New K-member question
Old June 23rd, 2007, 08:49 PM   #1
energiesource's Avatar
energiesource is on a distinguished road
when purchasing a tubular k-member, what can you reuse out of your stock suspension stuff and what do you need to buy for it to work?
Old June 23rd, 2007, 09:00 PM   #2
MM's Mad Scientist
acmillr's Avatar
Slow Fella
acmillr is a splendid one to beholdacmillr is a splendid one to beholdacmillr is a splendid one to beholdacmillr is a splendid one to beholdacmillr is a splendid one to beholdacmillr is a splendid one to behold
I think if you get an AJE, you can use your factory lower control arms and shocks. I don't know of any other system like that. All the others, that I have knowledge of, require aftermarket lowers and coil overs. I may not 100% correct on that last part though.
Old June 23rd, 2007, 09:00 PM   #3
i was planning on getting a steeda one, if that helps
or should i stay away from that one?
Old June 24th, 2007, 12:19 AM   #4
zerofx150's Avatar
2003 GT
13.6 @ 101
zerofx150 is on a distinguished road
Send a message via AIM to zerofx150 Send a message via Yahoo to zerofx150
i've read that the QA1 system is modular so you can use all your factory stuff and then later add the coil-overs or LCAs etc
03 GT 5sp, K&N FIPK, MAC LT ceramic coated headers, MAC Prochamber, Steeda Tri-ax, 3.73, SCT X-cal2 tuned by D&G Dyno Tune, NX plate Kit, Eibach Pro Springs, CMS Stage 2 cams. STRIKE design from MK Motorsports.
Old June 24th, 2007, 03:47 AM   #5
1999 Mustang
Invictus is on a distinguished road
i think you need 4 bolt C&c plates, coil over conversion, and on some kits an oil pump relocation
Threads Similar to: New K-member question
GMS Mustang Tubular K member Kit w/ A-arms, K member, & 94GTD1SC Drag 1 November 16th, 2007 12:11 AM
New Member saying Hi from NC belial New Members Introductions 15 July 1st, 2007 04:16 PM
New Member from NC aintsheperty66 New Members Introductions 9 June 29th, 2007 06:30 PM
New old member White2000GT New Members Introductions 7 June 15th, 2006 03:31 PM
