2003 Mustang TSB's
Technical Service Bulletins
2003 MUSTANG - US (English) 05-18-7 WIRING - SOLDERING AND CRIMPING REPAIRS - SERVICE TIPS 05-16-11 SAFETY BELT RETRACTION SPEED 05-14-3 SQUEAK/CREAK NOISE FROM STEERING RACK WHEN TURNING 05-9-18 DISCHARGED BATTERY - CHARGING SERVICE TIPS 05-3-10 SAFETY BELT WEB STOP BUTTON SERVICE 04-24-20 LIMITED SLIP AXLE CHATTER, SHUDDER, BINDING SENSATION, OR VIBRATION DURING LOW SPEED TURNING MANEUVERS 04-24-14 GENERAL PCM PROGRAMMING PROCEDURES 04-24-5 REAR WINDOW DEFROSTER GRID/INTEGRAL ANTENNA DIAGNOSIS AND REPAIR - TERMINAL TAB REPAIR 04-24-3 LEATHER-WRAPPED STEERING WHEEL - LEATHER COMING LOOSE 04-21-6 EXHAUST LEAK - CRACKED OR SEPARATED RIGHT SIDE EXHAUST PIPE - 3.8L AND 3.9L ENGINES 04-19-8 MANUAL TRANSMISSION HARD TO SHIFT INTO FIRST/REVERSE FROM A STOP 04-17-4 MALFUNCTION INDICATOR LAMP (MIL) ILLUMINATED - SYSTEM LEAN DIAGNOSTIC TROUBLE CODES (DTC'S) - SERVICE TIPS 04-16-1 ENGINE MISFIRE OR ROUGH RUNNING - COIL ON PLUG (COP) IGNITION SYSTEMS - WDS COP KIT DIAGNOSTIC TIPS 04-15-6 TR3650 MANUAL TRANSMISSION - JUMPS OUT OF GEAR 2ND AND/OR 3RD - CLASH NOISE AND/OR RASPY FEEL ON GEAR ENGAGEMENT 04-13-4 TRANSMISSION RATTLE NOISE OR DIFFICULT TO SHIFT - TREMEC T56 6 SPEED MANUAL 04-5-3 CLIMATE CONTROL - RATTLE NOISE FROM INSTRUMENT PANEL VENTS - DIFFICULT TO ADJUST NOISE - CLIMATE CONTROL - RATTLE NOISE FROM INSTRUMENT PANEL VENTS - DIFFICULT TO ADJUST 04-1-2 BODY - INTERIOR TRIM - HEADLINER SAGGING IN REAR 03-25-6 ENGINE - ROMEO BUILT 4.6L 2V - TICK NOISE FROM ENGINE - ENGINES BUILT BEFORE 9/17/2003 03-25-5 PAINT - PIN HOLES AND/OR PAINT DELAMINATION ON VEHICLE HOOD - VEHICLES BUILT 6/1/2001 THROUGH 3/1/2003 ONLY 03-24-3 TRANSMISSION - AUTOMATIC TRANSMISSION GEAR SELECTOR LEVER STUCK IN PARK, UNABLE TO SHIFT INTO PARK - OVERDRIVE FUNCTION INOPERATIVE 03-23-2 BODY - MIRROR - EXTERIOR MIRROR GLASS AND MOTOR REPLACEMENT - SERVICE TIPS 03-22-1 BODY - NOISE - HOOD SCOOP (SHAKER) RATTLE NOISE ENGINE - NOISE - HOOD SCOOP (SHAKER) RATTLE NOISE NOISE - HOOD SCOOP (SHAKER) RATTLE NOISE 03-20-3 DRIVEABILITY - MALFUNCTION INDICATOR LAMP (MIL) ILLUMINATED WITH DTC'S P0442, P0455, P0456, P0457, P1442 OR CHECK FUEL CAP LAMP ILLUMINATED WITH DTC P0457 03-18-1 ELECTRICAL - REMOTE KEYLESS ENTRY (RKE) - SERVICE TIPS 03-14-8 TRANSMISSION - NEW TRANSMISSION COOLER FLUSHER - SERVICE