Vortech input shaft seal - Forums at Modded Mustangs
post #1 of 3 Old April 18th, 2012, 10:01 PM Thread Starter
blownstang's Avatar
So there is some oil on the front side of the blower (where the pulley is), bracket, a tad on the back side of the pulley and relocated idler pulley, and some on the bracket. It's not alot just lightly coated. My guess is the input shaft seal is leaking a little. Who has replaced the input shaft seal or had someone do it other than Vortech? Where did you get the seal from? Seems like a fairly easy job. I'm not sending the blower in for a $360 rebuild. Hans at Dean's Performance who will be installing my intercooler kit in three weeks says he has replaced the seal before. Told me to get a seal. I called Vortech and they will not sell a seal, tell you who makes it, or give you a part number. I did some of my own research.
The below links were helpful to see how to do it. One of the posts says the seal has part number 25 40 7 on it. I jammed a very bright LED light between the pulley and input shaft tonight and saw a 25 40. The 7 must be on the part of the seal that is under the input shaft so I could not get to it. One guy in one of the links mentioned that he went to the local parts store, gave them the part number, and they gave him a seal that corresponds with that part number. There are also some companies selling better than stock input shaft seals for a Vortech. The links are below.
Vortech Supercharger Seal
928 Motorsports - Porsche® 928 Performance Parts - Vortech High-Speed Seal Set V1 V2 V4 V5 V7 V9 XB-1a - Porsche® 928 World record Holder 216.63537 mph
http://www.starrland.com/Supercharge...%202-22-08.pdf
oil leak from vortech? - SVTPerformance
TRD Vortech Supercharger Seal Repair FAQ - Scionlife.com
2003 DSG Mustang GT TR3650 - 411/403 with a Vortech S trim. Now back to stock.
2004 DSG Mustang Mach 1 4r75w - 423/387 through unlocked converter. Intercooled Vortech V1 S trim, Circle D 4c converter, BCA valve body, VRS o/r x pipe
blownstang is offline
post #2 of 3 Old April 18th, 2012, 10:25 PM Thread Starter
blownstang's Avatar
Found these on ebay. I read Viton is the way to go. Last one only says it is Viton.
Metric Oil Shaft Seal 25 x 40 x 07 25x40x7 Double Lip | eBay
National Federal Mogal Seal 25x40x7 New in box | eBay
HUSQVARNA KTM CAGIVA Engine Seal Viton 25x40x7 Double Lip | eBay
post #3 of 3 Old April 18th, 2012, 10:34 PM
Moderator
SSG Pate's Avatar
iTrader: 9 reviews
Good info man I will keep this in mind if I ever have that issue with my Vortech.
Convertible Crew Founder
Proud Iraq and Afghanistan War veteran
700 RWHP Club Member #1
Vortech T Trim @18 PSI
604 RWHP 516 FT LB
11.50@121.77@ 523RWHP
Precision Turbo 7675 CEA @ 20 PSI
738 RWHP 691 FT LB
10.9 @ 131 MPH
SSG Pate is online now
Human Verification
