"lifter" tick causes what damage? - Forums at Modded Mustangs
post #1 of 11 Old November 15th, 2012, 11:09 PM Thread Starter
I think I've got a ticking "lifter" that is rearing its head now that it's cold out.
Running the motor hard with this condition, what damage would it/could it cause to the engine?
MM Bracket Racing Crew Member #5
saxmanJJ is offline
post #2 of 11 Old November 15th, 2012, 11:11 PM
Asian Persuasion
iRoush's Avatar
you could potentially collapse a lifter and if that happens, the follower could fall out causing PTV contact.
BTM AutoSport - Like us on Facebook! - Follow us on Instagram!
2014 SCCA National Tour Champion
2014 SCCA Regional Champion
#99 '99 Roush Stage II - SU
'92 Mazda Miata
iRoush is offline
post #3 of 11 Old November 15th, 2012, 11:12 PM
07gtS197's Avatar
iTrader: 5 reviews
Also if u have ticking lifters that could mean u have an oiling problem
Sent from my iPhone using AutoGuide.com Free App
07 GT Tungsten Gray
02 GT Mineral Gray
98 Crown Vic P71
07gtS197 is offline
post #4 of 11 Old November 16th, 2012, 12:15 AM
US Air Force (retired)
Eagle2000GT's Avatar
A hydraulic lifter that ticks during a cold start and then stops after the engine is warmed up is loosing its pressure when the car is turned off. Because of this that rocker arm has too much slap causing the tick. I drove a truck five years with a ticking lifter. It was still running good when I got rid of it.
What oil are you running? If you go to an oil that flows better during a cold start such as 0w20 or 0w30 the lifter will pump up faster.
ProCharger P-1SC, 9 psi, STD 396/383; Uncorrected 388/375; SAE 383/370.
USAF 1969-1996: Vietnam veteran. Aircraft maintenance. ICBM Operations. Research & Development.
Eagle2000GT is offline
post #5 of 11 Old November 16th, 2012, 12:30 AM
Lift-O's Avatar
What eagle said. Mine does it too, just make sure the motor is warm before you go wot.
-Full Bolt On's-Tuned-Built 4.10 Rear by Carl Wzorek-Sport Lite Big n Littles-BFG 275/50/15 Drag Radials-
Lift-O is offline
post #6 of 11 Old November 16th, 2012, 01:59 PM Thread Starter
Right now I have 70 dollars worth (LOL!!!) of pretty fresh Royal Purple 5w30 in the motor, so I'm not going to change it out for 0w30 just yet.
BTW, since I mostly use the car for racing, I use the 30 weight...
How many hours of a job should it be to replace all the lifters on the passenger side head?
saxmanJJ is offline
post #7 of 11 Old November 16th, 2012, 03:25 PM
07gtS197's Avatar
iTrader: 5 reviews
If u are going to replace your lifters replace all of them. It took me a couple hours doing all of the myself. Do youself a favor and buy the valve spring compressor and dont get it stuck in the head lol
07 GT Tungsten Gray
02 GT Mineral Gray
98 Crown Vic P71
07gtS197 is offline
post #8 of 11 Old November 17th, 2012, 01:35 AM Thread Starter
Thanks for the info.
I had a bad lifter in my driver's side head and had all those replaced when I was putting my forged motor together. Now about 5000 miles later I think I've got one going bad on the passenger side. I only have about 55000 miles on the car, but I race it pretty hard.
Should I put some heavier valve springs in at the same time (doing both heads obviously)??? I've got new stock valve springs, using Comp 262 cams.
I wind the motor out to 6500 rpms at the dragstrip and would like to rev it out a touch more.
saxmanJJ is offline
post #9 of 11 Old November 17th, 2012, 01:49 AM
07gtS197's Avatar
iTrader: 5 reviews
With any cam it would be smart get beehive springs just to be safe
07 GT Tungsten Gray
02 GT Mineral Gray
98 Crown Vic P71
07gtS197 is offline
post #10 of 11 Old November 17th, 2012, 09:46 AM
I had a slight ticking noise on startup, then the idler pulley started whining. When I changed it the tick was gone.
Sent from my LG-E970 using AutoGuide.Com Free App
Cdbformula is offline
post #11 of 11 Old November 17th, 2012, 11:19 AM
Moderator
SSG Pate's Avatar
iTrader: 9 reviews
Many of us have ran a car with a lifting ticker, but since the lifter is not fully pumping up then there is always the chance something could happen. If your changing cams or on a new motor do not pump up the lifters cause this can cause a valve to stay open during the starting cycle resulting in low compression on one or more cylinders which is detrimental to the break in on a new motor or Camshaft. I would suggest replacing all your lifters.
Convertible Crew Founder
Proud Iraq and Afghanistan War veteran
700 RWHP Club Member #1
Vortech T Trim @18 PSI
604 RWHP 516 FT LB
11.50@121.77@ 523RWHP
Precision Turbo 7675 CEA @ 20 PSI
738 RWHP 691 FT LB
10.9 @ 131 MPH
SSG Pate is online now
Human Verification
