Discussing White face gauge install in the 99-04 Forum. I don't understand why you cant just put them where they would be if ... Modded Mustangs is the premier Ford Mustang Forum on the internet. We discuss all aspects of the Ford Mustang on the forum. Registered Users do not see the above ads. Please Register - It's Free! |
I don't understand why you cant just put them where they would be if you shut your car off when you put them back on, or do the whole hold the odo/trip button and then turn on your key and watch it do the full sweep thing.
So is this possible or do you need to do it the way most places tell you to?
2000 Mustang GT, Steeda Triax shifter, Underdrive pulleys, SLP LM2, MAC L/T and O/R H-pipe. Transmission fix, new clutch Coming soon: Brakes.
well i pretty much screwed it up, can you recalibrate it with a tuner, or is that just your speedo?
Y2K GT
13.3@103
Makesure your car is completly cold and make your gauges look like myn excpt for the gas one
and if you cant tell b/c of poor pic quality the needles are right under the red bar and battery is little bit over half full the speedo and tach need to sit right on the little black bar. now for the gas just leav your clear cover of and go fill up tank compltly full adn put the needle little over full and you should be good to go. and sorry agian for poor pic cam sucks
Studies show that 92% of kids listen to rap. If you are one of the 8% who still listens to real music put this in your signature. |
Y2K GT
13.3@103
hope this helps you out.
alright thanks alot, i'll do that when i get home
do i turn the key on, then take the dials off, and put them where they should be and then push them on when the car is off?
Y2K GT
13.3@103
no take the needles of then turn your car to the on position rember do not start your car once the car is on just do like my post said and you should be fine i'v had to do it befor on my other car and it fixed it
it very important the your car is cold or the temp gauge wont set right when you set the speedo and tach hold the tip of the needle on the little black bar then put the other end of the needle on so it doesnt move on you once you start the car everything should be as close to normel as factory it may be off butt not enough to hurt anything.
alright ill try that, thanks
All Throttle with a Bottle
![]() 1996 Mustang GT with a 351 swap with Stalled C4 1997 F250 Powerstroke 1999 28' Classic Dominator Special Thanks to: Andrews Racing Transmissions & Thanks for the help: PoorManMotorSports "Just Cause its Smoking, don't mean its broken" |
yeah i read that one, wasnt really that easy.
99 GT
Just use the built in feature. Hold the reset button down for like 5-10 seconds, then start the car but still holding the button down...Then when the gauges do a gauge test let go and then press the reset button to scroll through the menus. You have your MPH and RPM then put cruise control as 30 and set the needle. Same with the RPMS. Gas fill it up then place needle at the edge of Full mark, not over. If any questions pm me.
Threads Similar to: White face gauge install
| white face gauges? | Stang6899 | V6 Mustangs | 4 | October 28th, 2007 11:19 PM |
| White Face Gauge Conversion?? | Speedstang302 | 5.0 Mustangs | 3 | September 9th, 2007 11:22 PM |
| Fuel guage stuck after white face guage install | r7r5 | 94-95 | 1 | March 2nd, 2007 09:35 AM |
| White-Face gauges? | postie | V6 Mustangs | 29 | January 6th, 2007 12:14 AM |
| White Face Gauge Install | jerb43 | Electronics | 3 | October 19th, 2006 05:31 PM |
