LinkBack (9) | Thread Tools |
#1
1999 Mustang TSB's and RECALLS
Field Service Actions (Recalls)
1999 Mustang 01S15 Safety Recall - Certain 1999 and 2000 Model Year SVT Mustang Cobra and Certain 2000 Model Year SVT Mustang Cobra R Vehicles - Rear Knuckle Replacement Published 04/2001 00S37 Safety Recall - Certain 1994 - 2001 Model Year Mustang Vehicles Equipped With Manual Transmission - Park Brake Control Assembly Modification Published 10/2000 99B27 Owner Notification Program - All 1999 Mustang Cobra Vehicles - Lack of Performance Published 12/1999 99S26 Safety Recall - DEMONSTRATION/DELIVERY HOLD: Certain 1999 MY Taurus and Sable, 1999-2000 MY Mustang and 2000 MY Continental Vehicles - Safety Belt Emergency Locking Retractor (ELR) / Automatic Locking Retractor (ALR) Switching Mechanism Published 10/1999 99E04 Emissions Recall - Certain 1999 Mustang GT Vehicles with 4.6L 2-Valve Engines - Transmission Control Wiring Harness Rerouting Published 08/1999 99S09 Safety Recall - Speed Control Cable Replacement Published 03/1999 Technical Service Bulletins 1999 MUSTANG - US (English) 05-9-18 DISCHARGED BATTERY - CHARGING SERVICE TIPS 04-24-14 GENERAL PCM PROGRAMMING PROCEDURES 04-24-5 REAR WINDOW DEFROSTER GRID/INTEGRAL ANTENNA DIAGNOSIS AND REPAIR - TERMINAL TAB REPAIR 04-21-6 EXHAUST LEAK - CRACKED OR SEPARATED RIGHT SIDE EXHAUST PIPE - 3.8L AND 3.9L ENGINES 04-19-8 MANUAL TRANSMISSION HARD TO SHIFT INTO FIRST/REVERSE FROM A STOP 04-16-1 ENGINE MISFIRE OR ROUGH RUNNING - COIL ON PLUG (COP) IGNITION SYSTEMS - WDS COP KIT DIAGNOSTIC TIPS 03-23-2 BODY - MIRROR - EXTERIOR MIRROR GLASS AND MOTOR REPLACEMENT - SERVICE TIPS 03-20-3 DRIVEABILITY - MALFUNCTION INDICATOR LAMP (MIL) ILLUMINATED WITH DTC'S P0442, P0455, P0456, P0457, P1442 OR CHECK FUEL CAP LAMP ILLUMINATED WITH DTC P0457 03-18-1 ELECTRICAL - REMOTE KEYLESS ENTRY (RKE) - SERVICE TIPS 03-9-5 SUSPENSION - CLUNK OR POP NOISE FROM REAR SUSPENSION - MUSTANG COBRA ONLY - SERVICE TIPS NOISE - CLUNK OR POP NOISE FROM REAR SUSPENSION - MUSTANG COBRA ONLY - SERVICE TIPS 03-6-2 ENGINE - CYLINDER HEAD DECK LEAK - 4.6 AND 5.4L ENGINES - NEW "SERVICE-ONLY" GASKET AND CYLINDER HEAD KITS AVAILABILITY 03-1-5 TRIM - PASSENGER SEAT RUBS AGAINST DOOR PANEL 02-23-4 DIAGNOSTIC TROUBLE CODE (DTC) - P1635 AND/OR P1639 PRESENT AFTER POWERTRAIN CONTROL MODULE (PCM) OR INSTRUMENT CLUSTER REPLACEMENT - GASOLINE ENGINE VEHICLES ONLY LAMP - 4X4 LAMP ILLUMINATED AFTER