Throw out Bearing noise when clutch let out? - Forums at Modded Mustangs
post #1 of 13 Old July 7th, 2012, 09:19 PM Thread Starter
Hi everyone. I have an 02 mustang GT and had the clutch replace about 30k ago. Car has 101k now. When i let out the clutch and have it in neutral i can hear a squeaky chattering. When i push in the clutch it goes away. What could this be please? how hard is it to replace? and im am an entry level tech so is this easy to do?
1998 GT 5spd- Full pi swap, Fenderwell CAI,UPR Catted X-Pipe, Mac FlowPath Cat-Back
1988 LX auto- Pypes violator cat-back, UPR X-Pipe, Shift Kit, 4.10 Gears, Pulleys, Suspension upgraded, CAI
1999 GT 5spd- CAI, Pypes violator cat-back
Damaso is offline
post #2 of 13 Old July 7th, 2012, 09:35 PM
Dysturbed87's Avatar
It is more than likely the throw out bearing. Cost of the part...$30-$40. You will have to remove transmission to replace. If you do replace it only use a Ford racing one as they are the best ones. It is possible for you to do but may be a little advanced for a beginner...just all depends on how long you want the car out of service if you attempt to try
You could leave it and it may be fine though. I've had friends that only had the noise and bearing never went out, just depends. I had one make the noise and a few weeks later it went out.
Sent from my DROID RAZR
Dysturbed87 is offline
post #3 of 13 Old July 7th, 2012, 10:32 PM
02gtKev's Avatar
Mine has been making the same noise also for the past 2 months.
I had my clutch replaced 7 months ago but used the tob that came with the clutch kit.....didn't stay quiet long. Im hoping i can squeeze another 2 weeks out of it so i can get it replaced with the ford oem one i bought.
02gtKev is offline
post #4 of 13 Old July 7th, 2012, 10:50 PM
joshdj13's Avatar
mines been making the noise for about 3 months. i would recommend replacing the clutch while you have the trans out. it will save a lot of trouble down the road. i also recommend the ford racing tob
joshdj13 is offline
post #5 of 13 Old July 7th, 2012, 11:29 PM
Procrastinator
Not uncommon for non ford throw out bearings to go bad quickly. My throw out bearing made noise for probably a year before i changed it. As far as a technical job, once you pull the transmission you are 49% done so if you can do that you are good.
DickH is offline
post #6 of 13 Old July 7th, 2012, 11:47 PM
Certified Bwaloligisit
Mach Stang!'s Avatar
yup. I have that squeaking to. Very faint, but so far its been fine after a month.
-Rocco
Mach Stang! is online now
post #7 of 13 Old July 8th, 2012, 02:01 AM
02gtKev's Avatar
Mine has progressed to constantly chriping at idle.
02gtKev is offline
post #8 of 13 Old July 8th, 2012, 09:44 AM Thread Starter
Thanks for all of the responses. I think ill probably replace it next semester in my trans class at school. I want to get a heavy duty clutch anyways cause i wanna spray the stang. thanks for the input.
Damaso is offline
post #9 of 13 Old July 8th, 2012, 10:47 AM
MM's V6 Hater
iTrader: 31 reviews
Yep, sounds like a TOB. Follow the how to guide in the sticky section. I would replace it ASAP before it explodes into pieces. Shouldn't take but ~5 hours if you've never done it before, with breaks.
Edit: replacing your clutch? look no further.
2013 GT
2016 F150
Cabikejumper is offline
post #10 of 13 Old July 8th, 2012, 11:03 AM
MacDizzle's Avatar
Mine comes and goes also usually after doing burnouts but its faint.
Im into high speed chase play and im First On Race Day!
Roughneckin aint eazy but some poor tough bastards gotta do it!
2000 GT - MMR 4.75 (750SE)
2013 GMC Sierra - 5.3L Vortec
2008 Kawasaki Brute Force 650 4x4i
MacDizzle is offline
post #11 of 13 Old July 8th, 2012, 12:03 PM
mine has a small knock once i press the clutch a little its gone. Its been like this since i started driving in january.
01 cobra=Bassani o/r x, lm1, H&R,JLT,blacked out,chrome 03 cobras, HID's
f350-8" lift, moto metal 951's, toyo m/t 37/13.50/17, no cat borla, HID's, train horns, tints
07 r6=flat black, full exhaust, geared
MM cobra club #121
cc250r is offline
post #12 of 13 Old July 8th, 2012, 12:10 PM
Bringing Yellow Back
zinc-vert02's Avatar
Send a message via MSN to zinc-vert02
mine makes a rattle noise, it has since i put the new clutcha nd tob in it. im pretty sure the fork is worn out
Stock long block 2v, stock trans, 100 shot of go fast gas. 315hp and 430 trq on spray
zinc-vert02 is offline
post #13 of 13 Old July 8th, 2012, 12:58 PM
Mr. Stangarang
04MidnightGT's Avatar
iTrader: 5 reviews
My car is running the factory installed clutch and I just hit 89k, boosted since 85k, and the tob is just now starting to go lol. The person who had my car before me was an older gentlemen, always babied it, and then I bought it
Oh yea I bumped it up to 10psi last night and when I raced a 600cc crotch rocket I layed rubber on the road at 40mph
USAF E-5
IG @ nj_5oh
Current Vehicles
14' Mustang GT "Alexandria" - Paxton Supercharged
15' GSX-R 600
Sold Vehicles
08' Lancer Evolution X MR
04' Mustang GT - Single Turbo
04MidnightGT is offline
Human Verification
LinkBack to this Thread: http://www.moddedmustangs.com/forums/99-04/268900-throw-out-bearing-noise-when-clutch-let-out.html
Thread Throw out bearing noise, new clutch, new bearing | Corral.net: Ford Mustang Forums | BoardReader This thread Refback November 29th, 2012 03:26 PM
Thread Clutch/Throw-out bearing noise | Subaru Forester Owners Forum | BoardReader This thread Refback July 16th, 2012 12:33 PM
