2000 mustang gt
havent been to the track yet,lol
hopefully a easy fix
About a hour ago the fan that keeps the car cool turned on and hasent turned off yet. Before it wasent over heating or anything and its not over heating now. How can I fix this or any suggestions. Any help is appreciated.
You mean your driving the car or you mean its just running in the driveway with the key off? The engine fan is part of the ac/defroster circuit it will run anytime the ac or defroster is on btw.
99 Mustang GT 560rwhp on STOCK HEADS, 4.75L, Kenne Bell Mammoth 2.1, Killer Chiller @16lbs, Cobra Inlet, LFP Throttle Body, JLT High Boost CAI, CMS Stage 2 Blower Cams, HPX, 3.55s, MGW, Battery Relocation, Intercooler Tank Relocated, CF DF clutch |
2000 mustang gt
It's on while driving and its on while the car off with the key out. For about a hour now. Neither the a/c or defrosted is on
when standing front of the car top left of fan/radiator system. check the temp sensor there for the fan and also check the connector into the fan itself. See if one of the three or so wires are disconnected. the temp sensor pulls out pretty easy you can see the clips to push down
07 GT/CS manual - STOCK 88 LX automatic-SOLD 01 GT manual-UNDER CONSTRUCTION 97 GT automatic-SOLD |
2000 gt
![]() ![]() ![]() ![]() ![]() ![]() iTrader: 2 reviews
probably the CCRM in the passenger side wheel well. i think this is one of the symptoms of it going bad.
Procharged 2000 5 Speed BAB GT, built motor, blower cams, speedy dyno tune 412 hp, 450 rw tqHARDCORE CREW BRIGHT ATLANTIC BLUE CREW #1 MEMBER |
2000 mustang gt
Well it finally turned off AND it killed the battery...smh. I got jump though and after driving it for a few minutes the fan didn't come on. Silly car
Keep a close eye on that. It could be the relay control module. Hopefully cycling power to the ECM corrected it as the program does lock up occasionally. Goodluck
2000 mustang gt
What program are you talking about?
#9 | |
Engine ASPLODE!
2000 Ford Dumpster Fire
17.81@87
Unfortunately you have to replace the whole module. It's a pretty easy replacement though.
2000 mustang gt
Any price #'s? For that module?
