![]() iTrader: 1 reviews
Power window question
So its not that important but its a cheap little project, or atleast i hope anyways.
I was wondering how a person would go about making both windows go down by pressing the button once like the driver side, would it be the motor, a switch, relay, what? I was in one of the newer mustangs and i was kind of intrigued by what simple of a thing it is, but it helps. so if anyone can help me, thanks
Achieving more N/A power!
Here ya go...
http://www.webelectricproducts.com/ Click on "One Touch Windows" on the left side, then choose the lower Mustang (not the 2005+ one obviously). GREAT product. I installed one in my passenger door last weekend, and love it. Ha, I have to force myself to remember that my passenger window is only one touch now, I was so used to holding it down.
Brendan '99 Mustang GT [ 318 rwhp N/A ] - SOLD ( )'04 F150 XLT SuperCab
Alright I'll take a look into it, and you just need to replace the switch? or do you have to take the whole door panel off? and you'd need two, as in one for the driver passenger control and one for the passenger control?
You only need one, it gets installed in the passenger door, and all you need to take off is the piece that holds the window switches (the part you grab when you pull the door shut).
It is a Ford module that you wire into the switch. It's very easy and comes with instructions and everything you need to do it minus the tools (wire cutter, stripper, pliers, crimper). Definitely worth the $31.
oh yeah this is what i have been waiting for, so once you install it on the passenger side the driver side button will also put the passenger side down all the way??.... whoa that was a lil confusing... what i meant was on the driver door the passenger side button will roll the window all the way down??..
...Not to intrude on your question man but since we're here talking about this I figured it was a good point to ask...The driver-door's Passenger-Side window switch rolls it down, but not back up. Its not a motor problem cause done from the Passenger Side door it works fine, I might be able to tell by just taking the cover off but does anyone know if this is just a crappy wiring problem? I have a 2001 GT, its got 110,000 miles on it and the gaps are shrinking between episodes of minor repair and replacements...Thanks.
#7 | |
#8 | |
Ok so all i need is one and i can install it on the passenger side only??!! And then from the drivers side both switches will be one touch right?
#10 | |
SWEET!! thanks man!!
#12 | |
#13 | |
Re: Power window question
Ok well i just ordered mine!! Excited to see this work!! Was the install easy??..
its cool how they roll down and up just a bit when you open and close the door
What??... do they really??..
yeah, to make a better seal i guess its a pretty cool feature but its the little shit that gets to me
Yeah well i used to work for Mercedes and that was one of their features also!! Does it to it for both doors??..
Did you only buy one? |
#19 | |
Don't use these: Wire Tap-In Squeeze Connectors http://www.radioshack.com/product/in...entPage=family ![]() Use these: Screw-On Wire Connectors http://www.radioshack.com/product/in...entPage=family
#20 | |
Threads Similar to: Power window question
| Power Window problem..... | lwhitetrash88l | V6 Mustangs | 1 | September 24th, 2007 03:32 PM |
| Power Window Problem | V6er | General Tech | 1 | August 6th, 2007 04:51 PM |
| power window problem (pulling hair out of my head) | zmykk | General Tech | 4 | August 1st, 2007 08:34 AM |
| Power Window Problems | Replica R | Audio/Video | 4 | October 13th, 2006 12:51 AM |
| Which wire to control power window or locks | TWallace | 5.0 Mustangs | 2 | May 2nd, 2006 11:01 AM |
