04 COBRA, 01 BULLITT
x pipe installed, no more power I just installed a bbk o/r x pipe on my 01 bullitt and now the car feels like a four cylinder, can anyone pls help???? I did not add mil elliminators because light never came on. Rest of car is stock.
48.47@ 12.58
re install it.
sounds like a leak
2004 SVT Cobra
![]() iTrader: 1 reviews
+1 ive had the same problem before on another car...probobly an exhaust leak
Garage: http://www.moddedmustangs.com/forums...e-member-9480/ 04 Cobra - STOCK for now
I didn t notice a leak but i will definetly look again..
That sucks! I felt a little more pep in my Bullitt when I installed my O/R Bassani X.
2001 Mustang SVT Cobra
so an exhaust leak will decrease performance...
I wonder if the leak on my LT's at the heads is killing me a bit.
Slow, really slow Cobra. Wanna see?![]() MM Cobra Club Member #81 "TAMPA BAY AREA CREW"
an exhaust leak can make you loose hp/power? heck if thats the case id better get my header gaskets done again thay leak like mad
I wouldn't think a leak would decrease hp. If there is something restricting flow that would definately affect hp.
![]() 2003 Mustang GT. Red HOT Bitch! Many mods to come... |
IBEATU
06 GT, 98 GT, & 93 Notch
Yes, a bad exhaust leak will KILL your horseower.
![]() 98 GT: some stuff 06 GT: more stuff 93 Notch: 4 cyl at birth, now 5.0 drivetrain and stock exterior and interior= True Sleeper Paxton/Vortech Crew Member #3 FRPP's #1 Dealer Injected Engineering BMR Suspension |
#10 | |
The George Forman of Keepers
A leak will cause some degree of loss of backpressure right? Naturally aspirated engines need back pressure. If you cut your exhaust off at the engine, your car would run like shit.
I think mines leaking somewhere because I can cover the duels and the engine stays running! Thats probably a sign that theres a good leak someplace.... Im totally guessing though. |
Shit that's a bad leak. Are you sure the exhaust is connected at all???
If your car has an exhaust leak bad enough to kill the power, you should be able to hear it. Unless your deaf. But I would def fix a exhaust manifold leak at the head. Thats alot of heat on that aluminum head. Plus if its bad enough you could burn a valve up. Then comes winter time, its not fixed sucks up a wif of cold air when you let off the throttle and shatters a valve.
1986 Mustang GT t-top time piece! |
Had car up on hoist today, no leaks, no kinks. Was told that now i need to introduce more air and fuel to compensate for the extra flow.
#16 | |
48.47@ 12.58
it shouldn't be causing the loss of power that is being claimed but a Good cai and t/b plenum set up will open his car up nicely over just the x pipe..
Are you sure you lost power? Sometimes with more sound coming out of it, it can feel like is just more sound and less power. If you know what I mean... I have heard from my tuner of people actually loosing power by doing the LT's and mid pipes with stock intake and TB/Plenum. You should definitely increase the air intake now.
yea you might be trying to move more air out then you are pulling in,with a stock config. maybe you should have gone with a catted pipe
2004 Black Mustang GtWhen I see a 5.0...I respect my elders. |
#19 | ||
Y2K GT
13.3@103
I think when you had the x-pipe installed you are felling a low end power loss and its not you losing power at all its just your lowend power got moved in to the upper rpm range so now with the x-pipe the low jerk you felt befor is a little higher up in rpms now.
Studies show that 92% of kids listen to rap. If you are one of the 8% who still listens to real music put this in your signature. |
Threads Similar to: x pipe installed, no more power
| O/R H pipe installed this weekend.... | XTCNAGT | 99-04 | 1 | September 10th, 2007 08:24 AM |
| Summit H-Pipe installed | mastershake | 99-04 | 4 | May 17th, 2007 07:46 PM |
| power installed | spaseghost | V6 Mustangs | 29 | May 2nd, 2007 09:50 PM |
| O/R H pipe installed | stanglifemike | 2005 - 2010 | 34 | March 28th, 2007 09:41 PM |
| Need HELP with those who have installed a UPR X-pipe! | rgurleyjr | 96-98 | 5 | January 21st, 2007 05:50 PM |
