Getting Cams and heads
Old July 2nd, 2007, 06:08 PM   #1
DrHolliday is on a distinguished road
This post isn't for me, its for Amp...
He's getting cams and heads, and I'm helping with the install.
He's getting stage 2 heads, undecided on cams still. He has a 75mm TB, plenum, K&N CAI. He will be getting headers and a O/R mid pipe that we will be doing the same time as the cams and heads.
My question is, what size injectors should we go with? Its got the stock 19#ers right now. I'm thinkin somewhere in the 24 to 30# range would be perfect for now. Any advice would be awesome.
Should we look into upgradding the MAF too? He's planning to forge and KB it later, so we could always wait untill then to upgrade the MAF.
So to recap the questions:
1. What size injectors are recommended?
2. Unpgrade the MAF or keep stock for now?
Mustangless atm
2006 2500 HD Diesel. Built allison trans and other goodies
Old July 2nd, 2007, 06:09 PM   #2
^^^ that was my 500th post :award
Mustangless atm
Old July 2nd, 2007, 06:34 PM   #3
Baneful's Avatar
Baneful is on a distinguished road
Send a message via Yahoo to Baneful
I remember seeing a couple things for that.
http://www.rpmoutlet.com/formula.htm
http://www.2gnt.com/www/corbin/chooseinj.html
http://www.conleyracing.com/article_fuelinjectors.htm
K&N fipk2 CAI, flowmaster 40 cat back, accufab 70mm tb/p, xcal2, 3.73 frpp gears, Steeda Tri-ax, Mach grill del.
255rwhp 295rwtq Needing more
Old July 2nd, 2007, 06:46 PM   #4
mm's nitrous mod
SWEET2KSTANG's Avatar
2000 mustang gt
11.79@115.83 (old set up)
iTrader: 8 reviews
the 19lb will be fine for now. i am going to p&p my heads and install lt's and prochamber when the trans gets here. look in my garage and see the bolt ons i have, every tuner i have talked to is saying the stock injectors are fine.
Old July 2nd, 2007, 08:28 PM   #5
Sweet, guess we'll keep the stockers for now until he gets the KB.
Mustangless atm
Threads Similar to: Getting Cams and heads
Heads and cams mystang0673 99-04 1 September 2nd, 2007 03:43 PM
Heads and cams pa.ulB General Tech 4 August 9th, 2007 03:32 AM
CAMS vs Heads nHuman 96-98 10 February 28th, 2007 09:43 AM
Heads and Cams help please! 00silvergt 99-04 4 June 10th, 2006 09:56 PM
heads and cams? Drgnracin72 99-04 4 June 9th, 2006 01:04 PM
