I need some help (Nitrous jet question)
Old June 22nd, 2007, 07:20 PM   #1
MM's Mad Scientist
acmillr's Avatar
Slow Fella
acmillr is a splendid one to beholdacmillr is a splendid one to beholdacmillr is a splendid one to beholdacmillr is a splendid one to beholdacmillr is a splendid one to beholdacmillr is a splendid one to behold
Could someone please tell me what size jets you are running for a particular HP setting? I have checked some of the nitrous jet calculators, but they disagree with each other.
Old June 22nd, 2007, 07:27 PM   #2
03 R Code's Avatar
unstoppable @ speed of light
03 R Code will become famous soon enough
This is from a coldfusion kit. The ratings are for crank hp, and not for rear wheel hp.
100shot-.052 n2o : .029 fuel
125shot-.057 n2o : .031 fuel
150shot-.063 n2o : .035 fuel
200shot-.073 n2o : .039 fuel
Hope this helps.
Political correctness is a doctrine fostered by a delusional, illogical, liberal minority, and rabidly promoted by an unscrupulous mainstream media, which holds forth the proposition that it is entirely possible to pick up a turd by the clean end.
Old June 22nd, 2007, 07:37 PM   #3
MM's Mad Scientist
acmillr's Avatar
Slow Fella
Uh Oh, I think I know why my car has been screaming like a bat out of hell lately. I had a slight mix up. I thought I installed a 75 HP jet a few weeks ago, but my car has been an absolute beast. I'm talking about burning the tires at 70 in third gear.
I ordered a .057" jet from dynotune, and when it came in, I took my old jet to compare sizes. Boy was I surprised- the jet I had in my car was about twice as big as the .057" (or so it looked). After some careful cleaning and polishing, I can clearly see a marking. It is stamped either 89 or 68. I'm pretty sure it's an 89 because it is way bigger than the .057. I'm pretty sure the limiting factor was my injection tube- it looks a litle smaller than the jet, but not much. Either way, I'm surprised I still have a motor. I have run about 15 lbs. of nitrous through my motor on this jet.
Old June 22nd, 2007, 09:05 PM   #4
stangaddict's Avatar
stangaddict is on a distinguished road
wet or dry?
the dry 86 nozzle from compucar is 100rwhp
2002 Eddie Bauer Ford Explorer
1987 Chevrolet Corvette
Modded....Enough Said
Old June 22nd, 2007, 11:09 PM   #5
MM's Mad Scientist
acmillr's Avatar
Slow Fella
Thank God, I went and looked again and it is 86. Also, it came out of a Compucar kit. Why is it so much bigger than the jets that come in other kits?
Old June 23rd, 2007, 12:17 AM   #6
mm's nitrous mod
SWEET2KSTANG's Avatar
2000 mustang gt
11.79@115.83 (old set up)
iTrader: 8 reviews
damn!!! i am running a 56/32 in mine.
Old June 23rd, 2007, 07:48 AM   #7
03 R Code's Avatar
acmiller, are you running a wet or dry kit? I'm pretty sure the absence of fuel in the mixture would change the size of the nitrous jets. That could be why we have different size jets for that same hp rating. Also remember that the jets in the coldfusion kits are for flywheel ratings...
Old June 23rd, 2007, 07:56 AM   #8
MM's Mad Scientist
acmillr's Avatar
Slow Fella
I'm running a dry kit. I think that the solenoid used in this kit will not flow any more than a 100 HP shot is what is going on.
Old June 23rd, 2007, 08:51 AM   #9
03 R Code's Avatar
Wow... That has to be a tiny solenoid. I always thought that a solenoid would flow as much as any jet size could handle. I'm not sure though. I don't know a ton about nitrous components yet. You said the jet came out of a compucar kit right? where is the solenoid from?
Old June 23rd, 2007, 09:07 AM   #10
MM's Mad Scientist
acmillr's Avatar
Slow Fella
It's from Compucar as well.
Old June 23rd, 2007, 10:08 AM   #11
03 R Code's Avatar
I checked on compucar's web site and the most basic kit the sell will flow up to a 125 shot. This means that the soleniods will handle at least that much nitrous. I would assume that they probably use the same soleniods on all their kits, except for the more for professional set ups, like foggers and direct port kits. But then again, you know what happens when assuming things...
You should call there tech support Monday when they open back up for business.
Old June 23rd, 2007, 10:35 AM   #12
MM's Mad Scientist
acmillr's Avatar
Slow Fella
I called over there already and the guy I spoke to was really vague about how much this solenoid would flow.
It is irrelevant at this point. I won't be spraying my motor for a while. It appears as though I have found the breaking point.
312/326 n/a HP + at least 100 HP of giggle gas + 6500 rpms on a daily basis = knock, knock, knock............
It started hearing it this morning coming back from Advanced auto parts with a filter and some oil. I'll just save the new filter for the next motor. It was only a matter of time before it went, but I was hoping to get a few more thousand miles out of it. Oh well, I'll just nurse it around for a few weeks until my new motor is complete.
Old June 23rd, 2007, 07:27 PM   #13
MM's Mad Scientist
acmillr's Avatar
Slow Fella
I just got back from gettting my new block and a 6 bolt crank. As soon as i get the rods, pistons, and get it together I'll be going for the 200 shot.
BTW: I know this has been brought up before, but I'm going for 350+ at the wheels on motor.
Old June 23rd, 2007, 11:35 PM   #14
Timber's Avatar
Timber is on a distinguished road
And I'm sure you'll get there. If I'd never rode in your car I'd still have mine. I'm just sorry I won't get a chance to ride in it when you're finished. It was FN brutal as it was.
http://pic14.picturetrail.com/VOL534/828983/15628081/246397139.jpg
Old June 24th, 2007, 09:33 AM   #15
neckbonekat's Avatar
2005 Cadillac STS V8
Are you blaming AC for your decision? Damn it AC what did you do to Timber while he was down there? Now he is scarred for life. LOL
ITEMS FOR SALE!
4.10 GEARS + BEARING KIT
Old June 24th, 2007, 10:15 AM   #16
MM's Mad Scientist
acmillr's Avatar
Slow Fella
I'm sorry, I just drove it like a was going to the grocery store.
Old June 24th, 2007, 11:27 AM   #17
ujslost's Avatar
so AC you dropped the idea of getting an 03 cobra?
Old June 24th, 2007, 11:46 AM   #18
MM's Mad Scientist
acmillr's Avatar
Slow Fella
Yes, I'm going to build a n/a set for my GT. After I get block out of the car and get it running on the new motor, I will probably go ahead and build a second shortblock with -22cc pistons. I talked to a local shop about building a turbo set up, and I plan on working on that for the next year or so. I feel like I have all of the tools and knowledge to build a turbo myself since I finally got a good welding set up at my house. I'm just going to keep the 2v and play with it for a while.
Threads Similar to: I need some help (Nitrous jet question)
nitrous question BWAL 5.0 Mustangs 26 November 2nd, 2007 05:49 AM
Nitrous question 89LX347 5.0 Mustangs 25 July 2nd, 2007 01:19 PM
nitrous jet question flattusmaximus78 V6 Mustangs 13 May 17th, 2007 10:12 PM
Nitrous Question 351stng 5.0 Mustangs 10 April 12th, 2007 11:21 AM
Another Nitrous Question keiken 96-98 7 March 2nd, 2007 09:05 AM
