Rear wheel bearings - Forums at Modded Mustangs
post #1 of 11 Old June 10th, 2012, 11:45 PM Thread Starter
2VSouth's Avatar
iTrader: 6 reviews
Rear wheel bearings
Mine are going bad and the humming noise is driving me fucking crazy so I need to change them out. I'm not positive how to do it on our cars. Just take the diff cover off, push the axles in, remove c clips and pull out axles to change the bearings?
2VSouth is offline
post #2 of 11 Old June 11th, 2012, 01:08 AM
iTrader: 16 reviews
i believe there pressed on aswell
2017 oxford white GT 5.0
2003 GT stock sold
2006 Spec V sold
1991 chevy s10 4.3L sold
2003 chevy colorado z71 sold
2006 spec v sold
few 71 bugs all sold
1_nice_03_gt is offline
post #3 of 11 Old June 11th, 2012, 01:10 AM
Procrastinator
Something like that, make sure you have new bearings and axle seals with you and it really helps to have a slide hammer with an axle bearing puller.
Edit
The bearings are behind the seals, I had no luck trying to pull the seal and it ended up easiest to just pull the bearing and seal at the same time.
DickH is offline
post #4 of 11 Old June 11th, 2012, 09:52 AM Thread Starter
2VSouth's Avatar
iTrader: 6 reviews
So the bearings and seals need replaced? Gotcha. Yes my neighbor has a slide hammer I'll be able to use. How do you pull both at the same time?
2VSouth is offline
post #5 of 11 Old June 11th, 2012, 09:52 AM
Woodman's Avatar
How much would I expect to pay to get this done? Mine are going bad too.
You guys are barely 20 years old yet. A fart that vibrates your nutsack is fap material for you.
woodman: achieving the impossible since 1967. 1973? 1980? 1985? 1976? whatever, you get my point
Woodman is offline
post #6 of 11 Old June 11th, 2012, 10:10 AM
bigjohnstud4200's Avatar
My guess is a shop would charge you two hours labor plus parts.
Tuned by Joe@TrickTuners
CMS Stage 1 Cams, 4.10 Gears, TrickFlow 70mm TB & Plenum, MAC Prochamber with Pypes M80's, MGW Shifter, Custom Paint, Cobra Cloth Top, Staggered Chrome 18" Saleen's and Sequential Tails.
bigjohnstud4200 is offline
post #7 of 11 Old June 11th, 2012, 10:25 AM
war1ock's Avatar
You cant pull both at the same time because there at the ends of the axles. Ive done them there not bad at all.
Sent from my C771 using AutoGuide.Com Free App
Originally Posted by Boercker View Post
ram it in the whole and see what happens (my philosophy)
Originally Posted by BakerFX4 View Post
Im more a meth kinda guy. Primarily on the weekends.
1997 GT. K&N Filter, Smoked Angel Eye Headlights, Sequential Taillights, Summit O/R H Pipe Flowmaster 40s
war1ock is offline
post #8 of 11 Old June 11th, 2012, 11:10 AM
cschoening09's Avatar
iTrader: 10 reviews
this may be very similar
2014 A6 GT Sterling Gray. SR performance lowering springs, J&M adj. panhard and Stainless power longtubes - o/r x awaiting tuner and install.
cschoening09 is offline
post #9 of 11 Old June 11th, 2012, 09:01 PM
Originally Posted by cschoening09 View Post
That video sucks. I didn't watch the whole thing but just in the first 1:30 seconds they skipped a significant portion of the job.. how to get the axles out.
This is the basics:
1) remove the rear differential cover.
2) remove the c-clips holding the axles in.
3) remove the bearings and seals
4) replace the new bearings and seals.
5) install axles and c-clips
6) reinstall diff cover and refill.
The most complete DIY will come from looking at gear install DIY's. Only thing you will have to remove are the c-clips and axles.
post #10 of 11 Old June 13th, 2012, 09:57 AM
Woodman's Avatar
This is the basics:
That doesn't look too bad actually. How much gear oil goes back in, and what is the most recommended type? I'll look up getting the C-Clips out too. Might be a good project for a sunny weekend.
Woodman is offline
post #11 of 11 Old June 13th, 2012, 10:48 AM
I can't remember exactly, but I believe it's 2 quarts.. you just fill it till it starts overflowing the fill hole; I used Royal Purple. The C-Clips are EASY.. once you have the wheels, brakes and differential open, you simply push the axle in towards differential. Then when you look inside the differential, you'll see the axle and the C-Clip. Once you remove the c-clip, you then pull the axle straight out.
Human Verification
