MM's Mad Scientist
Slow Fella
![]() ![]() ![]() ![]() ![]() ![]() iTrader: 2 reviews
crankshaft specs
Does anyone know where to find the correct specs for the 4.6 crankshaft measurements? I.E. main journal diameter, rod journal diameter, and allowances.
Crankshaft
Main Bearing Journal Diameter 67.482- 67.504 mm (2.66 - 2.661 inch) Connecting Rod Journal • Diameter 52.983-53.003 mm (2.085941-2.086728 inch) Crankshaft Free End Play 0.075-0.377 mm (0.003-0.015 inch) Crankshaft Runout to Rear Face of Block 0.050 mm (0.01969 inch) max Connecting Rod Bearings Clearance to Crankshaft • Desired 0.027-0.069 mm (0.0010629-0.0027165 inch) • Allowable 0.027-0.069 mm (0.0010629-0.0027165 inch) Bearing Wall Thickness (Std) d 2.442-2.453 mm (0.096-0.097 inch) Main Bearings Clearance to Crankshaft • Desired 0.025-0.044 mm (0.001-0.002 inch) • Allowable 0.025-0.050 mm (0.00098-0.00197 inch) Bearing Wall Thickness (Std) f 1.919-1.925 mm (0.0756-0.0757 inch) Got this from another forum so I'm not sure how accurate it is. here's the link: http://forums.mightymustangs.net/ind...&mode=threaded
Mustangless atm 2006 2500 HD Diesel. Built allison trans and other goodies
MM's Mad Scientist
Slow Fella
I would trust the numbers you found... Its made by ford.
Threads Similar to: crankshaft specs
| Crankshaft Help PLEASE!! | ymerej47 | 5.0 Mustangs | 5 | September 9th, 2007 07:10 PM |
| Crankshaft torque specs anyone?? | stanglifemike | 2005 - 2010 | 18 | August 22nd, 2007 01:11 PM |
| Help! need crankshaft info. | acmillr | 99-04 | 8 | June 12th, 2007 08:26 AM |
| Steel crankshaft for 96 3.8l v6 | Easy04_jm | General Tech | 0 | October 22nd, 2006 01:50 AM |
| Cant Get Off Crankshaft Pulley | 02Gt Stang | 99-04 | 2 | September 14th, 2006 08:31 PM |
