Seafoam
Old July 15th, 2007, 10:18 PM   #1
mustangmanic's Avatar
13.334 @ 106.27 w/2.01 60'
mustangmanic will become famous soon enough
Send a message via AIM to mustangmanic
Seafoam
What is it? What does it do? Where can i get it? how do you use it?
Old July 15th, 2007, 10:20 PM   #2
energiesource's Avatar
energiesource is on a distinguished road
Its basically an engine/injector cleaner.
Cleans all the carbon out of your engine and your injectors
You can get it basically any auto place.
And you just suck 1/2 of it through the vacuum hose while its running and put the rest in the gas tank. 5 mins later, watch the smoke show
Old July 15th, 2007, 10:32 PM   #3
Blk01ponyGT's Avatar
2004 SVT Cobra
Blk01ponyGT is on a distinguished road
is it really worth while? how often should you do it?
Garage: http://www.moddedmustangs.com/forums...e-member-9480/
04 Cobra - STOCK for now
Old July 15th, 2007, 10:35 PM   #4
Well I noticed a difference on mine, it was the first time i did it, so id say every 8-10k is only practical.
Old July 15th, 2007, 10:38 PM   #5
04GTAMPA's Avatar
2001 Mustang SVT Cobra
04GTAMPA will become famous soon enough
It's definitely worth it. I have used it a number of times on my cars and it really works great. The more smoke, the dirtier it is, so if it smokes too much, you might want to repeat the process.
I can't think of the line I feed it through, but someone here will tell you for sure. Might be the brake booster...
Slow, really slow Cobra. Wanna see?
MM Cobra Club Member #81
"TAMPA BAY AREA CREW"
Old July 15th, 2007, 10:49 PM   #6
I did it through one of the vacuum lines, on the passenger side closer to the firewall there was a rubber hose with a connecter and i just pulled the connector apart and sucked it through
Old July 15th, 2007, 11:20 PM   #7
do you have to do it through a vac line? i thought you could put some into the open throttle while someone regulates the engine rev, then pour the rest into the throttle and some in the oil and then let you car sit for 5 min (while off) then start it back up again and rev it and everything until there isnt any smoke, then change the oil... isnt that right?
Old July 15th, 2007, 11:25 PM   #8
i think pouring it into your oil would be a very bad idea. i think it just goes through intake parts.
Old July 15th, 2007, 11:36 PM   #9
beheivjer's Avatar
beheivjer is on a distinguished road
vac is the best way to do it.
1969 Early Bronco 3.5" lift 37" swampers
1969 Early Bronco 2" lift half cab
1979 2.3t Cobra
1997 Black Cobra
http://www.cardomain.com/ride/680999
http://www.myspace.com/beheivjer
Old July 15th, 2007, 11:37 PM   #10
Yeah.. i'll take ur word for it lol. When i heard that i was kinda skeptical about that too.. which vac line tho...
Old July 15th, 2007, 11:39 PM   #11
i followed this
basically anyway
http://youtube.com/watch?v=z3dhdoHAcaw
Old July 16th, 2007, 12:11 AM   #12
Proud American
MustangMatt96GT's Avatar
Its fine to put it in your oil. And I would try the PCV valve on the valve covers. I have yet to do the vaccum part of the seafoam because I had a leaky spot and it wouldnt work on my manifold. It has since been replaced with a PI mainfold!
RIP Travis Billings
Special Thanks to:
Andrews Racing Transmissions
Baseline Suspensions
25.3 SFI Chassis Build
Never Lift Racecars
Old July 16th, 2007, 12:34 AM   #13
99spaded is on a distinguished road
Is there any long term effects??..
Old July 16th, 2007, 01:28 AM   #14
01GT is on a distinguished road
its actually really good for your motor in the oil... pour half a bottle in, run the car for a minute or two, rev it up to splash the oil around...then wait 5-10 minutes and change your oil. it breaks down all the sludge that builds up
Don't buy from this guy: 1fstmach1
Old July 16th, 2007, 10:08 AM   #15
ok well to put it up ur vac line does ur car need to be on?
Old July 16th, 2007, 02:09 PM   #16
04GTAMPA's Avatar
If you read the directions it will say YES, the car must be running. It needs to literally SUCK the seafoam into the engine. Now, try to keep a rhythm so you don't choke it and stalls on you. After that, shut it off and wait 5 minutes, then start it and enjoy the special effects. Rev a few times then drive it like you stole it, that's when the real cleaning takes effect.
Old July 16th, 2007, 03:39 PM   #17
coffinator6's Avatar
03 GT, 92 coupe 2.3T
coffinator6 will become famous soon enough
read the can and follow the instructions EXACTLY. I have poured it in my fuel and oil. as well as suckes some into my vac line. My car produced VERY little smoke especially for 95k miles.
2003 DSG GT 5-speed
full bolt on's
03 cobra irs swap
18x9/18x10.5 TF mach 5 wheels
Old July 16th, 2007, 09:05 PM   #18
i just did the seafoam through the pcv vac... followed instructions (1/2 pint, turned off car, waited 5 min)... when i started it, no smoke or anything, i even took it out for a spin redlining it and still no smoke, is this bad?
Old July 16th, 2007, 09:20 PM   #19
|TH|BLaCkStAnG is on a distinguished road
I wouldnt redline it lol...not good for any car. But I guess your car is really freaking clean if you did it right.
Old July 16th, 2007, 09:41 PM   #20
redline as in reved it to 5800 or wherever the redline starts, not actually reved it until it hurt it
Threads Similar to: Seafoam
Seafoam? MustangMatt96GT The Clubhouse 21 October 20th, 2007 04:30 PM
how do u seafoam? ricerraper33 V6 Mustangs 11 October 8th, 2007 08:19 PM
seafoam SilverGT04 99-04 11 September 12th, 2007 01:48 PM
seafoam... 02ponypackage V6 Mustangs 51 August 7th, 2007 09:35 PM
how much seafoam? energiesource 99-04 3 June 21st, 2007 03:48 PM