TIPS 03-11-4 ENGINE - MUSTANG COBRA - TICK NOISE FROM ENGINE - COBRA VEHICLES EQUIPPED WITH ENGINES BUILT BEFORE 11/1/2002 ONLY 03-10-1 PAINT - PLASTIC BUMPER/FASCIA PARTS - PREPARATION PROCEDURES - SERVICE TIPS 03-9-5 SUSPENSION - CLUNK OR POP NOISE FROM REAR SUSPENSION - MUSTANG COBRA ONLY - SERVICE TIPS NOISE - CLUNK OR POP NOISE FROM REAR SUSPENSION - MUSTANG COBRA ONLY - SERVICE TIPS 03-8-3 ENGINE - ENGINE OIL LEVEL INDICATOR MARKINGS - REPORTS OF LOW OIL LEVELS 03-3-6 SUSPENSION - DRIFT OR PULL TO RIGHT OR LEFT - MUSTANG COBRA MODELS ONLY 03-1-5 TRIM - PASSENGER SEAT RUBS AGAINST DOOR PANEL 02-23-7 COOLING SYSTEM - MOTORCRAFT PREMIUM GOLD ENGINE COOLANT - SERVICE TIPS 02-23-3 DRIVEABILITY - FUEL PRESSURE RELIEF VALVE (SCHRADER VALVE) DISCONTINUED ENGINE - 3.0L/3.8L/4.6L - FUEL PRESSURE RELIEF VALVE (SCHRADER VALVE) DISCONTINUED 02-22-1 DRIVEABILITY - SURGE/ROLLING IDLE - GEAR DRIVEN SYNCHRONIZERS - INCORRECT INSTALLATION - CAMSHAFT POSITION SYNCHRONIZER (CMP) INSTALLATION TOOL CORRECT APPLICATION ENGINE - GEAR DRIVEN SYNCHRONIZERS - INCORRECT INSTALLATION - CAMSHAFT POSITION SYNCHRONIZER (CMP) INSTALLATION TOOL CORRECT APPLICATION 02-21-13 ENGINE - STRAIGHTEDGE PROCEDURE FOR CHECKING CYLINDER HEAD AND BLOCK FLATNESS 02-20-8 CLIMATE CONTROL - A/C SERVICE TECH TIPS 02-17-8 NOISE - WINDNOISE FROM THE "A" PILLAR AREA 02-17-6 LAMP - BRAKE - INADVERTENT DISABLING OF BRAKE SHIFT INTERLOCK 02-16-7 BODY - PAINT - APPROVED PAINT MATERIALS FOR WARRANTY REPAIRS
91 LX, 5spd. Ex:Toyota/Ford tech Marine Machinery Technician, Department of Defense.
2003 mustang gt
slow
Lol I have quite a few of these issues...
2003 Mustang GT
8.26@83.06 (1/8)
Holy old post, Batman!
![]() SLP :: SCT :: Eaton :: Maximum Motorsports :: Baseline Suspensions :: Strange Engineering MM Bracket Racing Crew BAMA Performance Drag Team #1 Project Thread :: YouTube Channel |
Threads Similar to: 2003 Mustang TSB's
| 2007 Mustang TSB's | Casper98GT | 2005 - 2010 | 38 | March 14th, 2009 10:30 PM |
| 2000 Mustang TSB's and RECALLS | Casper98GT | 99-04 | 12 | January 23rd, 2009 12:54 AM |
| 2006 Mustang TSB's | Casper98GT | 2005 - 2010 | 29 | March 9th, 2008 03:30 PM |
| 2004 Mustang TSB's | Casper98GT | 99-04 | 2 | August 19th, 2006 04:22 PM |
| 1999 Mustang TSB's and RECALLS | Casper98GT | 99-04 | 0 | September 5th, 2005 11:23 PM |
