisJ's Avatar
iTrader: 10 reviews
I would recommend this being a good time to change the gearing to what you want it to be...
A diff girdle is a suggestion like said above...You can use the stocker but why not go ahead and do all the imporvements at once...
I have 31 spline Strange Axles and a 31 Spline FRPP Diff (Supposedly Carbon Clutches)...It will work fine for me...
If the axles do not come with new bearings I would buy a set and replace them...No matter the mileage...
Facebook
Google+
Old June 20th, 2007, 11:59 AM   #6
matrixpuba is on a distinguished road
Send a message via AIM to matrixpuba Send a message via MSN to matrixpuba Send a message via Yahoo to matrixpuba
im running all frpp in mine. 31 spline axles, cobra t-lok(the one with carbon clutches) 3:73 gears, arp main studs and a frpp aluminum girdle with royal purple fluid.
Old June 20th, 2007, 02:52 PM   #7
FOR POINT SIX's Avatar
FOR POINT SIX is on a distinguished road
I am running strange 31 spline axles, FRPP 4.10s, and a True-Trac in mine. If I had to do all over I would not use the True-Trac. It makes some noise when you take off from a dead stop. And come to find out this is very common with the True-Trac. But other than that it has been a great.
Old June 20th, 2007, 03:20 PM   #8
Well, my end goal is 600-700 rwhp. I know the forged axles and all the bearings, new posi to match the 31 spline.
I think I might keep the 4.10's. With some wide slicks adjustable coil overs and new control arms I should hook up pretty good from a dig.
Only question I have is: What is involved in welding the axle tubes? I've heard about it and have a good idea what it is, but i'm still unsure on what exactly it is.
Mustangless atm
Old June 20th, 2007, 08:19 PM   #9
its when you stitch the tubes to the center section. under a hard launch the tubes can spin in the center section so this stopes it. also welded torque boxes are a must if you plan on running slicks.
Threads Similar to: Upgrading Rear-end
upgrading rear end Raven 96-98 6 May 25th, 2007 09:11 AM
Upgrading to v8 nickp008 V6 Mustangs 9 January 13th, 2007 06:41 PM
upgrading my 06 v6 bryanrocks907 V6 Mustangs 1 October 19th, 2006 10:22 PM
Upgrading a V6 Wilson00V6 V6 Mustangs 5 October 19th, 2006 07:11 AM
Help upgrading 4bangerEater V6 Mustangs 6 July 18th, 2006 01:26 PM
