tubular front kmember
Old June 22nd, 2007, 11:39 PM   #1
1999 Mustang
Invictus is on a distinguished road
I have my entire front kmember out of my GT right now and while it's out i considered buying a new D&D or MM tubular front kmember for more header clearance, shave a few pounds and better handling.
Aside from that, is there anything else this kit is good for? Is it even worth getting for my DD car? I'd also need a coil over conversion, C&C plates, and a few other things...
Is it worth it?
Old June 23rd, 2007, 01:12 AM   #2
droppedbass87 is an unknown quantity at this point
Send a message via AIM to droppedbass87
yeah do it man..and only if you want get some coilovers and tubular a arms..and then you will have it setup to go with turbo cuz thats what you have to do with every turbo is get a tubular kmember..
Old June 23rd, 2007, 01:20 AM   #3
mm's nitrous mod
SWEET2KSTANG's Avatar
2000 mustang gt
11.79@115.83 (old set up)
iTrader: 8 reviews
some kits can use the stock a-arms and etc. i dont know much about them, i have heard that the ride gets rough with them.
Old June 23rd, 2007, 08:50 AM   #4
03 R Code's Avatar
unstoppable @ speed of light
03 R Code will become famous soon enough
Be prepared for a lot of noise. Even the top of the line k-member kits will rattle and squeek. It's well worth it performance wise, and most kits will last forever on a dd car, but do your research and find out which one's won't. I've heard that the UPR kit won't last too long on a dd car....
Political correctness is a doctrine fostered by a delusional, illogical, liberal minority, and rabidly promoted by an unscrupulous mainstream media, which holds forth the proposition that it is entirely possible to pick up a turd by the clean end.
Threads Similar to: tubular front kmember
BMR Fabrication Front Antiroll Bar Eliminator/Tubular Lower Draztic1 2005 - 2010 2 September 30th, 2007 12:00 PM
Tubular K-member kit acmillr 99-04 28 August 21st, 2007 02:06 PM
Tubular K Members 90ProjectStang 5.0 Mustangs 2 August 24th, 2006 07:10 PM
after upr kmember install? hrseply General Tech 2 June 21st, 2006 03:24 PM
