Need help on GT Axle
I got a GT axle from a 04. But the thing is it has a broken axle shaft.....since it came from a GT i figured you guys might know how to pull it out...
If you aren't first.....your last!
mm's nitrous mod
2000 mustang gt
11.79@115.83 (old set up)
buy a new axle, new aftermarket axles, or go 31 spline axles and diff.
yeah i'm goin to but how do i get this one thats broke off out of there?
mm's nitrous mod
2000 mustang gt
take off diff cover
take out cross pin push axle in a litlle bit remove c-clip take screw driver/pry bar and push the axle out from the inside that should give more than enough to grab a hold of it from the outside to pull it out.
the guy that i got the axle from said that one of my 7.5 axle shafts will fit in there...so im hoping to use that because i dont need 31 spline. the most i plan on doing to this car is a 4.2 twin turbo...and that will be years down the road so i dont think i will need 31 spline. While i'm in there im putting in 4.10 gears. Yes i know no one recommends doing it yourself..but i have a guy that has done alot of them before to help me out so i think i will be aight...
Threads Similar to: Need help on GT Axle
| I GOT MY AXLE!! | Bies08 | V6 Mustangs | 21 | July 9th, 2007 07:01 PM |
| Axle Girdle | Blackblurr_00GT | 99-04 | 5 | June 27th, 2007 09:58 AM |
| axle questions | mustangrebuilder | Classic Mustangs | 1 | March 20th, 2007 05:56 AM |
| Where to buy an axle??? Do I need one??? | dannygraves | V6 Mustangs | 4 | February 2nd, 2007 02:41 PM |
| 05 v6 axle ? | meogge | V6 Mustangs | 1 | December 3rd, 2006 07:09 PM |