POWERTRAIN CONTROL MODULE (PCM) OR INSTRUMENT CLUSTER REPLACEMENT - GASOLINE ENGINE VEHICLES ONLY SPEEDOMETER - INACCURATE AND/OR INOPERATIVE AFTER POWERTRAIN CONTROL MODULE (PCM) OR INSTRUMENT CLUSTER REPLACEMENT - GASOLINE ENGINE VEHICLES ONLY 02-22-1 DRIVEABILITY - SURGE/ROLLING IDLE - GEAR DRIVEN SYNCHRONIZERS - INCORRECT INSTALLATION - CAMSHAFT POSITION SYNCHRONIZER (CMP) INSTALLATION TOOL CORRECT APPLICATION ENGINE - GEAR DRIVEN SYNCHRONIZERS - INCORRECT INSTALLATION - CAMSHAFT POSITION SYNCHRONIZER (CMP) INSTALLATION TOOL CORRECT APPLICATION 02-21-13 ENGINE - STRAIGHTEDGE PROCEDURE FOR CHECKING CYLINDER HEAD AND BLOCK FLATNESS 02-20-8 CLIMATE CONTROL - A/C SERVICE TECH TIPS 02-17-6 LAMP - BRAKE - INADVERTENT DISABLING OF BRAKE SHIFT INTERLOCK 02-11-4 ENGINE - NEW GASKET REMOVER/CLEANER AND SERVICE TIPS FOR ALUMINUM HEADS AND BLOCKS 02-2-2 COOLANT - COOLANT SEEPAGE AT INTAKE MANIFOLD CROSS-OVER - VEHICLES EQUIPPED WITH 4.6L 2V ENGINE ONLY ENGINE - 4.6L 2V - COOLANT SEEPAGE AT INTAKE MANIFOLD CROSS-OVER 02-1-9 ENGINE - ENGINE OIL - RECOMMENDED APPLICATIONS FOR SAE 5W-20 AND SAE 5W-30 MOTOR OILS - GASOLINE AND FLEXIBLE FUEL VEHICLES ONLY 01-24-6 ENGINE - ENGINE OIL SYSTEM PRIMING PROCEDURES - SERVICE TIPS 01-23-6 ENGINE COOLANT - PROPYLENE GLYCOL - FORD MOTOR COMPANY POSITION ON ENGINE COOLANTS MADE FROM PROPYLENE GLYCOL ENGINE COOLANT - PROPYLENE GLYCOL-BASED - FORD MOTOR COMPANY POSITION ON PROPYLENE GLYCOL-BASED ENGINE COOLANTS 01-23-5 TRANSMISSION - T-45 MANUAL TRANSMISSION - STUCK IN REVERSE - DIFFICULT TO SHIFT INTO REVERSE - POPS OUT OF REVERSE 01-21-13 DRIVEABILITY - DIAGNOSTIC TROUBLE CODES (DTC) P0500, P1502 AND/OR U1039 CONTINENTAL MODELS ONLY - STICKING OR BINDING IGNITION LOCK CYLINDER - HIGH EFFORT WHEN TURNING IGNITION SWITCH ELECTRICAL - STICKING OR BINDING IGNITION LOCK CYLINDER - HIGH EFFORT WHEN TURNING IGNITION SWITCH 01-17-4 BODY - HOOD SCOOP LOOSE OR DETACHED FROM HOOD 01-15-6 CLIMATE CONTROL - REPEAT HEATER CORE FAILURE COOLING SYSTEM - REPEAT HEATER CORE FAILURE 01-13-7 NOISE - "CLUNK" NOISE HEARD ON 2-1 DOWNSHIFT VEHICLES EQUIPPED WITH 4R70W AUTOMATIC TRANSMISSION TRANSMISSION - 4R70W - "CLUNK" NOISE HEARD FROM TRANSMISSION ON 2-1 DOWNSHIFT 01-10-12 WIRING - WIRE HARNESS TERMINAL REPAIR KIT AND WIRE SPLICE PROCEDURE 01-9-7 DRIVEABILITY - HO2S (HEATED OXYGEN SENSOR), CATALYST, AND FUEL SYSTEM MONITORS - SERVICE TIPS - OBD II VEHICLES ONLY 01-8-3 VIBRATION - FELT THROUGH