bad noise...
ok so for the past, oh month or two, i've been driving around with the horrible noise in the rear. at first everyone thought it was a diff bearing (thus the rear-end rebuild) because it only happened whenever the throttle was applied... turns out it wasn't that. so the other day some friends and i go back and lift my car and check everything out. turns out my mufflers are rubbing a little on my driveshaft, i have about 1/4inch clearance between my tubing and body... anyone ever had a problem like this? btw it all started when i raced a mach 1 and took off hard off the line.
so.... suggestions on what to do? just get a new catback? what about until then? |
48.47@ 12.58
well you can either get a new cat back..
or take it to a muffler shop and see if they can refit it properly
48.47@ 12.58
dumps
Dude a muffler shop can probably just weld another hanger on the pipe and pull it away from the drive shaft. Cost I estimate $20 max. Dont try doing it in the drive way, it will be more of a pain in the ass then $20.
1986 Mustang GT t-top time piece! |
just heat them up with a torch and bend them out of the way with a long wrench or pipe
![]() 2004 GT Boosted by Vortech |
#8 | |
if you wanted Im sure someone here with a v6 might would swap you their rear bumper that has no cut outs for yours that does. Personally I think the no cut out look with no spoiler is sexy!
Threads Similar to: bad noise...
| noise | cali 5.0 | 5.0 Mustangs | 2 | July 12th, 2007 10:02 AM |
| Noise | jblood37 | 99-04 | 14 | March 19th, 2007 11:36 AM |
| 2005 auto mustang vibration noise/ rumbling noise | ozan169 | 2005 - 2010 | 4 | March 13th, 2007 05:31 PM |
| Noise | Fubar4774 | 5.0 Mustangs | 11 | February 21st, 2007 05:33 PM |
| Another noise 8( | flattusmaximus78 | General Tech | 1 | January 30th, 2007 04:11 PM |
