13" Rotors
Musclemotors.com is freakin RIPPING people off for these Cobra Big Brake upgrade kits....so Im looking for a back door because $250 for the rear is one thing...$470 for the front is ridiculous. As far as 13" slotted rotors go, I keep seeing these for sale that say 94-2004 Cobra only, and I think thats bullshit cause if you've got a 94-04 Mustang GT or V6, the rotors should fit just as well. What I think is these people sell these rotors assuming that the customer has NO idea he can buy the calipers and brake lines to go with it...Am I missing something here like spacers? wheel clearance or other hardware? My point is will ANY set of 13" slotted or cross-drilled brake rotors work on my 2001 GT?
1990 GT
you need relocations brackets to make them work.
1990 5.0 getting all fixed up for next season 2004 mustang gt 520rwhp, 491 trq sold
03 GT, 92 coupe 2.3T
![]() iTrader: 3 reviews
look in the newest isseu of mm&ff or 5.0mag. there is a big brake kit for the front for $299 or $399. thats 2 rotors, calipers, and lines. it says right on it cobra brake kit.
2003 DSG GT 5-speed full bolt on's 03 cobra irs swap 18x9/18x10.5 TF mach 5 wheels
#4 | |
Blown 03 GT
if your gonna get the calipers from the junk yard then why not get the brackets and shims as a package deal. then just get some new pads and rotors. its silly to waste all that time and money when you can get all you need from one place.
look just spend the money. go to a junkyard that has the cobra brakes and pull them. buy some ss brake hoses, rotors, and pads and be done with it.
found it. 5.0mag. august 8 06. page 12. late model restoration ad. 399.95 part number LRS-2300BL 1996-2004 cobra front brake kit.
#7 | |
Blown 03 GT
#8 | ||
coming from someone who HAS done the upgrade..
what you NEED to make it work: Cobra calipers. Cobra caliper brackets. Cobra rotors. that's it SS lines are always fun and I did do them but you don't need to. Mach1 brakes are the same thing as Cobra brakes.. you still would need everything on the list. the only difference between the 2 is one caliper would say Cobra and the other has a running pony and is red. any other questions?
![]() iTrader: 1 reviews
brakes arent cheap and if youre one of those people who expect to get a full brake set including 4 calipers and rotors then you might as well go buy a taurus or a cavalier or something.
#11 | |
11.21@123 -150 shot
ok sooory.. the red paint is an option on the machs
#13 | |
11.21@123 -150 shot
i stand corrected
![]() btw .. Incorrect *
#15 | |
11.21@123 -150 shot
go to buyfordracing.com. i bought the bullit 13" brake kit (exactly the same as the cobra kit) for $369. it showed up quick and me and a friend put em on about 40 mins. they work amazing and look great too. i shopped around and could only find the same kit for $450 or so til i saw it for $369 and jumped on it. 13in rotors, cobra calipers, and stainless steel brake lines...
2002 Mustang GT Bilsteins, H&R race, MM CC plates Cobra brakes, O/R x, mac catback, CAI, tri-ax |
Since a few of you guys did this, I just got the kit and Im gonna install it this saturday. They're two 13" Cross-drilled rotors with the big dual piston front brake calipers and the SS brake lines. Can I manage to swap those brake lines out without losing too much fluid? Should I just empty the fluid and refill when Im done? Also, somebody told me to lube the rotor to avoid squeeking with the brake pads...but I didnt do that when I replaced my rear brakes two weeks ago and I have'nt heard a squeek yet. And do I need those stock dust sheilds with the kit or can I get rid of them?
#18 | |
One Man Wolf Pack
![]() ΜΟΛΩΝ ΛΑΒΕ
You can get a kit like the one UNFStang is talking about on ebay.
Kit includes: * 2 Dual piston front calipers painted red with the running pony logo * 2 Rear single-piston calipers painted red * 2 13" Cobra front rotors * 2 11.65" Cobra rear rotors * 2 Improved strength front brake hoses * 2 Front caliper mounting brackets * 2 Rear caliper mounting brackets * 2 Rear moan braces * 2 Rear dust shields * Rear dust shield bolts * Front brake pads * Rear brake pads
Boost gets you laid
stay away from the cheap shit. the previous owner of my car put les schwab rotors, brake pads, and struts on the car about 1000 miles before i bought it. let me tell you, that stuff is GARBAGE. the rotors were warped within 3000 miles, the brake pads leave TONS of dust on my wheels, and the struts have no slot to put a screwdriver in so its a pain to get them off. just spend the extra few bucks and get good stuff, you will be better off.
![]() '01 GT. Just a couple Bolt-ons. 0rwhp 0rwtq. Epic Turbo build in progress 2003 Rubicon (wheelin rig) 2008 Silverado 4x4 (towin rig/road queen) 2009 KTM 450 XC-W (Brap Brap!) |
Threads Similar to: 13" Rotors
| new rotors.... | 01silversnake | 99-04 | 15 | October 9th, 2007 05:18 PM |
| Brake rotors | Stangzilla | 5.0 Mustangs | 5 | May 8th, 2007 10:59 PM |
| "13 inch rotors | auburntiger7231 | 99-04 | 8 | May 8th, 2007 06:01 PM |
| rotors | droppedbass87 | 96-98 | 5 | December 18th, 2006 09:33 AM |
