stumbling when going down the road
Old June 24th, 2007, 01:59 AM   #1
kdb30 is on a distinguished road
Guys I need some help.My 99 Mustang GT "stumbles" when cruising down the road.While idling it seems be a little rough,not too bad,just a little.Going through the gears it seems fine.However,when leveling off at highway cruising speed,it seems to jerk a tad.If I turn the defrost on it intensifies pretty good.Anybody know what could be wrong?Thanks in advance!
Old June 24th, 2007, 03:45 AM   #2
1999 Mustang
Invictus is on a distinguished road
clean you IAC, you can't do anything wrong by doing that. and also fluctuations at steady rpm is a symptom of your tps. check the voltage of it and see if it is to spec of not, it can be adjusted or replaced relatively cheap
Old June 24th, 2007, 02:07 PM   #3
steve_stang2003 has a little shameless behaviour in the past
+1
Also clean your MAF and check your air filter /box for contamination or the snorkel on loose etc.
Be VERY careful with the MAF and use only MAF cleaner or isopropyl alcohol.
Don't use carb cleaner as it is too caustic.
Old June 24th, 2007, 08:50 PM   #4
Baneful's Avatar
Baneful is on a distinguished road
Send a message via Yahoo to Baneful
I would like info on this too. My gt stumbles now on the highway at times, but doesn't seem to have any lack of power. I added a 1/2' copper pipe cap with a 1/4 hole drilled out to the iac line before the plastic black box to help the high idle drop. It helped the hanging idle, but it still stumbles at highway speeds while the ac is on. Could this just be the puter is still learning the airflow patterns? It seems every time my car wants to slow down while cc is on it stumbles.
I read it takes about 3 cycles of the ignition to learn the pattern, but I think I am past that.
I also read that the pipe cap worked on older gt's and that I need an iac restrictor plate instead of a cap... One side drilled to the iac hole size and the passanger side hole being smaller (depending on mods)...?
K&N fipk2 CAI, flowmaster 40 cat back, accufab 70mm tb/p, xcal2, 3.73 frpp gears, Steeda Tri-ax, Mach grill del.
255rwhp 295rwtq Needing more
Old June 24th, 2007, 08:55 PM   #5
Garhfer's Avatar
2004 Mustang GT Conv.
Garhfer is on a distinguished road
Send a message via AIM to Garhfer
wtf? Who told ya adding that crap to your iac line would help?? I wouldn't start adding crap to my iac lines, Just clean out your iac and everything should be fine... why does a hanging idle bother people so much? it hangs for like a second so what...
2004 GT Boosted by Vortech
Old June 24th, 2007, 09:01 PM   #6
40thmustanggt's Avatar
40thmustanggt will become famous soon enough
i agree its not a bad thing and it isnt going to hurt anything all 4.6 motors have it..
Old June 24th, 2007, 09:02 PM   #7
id try taking that crap off and seeing if it helps your stumble
Old June 24th, 2007, 09:39 PM   #8
MM's Mad Scientist
acmillr's Avatar
Slow Fella
acmillr is a splendid one to beholdacmillr is a splendid one to beholdacmillr is a splendid one to beholdacmillr is a splendid one to beholdacmillr is a splendid one to beholdacmillr is a splendid one to behold
Does it stumble under heavy acceleration. If it doesn't, I would have to think it is a TPS problem.
Old June 24th, 2007, 10:39 PM   #9
Ok I have cleaned my IAC.It looked fine but I cleaned it anyway.The air filter and maf all is fine also.The car is fine under any acceleration.It runs like a champ under acceleration.Just at idle it seems rougher than it should.And of course at an even highway speed she stumbles.I guess I need to check the tps.Any pointers from you guys on checking the voltage?Thanks for all the previous advice guys.
Old June 25th, 2007, 12:35 AM   #10
Baneful's Avatar
Crap, didn't want to hijack. starting new thread.
Threads Similar to: stumbling when going down the road
Another stumbling mustang changed IAC and Tp Sensor onerealfastang 99-04 12 August 6th, 2009 06:02 AM
Road Course 07stanggt 2005 - 2010 11 June 13th, 2007 08:12 PM
86 stumbling under load hopper 5.0 Mustangs 6 April 25th, 2007 09:25 PM
Stumbling powerband issues continued. MySallyMI 99-04 2 March 14th, 2007 12:10 PM
stumbling in hawxter996 V6 Mustangs 20 March 6th, 2007 09:51 PM
