trouble with a coil connector
Old June 30th, 2007, 06:20 PM   #1
Jayhop101 is on a distinguished road
OK i started to chang my coil connectors (boots) out on my 1999 mustang gt. OK here is the problem, the boot has a spring in it, the side the goes to the plug has some kind of resistor looking this that actually makes contact with the plug, this item is what connects the spring to the plug; well this part was broken (which has to be the problem i was having with my stang, but I dont know the name of this part, neither does any of the parts stores around here!!!! So does anyone know what this is called so i can order it???
Old June 30th, 2007, 11:01 PM   #2
mm's nitrous mod
SWEET2KSTANG's Avatar
2000 mustang gt
11.79@115.83 (old set up)
iTrader: 8 reviews
just go to oreilly's and get a coil boot. it is like 7 bucks i think. i have had to replace one on my car.
Old July 1st, 2007, 01:48 PM   #3
this part did not come on the coil boot. does anyone else's stang have this piece of metal at the end of the spring that connects to the plugs, or is it just the spring inside the boot that connects to the plug?
Old July 1st, 2007, 01:53 PM   #4
01GT is on a distinguished road
just the spring inside that connects to the plug....
Don't buy from this guy: 1fstmach1
Old July 1st, 2007, 04:00 PM   #5
Zoolander
04 Cobra #2260/3768 1/820
iTrader: 5 reviews
are you talking about the rope possibly?
MM Cobra Club #18
Team Tini Racing
I don't know jack shit...
Old July 2nd, 2007, 12:58 AM   #6
those are aftermarket.... the stock ones use a coil spring on the inside, nothing else.
Old May 8th, 2011, 10:57 PM   #7
Look Ma! My First Post!
Aeonixx is on a distinguished road
Go to autopartswarehouse.com and search for Dorman Spark plug wire boot. They include the springs. They aren't just springs. They are a highly conductive Nickel coated connection between the spark plug and the coil. Don't just stick a chunk of spring in it..
Threads Similar to: trouble with a coil connector
96 Cobra FLSubframe Connector Trans Crossmember Modification Ryan Paymaster 96-98 6 July 24th, 2007 11:14 AM
sub frame connector question? spero 99-04 17 April 12th, 2007 08:40 PM
2005-2007 Mustang GT 3V Coil Packs & Coil-on-Plug Connec ozan169 2005 - 2010 4 February 7th, 2007 09:03 PM
Connector broken or supposed to be like this? 5literJeff 5.0 Mustangs 12 July 31st, 2006 05:24 PM
coil pack to coil on plug conversion mustang_montana 96-98 6 July 24th, 2006 01:32 PM
