Excessive Heat
Old July 29th, 2007, 03:19 AM   #1
Dallas01GT is on a distinguished road
Excessive Heat
I did a search on here and found part of my answer but I need some advice from you guys on the rest. I have an 03 Cobra and the Shifter under the leather is extremely hot. Also under the floor mat on the drivers side the rubber part on the flloor is hot to touch. Seems the longer I drive the worse it gets, it gets to the point where my feet sweat.
I read that around the cup holder area and shifter might get warm but didn't think this much heat is normal, also the floor board thing is unbearable. I can't drive in the summer like this. Any suggestions?
Old July 29th, 2007, 01:39 PM   #2
TheUNZippee!'s Avatar
Get the car in the air, and check to see if the heat shields under the car are intact and in good shape. On an 03 car, they should be in good shape, but you never know. The exhaust system should have shielding above the pipes/catalytics etc, where ever they get close to the floorpan of the car.
BONER CREW EMPLOYEE - BWAL, CEO
Originally Posted by My Wife
Old July 29th, 2007, 01:42 PM   #3
mustangmanic's Avatar
13.334 @ 106.27 w/2.01 60'
mustangmanic will become famous soon enough
Send a message via AIM to mustangmanic
yeah that has to be the heat shield. do you have aftermarket exhust? Cobras sit a little lower than GT's i believe so everthing is more "tight" to the body of the car, thats why cobra floor pannels get a little warmer. But is your exhaust aftermarket? and if so did someone install it for you. If thats the case, they coulda set it too close to your heatshields or sumthin.
Old July 29th, 2007, 01:44 PM   #4
Word.
Old July 29th, 2007, 01:45 PM   #5
Zoolander
04 Cobra #2260/3768 1/820
iTrader: 5 reviews
If it bugs you this much..I'll be happy to take it off your hands.
I'm pretty sure you can find better heat shields somewhere on the interweb to help with it. You may need to get a new shifter handle to help with the heat of that. I've heard of guys doin that because it just gets too hot for them.
MM Cobra Club #18
Team Tini Racing
I don't know jack shit...
Old July 29th, 2007, 01:46 PM   #6
Inter......web? Is this a new thingy? Me likey!
Chances are there may have been a heat shield that fell off the car or was never replaced after mechanical work. Shouldn't be a tough fix.
Old July 29th, 2007, 02:18 PM   #7
Thanks guys, this gives me an idea of where to start. I just had the Tranny fluid replaced and was worried something happened and the Tranny was getting to hot but the heat shields make more sense. Appreciate it.
Old July 29th, 2007, 02:19 PM   #8
Anytime man. Best of luck with it. LEt us know how it goes.
Old July 29th, 2007, 03:27 PM   #9
is your exhaust aftermarket tho? Because if its stainless steel, it shouldnt get that hot you kno... but if its chrome or sumthin else it gets helle hot... if its not ur heatshield and you have a midpipe thats not stainless then thats most def your problem. My uncle has a fox body and put a chrome H-pipe on and that god sooooo hot, then he switched to stainless steel 409 i believe and it wasnt a problem anymore
Old July 30th, 2007, 12:32 AM   #10
I have full Bassani setup, Catted X and Catbacks, they are not stainless. But thanks for that. I am putting in Long tubes this week so everything is getting swapped out, will ask for stainless to reduce the heat ( yeah cost more but worth it to not have sweaty feet LOL ) and have them check the heat shield. Will post what the out come is.
Old July 30th, 2007, 12:34 AM   #11
the real shocker's Avatar
13.00 @ 105
the real shocker will become famous soon enough
you could look into some heat wrap for your exhaust as well...
Old July 30th, 2007, 12:38 AM   #12
One Man Wolf Pack
06RedfireGT's Avatar
2006 Mustang GT
13ish....maybe
+1 to what everyone else said. in the mean time just put on the floor a/c
ΜΟΛΩΝ ΛΑΒΕ
Old July 30th, 2007, 12:39 AM   #13
or drive nakies
Old July 30th, 2007, 12:41 AM   #14
energiesource's Avatar
energiesource is on a distinguished road
my car does this too
its quite a piss off.
Old July 30th, 2007, 12:43 AM   #15
One Man Wolf Pack
2006 Mustang GT
13ish....maybe
Originally Posted by TheUNZippee!
or drive nakies
or for the non-homosexuals wear sandles
ΜΟΛΩΝ ΛΑΒΕ
Threads Similar to: Excessive Heat
Excessive oil cunsumption in a new motor jpalm 5.0 Mustangs 8 May 17th, 2007 10:43 PM
Heat Plates ThePonyExpress V6 Mustangs 16 February 12th, 2007 12:57 PM
no heat hmotes 5.0 Mustangs 8 January 15th, 2007 04:24 PM
Heat / Air terribleonexx88 5.0 Mustangs 3 October 19th, 2006 12:09 AM
Please help with the heat tdurbin 5.0 Mustangs 12 May 19th, 2006 11:15 AM