SEAT, FLOOR AND/OR STEERING WHEEL AT HIGHWAY SPEEDS WHILE IN 4TH OR 5TH GEAR - COBRA MODEL ONLY 01-7-1 SUSPENSION - NOISE - "SQUEAK" FROM REAR SUSPENSION OVER BUMPS - COBRA MODELS ONLY NOISE - "SQUEAK" FROM REAR SUSPENSION OVER BUMPS - COBRA MODELS ONLY 01-6-2 PASSIVE ANTI THEFT SYSTEM (PATS) - DIAGNOSTIC SERVICE TIPS 01-1-9 DRIVEABILITY - HESITATION WHEN COLD - WITH NO DIAGNOSTIC TROUBLE CODES (DTC) PRESENT - VEHICLES EQUIPPED WITH 4.6L ENGINE AND MANUAL TRANSMISSION 00-23-10 TRANSMISSION - FLUID IN-LINE FILTER KIT - REPEAT REPAIRS OF TRANSMISSION - SERVICE TIPS 00-21-2 HOOD - HOOD REQUIRES EXCESSIVE EFFORT TO CLOSE - SERVICE TIPS 00-18-3 COOLING SYSTEM - COOLANT LEAK FROM PASSENGER SIDE OF INTAKE MANIFOLD AT REAR CORNER OF HEAD - VEHICLES BUILT FROM 7/1/1998 THROUGH 6/30/2000 - VEHICLES WITH 4.6L 2V OR 5.4L 2V ENGINE ENGINE - 4.6L 2V OR 5.4L 2V - COOLANT LEAK FROM PASSENGER SIDE OF INTAKE MANIFOLD AT REAR CORNER OF HEAD - VEHICLES BUILT FROM 7/1/1998 THROUGH 6/30/2000 00-9-6 WINDSHIELD WIPERS - FRONT WIPERS OPERATE WHILE SWITCH IS IN "OFF" POSITION 00-9-4 NOISE - "POPPING/CLUNKING" HEARD WHILE PERFORMING A QUICK LANE CHANGE AT HIGHWAY SPEEDS AND/OR GOING UP AN INCLINE AT LOW SPEEDS - COBRA VEHICLES ONLY (DOES NOT INCLUDE COBRA R VEHICLES) 00-9-1 LEAK - TRANSMISSION FLUID LEAKS AT RADIATOR - VEHICLES EQUIPPED WITH AUTOMATIC TRANSMISSION AND TRANSMISSION OIL COOLER IN RADIATOR END TANK 99-26-9 FUEL ECONOMY - CUSTOMER EXPECTATIONS VERSUS VEHICLE USAGE 99-24-2 LOCKS - REPLACE AND/OR REPAIR ANY LOCK COMPONENT - AVAILABILITY OF INDIVIDUAL LOCKS 99-23-4 MALFUNCTION INDICATOR LAMP (MIL) - DIAGNOSTIC TROUBLE CODES (DTCS) P0442 AND P0455 - NO DRIVEABILITY CONCERNS 99-22-6 NOISE - "POPPING" OR "OIL CANNING" NOISE FROM DRIVER'S FOOTWELL AREA 99-22-5 CONVERTIBLE TOP - IMPROPER FIT OF CONVERTIBLE TOP BOOT 99-21-8 BODY - "CREAKING" NOISE FROM LH REAR QUARTER AREA - CONVERTIBLES ONLY NOISE - "CREAKING" FROM LH REAR QUARTER AREA - CONVERTIBLES ONLY 99-19-7 LAMP - INTERMITTENT MALFUNCTION INDICATOR LAMP (MIL) ILLUMINATION - DIAGNOSTIC TROUBLE CODES (DTCS) P0741, P0750, P0755, AND P1746 MAY BE STORED IN MEMORY - VEHICLES BUILT FROM 8/1/1998 THROUGH 5/1/1999 WITH 4R70W TRANSMISSION LAMP - INTERMITTENT TRANSMISSION CONTROL INDICATOR LAMP (TCIL) ILLUMINATION - DIAGNOSTIC TROUBLE CODES (DTCS) P0741, P0750, P0755, AND P1746 MAY BE STORED IN MEMORY - VEHICLES BUILT FROM 8/1/1998 THROUGH 5/1/1999 WITH 4R70W TRANSMISSION