exhaust leak?
Old July 18th, 2007, 09:07 PM   #1
xedubx's Avatar
xedubx is on a distinguished road
exhaust leak?
i put a mac prochamber on my 03 gt and after the initial install it sounded great but i had a squeek under the car over bumps. i then unbolted the mid section and "moved" it around a bit and then bolted it back up. now i can hear a loud sound that sounds like, what i think is an exhaust leak, coming from i think the passenger side. is that passenger side gasket that easy to damage? would a cracked gasket really be THAT loud? how possible is it that i damaged the gasket that connects the h-pipe to the header flange? this is the only thing i can think of... has anyone had or heard of exhaust leaks like this after installing an new o/r midpipe? is this a leak or something else? just thought id ask and myabe find its something more simple that i can solve easier before i take it all apart again. (at higher rpms it gets worse and is really loud and makes my car sound like a loud ass ricer! help!)
Go Baby Go!
Old July 18th, 2007, 09:08 PM   #2
HMUSN's Avatar
iTrader: 9 reviews
def. a leak.
Old July 18th, 2007, 09:11 PM   #3
xedubx's Avatar
gasket most likey? or what?
Go Baby Go!
Old July 18th, 2007, 09:22 PM   #4
HMUSN's Avatar
iTrader: 9 reviews
i couldn't tell ya without looking myself...
go take a peak .. do a cold start.. then rev the motor to about 4k while someone is looking at the suspected area.. you will see smoke (from condinsation) come from the leak
Old July 18th, 2007, 09:53 PM   #5
Blk01ponyGT's Avatar
2004 SVT Cobra
Blk01ponyGT is on a distinguished road
i had that problem before....the gasket was burned up and caused the leak...sounds like that might be it
Garage: http://www.moddedmustangs.com/forums...e-member-9480/
04 Cobra - STOCK for now
Old July 18th, 2007, 10:02 PM   #6
04GTAMPA's Avatar
2001 Mustang SVT Cobra
04GTAMPA will become famous soon enough
another way to test is to use a funnel with a hose and pinpoint the area, or....
Like I did, I used seafoam and watched under the hood how the smoke was coming from the driver's side header/manifold area. Not to mention that it sounds like a spike sprinkler at mid morning.. Sht sht sht sht, and it gets louder with revs. If you drive with the windows up, you can hear it just enough with the rhythm of the pistons going up and down.
Slow, really slow Cobra. Wanna see?
MM Cobra Club Member #81
"TAMPA BAY AREA CREW"
Old July 19th, 2007, 12:08 AM   #7
xedubx's Avatar
thats it for sure. the sprinkler sound and its really loud. guess ima take it apart tomorrow and take a look. maybe replace the gasket either way...
Go Baby Go!
Old July 19th, 2007, 01:06 AM   #8
g0lden is on a distinguished road
Weld her up bro.
D
Old July 19th, 2007, 11:14 AM   #9
04GTAMPA's Avatar
Originally Posted by g0lden
Weld her up bro.
D
Old July 19th, 2007, 01:38 PM   #10
Zoolander
04 Cobra #2260/3768 1/820
iTrader: 5 reviews
Sounds kinda like a loud turbo with a kazoo on it doesn't it? Thats the best I can describe an exhaust leak. What I always did whenever I had exhaust leaks was have someone in the car revving it little by little to see if I could find the spot, and then tighten it down first to see if that fixed it. Always worked for me, but if it's a gasket well then I guess you know your gonna need a new one.
MM Cobra Club #18
Team Tini Racing
I don't know jack shit...
Threads Similar to: exhaust leak?
exhaust leak!?!? 95blueGT 94-95 6 October 10th, 2007 02:28 PM
exhaust leak 1998_svt_cobra 96-98 2 September 6th, 2007 01:34 PM
exhaust leak or something else? mikethetigerrr V6 Mustangs 9 July 6th, 2007 08:52 PM
exhaust leak... 232stang V6 Mustangs 7 April 1st, 2007 09:14 PM
Exhaust leak? JRubin2000 99-04 10 October 29th, 2006 01:07 AM
