FOCKING 3650
Posted this problem a while back and then it seemed to have gone away. Now its back with a vengance. My reverse is so freaking hard to shift into. Has anyone else had this problem with their 3650? I'm scared to take it to ford lol cause I'm not sure if my warranty is voided. Any help or solutions are appreciated
bad syncros or linkage ... the t-3650 sucks.
11.21@123 -150 shot
![]() iTrader: 1 reviews
The 3650 is notorius for bad synchros. This shouldn't cause a problem with reverse though. You may want to try some Royal Purple or other synthetic fluid which may help some.
To get mine into reverse some times I have to push over and double clutch it to get it just right and slide it in. Hmmm, now that just about sounded x rated.
Billy Weston
are you putting it in 1st before you go to reverse? This should be done every time you put it is reverse. There is a reverse lockout on the 3650s.
![]() TT Build in progress....... Need work done to your car for a great price in Hampton Roads? Shoot me a PM. |
never heard of that...ill try it. thanks
2004 Mach1
Mines a bitch to get into gear too sometimes
the problem is a lot more prevelant in 99-02 1/2 cars. even with over 500HP at the wheels my 3650 is holding up beautifully.
#8 | |
![]() 2004 GT Boosted by Vortech |
yea second is starting to get rough in mine:-(
2004 Black Mustang GtWhen I see a 5.0...I respect my elders. |
03 GT, 92 coupe 2.3T
![]() iTrader: 3 reviews
the reason reverse is hard to get into is because its NOT syncronized. With that said. the reason you shift into first is to get the gears aligned somewhat because reverse uses first gear to to duvert power to the reverse gear shaft.
oh and mine is going down hill fast.
2003 DSG GT 5-speed full bolt on's 03 cobra irs swap 18x9/18x10.5 TF mach 5 wheels
#11 | |
Features: * Center Distance - 85 mm * Five-speed transmission with overdrive * Two-wheel drive * Advanced synchronizer design * Optimized multi-rail shift linkage * Improved shifter design * Constant mesh, synchronized reverse * End-load design with integral clutch housing The earlier tremec's didn't have synchronized reverse but the 3650 does
Billy Weston
There is a reverse lockout it says it on the shifter tag when it comes brand new from the factory......
just went for a drive brought my bitch some lunch. tried the first gear thing...worked awesome. thanks
#14 | |
still doesn't always work... sometimes you just have to jam that shit into reverse, sometimes you have to let the clutch out an inch or 2 and it'll grind a little into reverse too...
#15 | ||
Billy Weston
Threads Similar to: FOCKING 3650
| 3650 in 99gt | superdave | 99-04 | 0 | February 26th, 2007 05:39 PM |
| 3650...how much will it take? | StuTheMusicEngineer | 99-04 | 1 | December 17th, 2006 05:34 PM |
| shifter for 3650... | WVSNS& | 99-04 | 9 | December 13th, 2006 11:39 AM |
| Help with the Tremec TR 3650( PLEASE) | H82LOSE | 99-04 | 1 | July 1st, 2006 06:16 PM |
| going with a 3650 instead of t-45 Q's | JRuckas | 99-04 | 4 | September 9th, 2005 09:39 AM |
