Header flange bolts
Old July 27th, 2007, 09:57 PM   #1
|TH|BLaCkStAnG is on a distinguished road
Header flange bolts
I think i found the exhaust leak I was looking for. Its where the header meets the x pipe(drivers side). There seem to be stops on the flange bolts. If i unscrew the bolts will the stops come off with ease? Because i think thats what is causing my x pipe to leak.
Old July 28th, 2007, 09:35 AM   #2
Nate's4.6 is on a distinguished road
I have never seen "stops" there.
I had a leak there too but it was from the gasket. After I changed to the x-pipe I used the stock gasket again. Well the gasket has a raised area that also seals the exhuast on the inner part of the pipe and that had rotted away.
just un-bolted the two on the drive and passenger side , replace the gasket, and drive off once done.
www.fquick.com/Nates4.6
Threads Similar to: Header flange bolts
Another header flange question nolife 5.0 Mustangs 5 October 29th, 2007 10:36 PM
stg.8 locking header bolts Invictus 99-04 1 June 18th, 2007 05:07 AM
damn header bolts dr.gonzo! 5.0 Mustangs 2 April 26th, 2007 11:00 PM
could header bolts be the problem? ddashtrois 99-04 4 March 30th, 2007 09:55 PM
Stage 8 header bolts Tony_90fox General Tech 3 February 28th, 2007 03:44 AM
