03 gt new clutch installed but grabbing too high/weird grabbing. - Forums at Modded Mustangs
post #1 of 10 Old September 11th, 2012, 07:32 PM Thread Starter
MMM JELLO!!!
esonu's Avatar
Well my old clutch(stock) was softer and also I think the grab spot was a little lower. Or maybe just cuz it's stiffer it seems that way. But can anyone tell me how to adjust this or fix it cuz it jerks a lil between 1-2 cuz I end up releasing the clutch a lil too early cuz of the amount of pressure required. Thanks.
2003 Mustang GT Manual
18in staggered fr500s,Mach 1 lip, mach 1 grill
esonu is offline
post #2 of 10 Old September 11th, 2012, 07:34 PM
Sheriff Metal Face
Chris951's Avatar
Pull clutch pedal up towards you with your foot while in neutral. You'll hear a click noise. Push pedal ALL the way to the floor. Repeat one or two more times until desired adjustment is achieved.
Chris951 is offline
post #3 of 10 Old September 11th, 2012, 09:21 PM
US Air Force (retired)
Eagle2000GT's Avatar
This causes the self adjust to engage. I really have no idea what clutch you installed. The self adjustment will make it the best it can be. Anything after that you will have to endure.
ProCharger P-1SC, 9 psi, STD 396/383; Uncorrected 388/375; SAE 383/370.
USAF 1969-1996: Vietnam veteran. Aircraft maintenance. ICBM Operations. Research & Development.
Eagle2000GT is offline
post #4 of 10 Old September 11th, 2012, 10:35 PM Thread Starter
MMM JELLO!!!
esonu's Avatar
I have the exedy stage 1 clutch. So I just pull it n push it all the way in a couple of times n should be fine?
esonu is offline
post #5 of 10 Old September 11th, 2012, 11:53 PM
joshdj13's Avatar
No idea what you did but i have the same and mine is just like oem
joshdj13 is offline
post #6 of 10 Old September 12th, 2012, 12:21 AM
MT0911's Avatar
iTrader: 14 reviews
Try this ^
If no luck - you'd be best off buying a new aftermarket quadrant and Fw adjuster. With those you can adjust to fit your preference.
'99 SVT Cobra - Built 4.6l, HP Blower Cams, Novi 2000 (8-Rib), RPM T-56, SRA Swap
'88 5.0 GT Hatchback - H/C/I/E
'99 C5 Corvette FRC - H/C/I/E + Suspension
'05 F150 FX4 - Stock
'02 Mustang GT - I/E, 4.10s, Suspension SOLD
MT0911 is offline
post #7 of 10 Old September 12th, 2012, 12:23 AM Thread Starter
MMM JELLO!!!
esonu's Avatar
I tried the pulling n pushing thing n it worked so I'm good now lol.
esonu is offline
post #8 of 10 Old September 12th, 2012, 12:25 AM
Sheriff Metal Face
Chris951's Avatar
Glad to hear it worked for ya
Chris951 is offline
post #9 of 10 Old September 12th, 2012, 12:42 AM
Send a message via AIM to hardhitter
Why clutch engages super low. I literally have to hit the floor with it before the car will crank up. I have pulled up on it with no result.
Vortech V2 Si
hardhitter is offline
post #10 of 10 Old September 12th, 2012, 01:34 AM Thread Starter
MMM JELLO!!!
esonu's Avatar
mine made a tick noise and it seems like it engages like stock, a inch off the floor lol
esonu is offline
Human Verification