TRANSMISSION - 4R70W - INTERMITTENT TRANSMISSION CONTROL INDICATOR LAMP (TCIL) ILLUMINATION - DIAGNOSTIC TROUBLE CODES (DTCS) P0741, P0750, P0755, AND P1746 MAY BE STORED IN MEMORY - VEHICLES BUILT FROM 8/1/1998 THROUGH 5/1/1999 99-18-5 TRANSMISSION CONTROL INDICATOR LAMP (TCIL) - TCIL ILLUMINATED WITH DIAGNOSTIC TROUBLE CODE (DTC) P0782 STORED IN MEMORY - VEHICLES BUILT BETWEEN 3/15/1997 AND 12/31/1998 AND WITH 4R70W TRANSMISSION TRANSMISSION - 4R70W - DELAYED OR NO 2-3 UPSHIFT - VEHICLES BUILT BETWEEN 3/15/1997 AND 12/31/1998 99-15-3 INTERIOR - CUP HOLDER NOT DEEP ENOUGH TO HOLD LARGE CUPS - VEHICLES BUILT THROUGH 5/3/1999 99-14-7 CALIBRATION INFORMATION - VEHICLES BUILT THROUGH 1/29/1999 - APPLICABLE ENGINES ARE 2.0L, 2.5L, 3.0L, 3.4L, 3.8L, 4.0L, 4.2L, 4.6L, 5.0L, 5.4L, 6.8L, AND 7.3L - SERVICE TIP 99-11-1 NOISE - TSB SPECIAL FOR NOISE/VIBRATION/HARSHNESS VIBRATION - TSB SPECIAL FOR NOISE/VIBRATION/HARSHNESS 99-10-1 BODY - DUST INTRUSION INTO LUGGAGE COMPARTMENT WATER LEAK - EVIDENCE OF WATER LEAK INTO LUGGAGE COMPARTMENT NOISE - EXCESSIVE ROAD NOISE HEARD FROM REAR WHEEL AREA 99-8-15 INTERIOR TRIM - DOOR TRIM PANEL REPLACEMENT - SERVICE TIP 99-5-3 TRANSMISSION - CHECKING TRANSMISSION FLUID LEVEL COLD - SERVICE TIP 99-4-3 REPROGRAMMING POWERTRAIN CONTROL MODULES (PCMS) - OUT-OF-VEHICLE - EEC V VEHICLES ONLY 99-2-3 WATER LEAKS - WINDSHIELD SEALING - SERVICE TIP WINDSHIELD - SEALING - SERVICE TIP 98-26-2 FUEL - INFORMATION ON GASOLINE - TIPS TO RESOLVE VOLATILITY RELATED DRIVEABILITY CONCERNS 98-25-9 INTERIOR TRIM - REPAIRS TO VINYL COVERED SURFACES - SERVICE TIP 98-24-6 ELECTRICAL - NEW TERMINAL GREASE RELEASED FOR SERVICE 98-23-10 MASS AIR FLOW (MAF) - SENSOR CONTAMINATION - SERVICE TIP 98-20-10 EXHAUST SYSTEM - LOOSE CATALYST OR MUFFLER HEAT SHIELDS NOISE - "BUZZING" OR "RATTLING" - LOOSE CATALYST OR MUFFLER HEAT SHIELDS
91 LX, 5spd. Ex:Toyota/Ford tech Marine Machinery Technician, Department of Defense.
Threads Similar to: 1999 Mustang TSB's and RECALLS
| 2000 Mustang TSB's and RECALLS | Casper98GT | 99-04 | 12 | January 23rd, 2009 12:54 AM |
| 2006 Mustang TSB's | Casper98GT | 2005 - 2010 | 29 | March 9th, 2008 03:30 PM |
| 2002 Mustang TSB's And Recalls | Casper98GT | 99-04 | 9 | November 26th, 2007 07:55 PM |
| 1998 Mustang TSBs and Recalls | Casper98GT | 96-98 | 8 | October 8th, 2007 09:04 PM |
| 2001 Mustang TSB's and RECALLS | Casper98GT | 99-04 | 0 | September 5th, 2005 10:58 PM |
