Discussing cams in high milage engine in the 99-04 Forum. I want to put cams in my mustang gt. Sooner or later ill end up ...
Old July 28th, 2007, 08:02 PM   #1
I want to put cams in my mustang gt. Sooner or later ill end up building a complete motor but i was wondering if its ok to put cams on a motor with 105k miles on it. I want the lope and performance that you get for them and im going to go with vt stage 1 cams or crower cams. I want to go with the biggest cam i can get without blowing the stock motor.
what you guys think?
2001 mustang gt 5 speed
Full bolt ons with 4.10 gears.
1965 Mustang
302 with 4 Barrel edelbrock 600cfm, T5 transmission, Hurst short throw shifter.
In the process of restoring it...
Old July 29th, 2007, 01:55 AM   #2
anyone?
1965 Mustang
Old July 29th, 2007, 02:26 AM   #3
Garhfer's Avatar
2004 Mustang GT Conv.
vt stage 2 cams have a real nice lope... I'd do them with valve springs and a tune and you'd be set...
2004 GT Boosted by Vortech
Old July 29th, 2007, 02:35 AM   #4
TheUNModerator!
TheUNZippee!'s Avatar
2007 Mustang GT
282 rwhp/292 rwtq
Location: I've got Rags in my bubble and I don't know what to do with it!
As far as whether or not it's ok to put new cams on a well worn engine. There are a lot of variables there. All engines break in & wear differently, obviously, which is why some engines run forever, and why some pop when they shouldn't. If you put new cams up top, you are rolling the dice with your rings & bottom end being worn. It also depends on how stiff of a cam you get.
Originally Posted by atlacatl69
man... Canadian... the other Mexican
Threads Similar to: cams in high milage engine
02 MUSTANG GT ENGINE STOPPED AT HIGH SPEED ozbusurfer 99-04 8 September 30th, 2007 12:48 AM
need help on Notch piston for high lift cams Badasstang281 99-04 11 August 17th, 2007 02:39 AM
Quick high rev engine dblindberg 2005+ 1 April 6th, 2007 12:24 PM
FS: PI cams, 5.0 engine, 289 parts, 68 dlxcoupe Engine 0 January 26th, 2007 02:18 PM
Nitrous on high milage 5.0? red01 5.0 Mustangs 4 September 8th, 2006 03:20 PM
