Just got a 2000 GT, advice on changing Plugs and Springs
Old June 25th, 2007, 02:17 PM   #1
Philipk2003 is on a distinguished road
Hello All,
I just got a 2000 Mustang GT. I've done all the usual over the weekend(change all the fluids to Royal Purple)
Next week, I plan on changing the spark plugs and springs. Just wanted to check with all of you out there, when
1) to change the plugs, do I need to remove the fuel rail as it looks like the rails are right on top of the coils? Or do I simply loosen the nut, slide the coils to the side a litte and pull it off the plug? (I'm asking cus I havn't even tried yet)
2) when changing springs, do I simply remove the 2 bolts from the front strut to the lower control arm and let the suspension fall down? Or is there much more work invovled? Rear springs - any suggestions.
I've done many other cars, but this is my first mustang. Any advice is appreciated. Thanks!!!
Old June 25th, 2007, 02:48 PM   #2
MM's nicest mod, :)
White99stang's Avatar
White99stang is a name known to allWhite99stang is a name known to allWhite99stang is a name known to allWhite99stang is a name known to allWhite99stang is a name known to allWhite99stang is a name known to all
alright with the plugs, you don't need to remove the fuel rail. Just loosen the nut for each cop and take them off after you unplug it. Make sure your motor is cold, do not over tq the plugs and use a little bit of anti-seize. The springs can be a little bit more of a pain. All you have to do is jack the car up and remove the wheels, brake caliper, and put another jack under the a-arm, remove the 2 bolts holding the strut on the bottom. slowly lower the jack and more than likely the spring will not come out. I use a pry bar and kinda just stand back and pop it out. I have never managed to get it to fly out and i have done it over 10 times. Just take your time and enjoy working on your car.
06 Dodge MegaCab Diesel 455rwhp/815rwtq
REAL TRUCKS DON'T USE SPARK PLUGS
Old June 25th, 2007, 03:05 PM   #3
Thanks!!! I figured you need a jack under the front. How about the rear springs?
Old June 25th, 2007, 07:06 PM   #4
vichael1's Avatar
vichael1 is on a distinguished road
this should help you out!!
http://mustangworld.com/ourpics/fcar/steedaspring1.htm
CMS Stage I Cams
Tuned by Mike Rousch
Mid-Atlantic Performance
Old June 25th, 2007, 07:34 PM   #5
Vichael 1,
This is exactly what I was looking for, thanks!!!!
What's your opinion about changing the plugs?
Philip
Old June 25th, 2007, 07:39 PM   #6
DrHolliday is on a distinguished road
Originally Posted by Philipk2003
Vichael 1,
Philip
Plugs are easy on these cars. Just unplug the coil, remove the bolt and the coil comes right off the plug.
Just don't over torque the new plugs. I hear these heads can strip easy.
Mustangless atm
2006 2500 HD Diesel. Built allison trans and other goodies
Old June 25th, 2007, 10:56 PM   #7
Drgnracin72's Avatar
yeah, you overtorque them and your gonna pull the threads out of the head. not good. do exactly what white said, pull em cold, and put a little anit-sieze on them and torque to specs and then your good. the back left was the hardest for me
RIP
ΜΟΛΩΝ ΛΑΒΕ
One Big Ass Mistake America
SHEEPDOGS
Threads Similar to: Just got a 2000 GT, advice on changing Plugs and Springs
2000 Mustang spark plug changing Black Wind V6 Mustangs 14 January 18th, 2010 07:29 AM
Changing Tranny Fluid??? Where are the plugs??? Slowbra_12 96-98 3 August 6th, 2007 10:24 PM
Hey 2000 Si. Gimme some advice please homebrewed The Clubhouse 15 May 8th, 2007 12:48 AM
need an easy way of changing my plugs in my 2000 (v-6) timwade V6 Mustangs 1 February 25th, 2007 05:01 PM
