Discussing Underdrive Pulleys in the 99-04 Forum. Just ordered a set of BBK underdrive pulleys for my 04 GT, anything I should ... Modded Mustangs is the premier Ford Mustang Forum on the internet. We discuss all aspects of the Ford Mustang on the forum. Registered Users do not see the above ads. Please Register - It's Free! |
Underdrive Pulleys |
the belt tensioner will take up the slack. when i put mine on, i had to remove the whole alternator from the car to get the pulley off of it just because of the space issue. i hit the nut with an impact and it came right off. the water pump pulley is really easy. i think it's like four bolts. for the crank pulley, put the car in first gear with the e brake set when you try to break free the bolt for the crank pulley. had to borrow a harmonic damper puller from advance auto parts to remove it. overall, it was a pretty simple swap. too about an hour and a half with smoke breaks. oh, and make sure you have a drawing of your belt routing so when you're done you know how to put the belt back on.
![]() Submariners Do It Deeper Military Crew MM1 (SS)Bluenose US Navy Veteran |
great thanks.
Threads Similar to: Underdrive Pulleys
| BBk underdrive pulleys | 03Gtmustang | 99-04 | 6 | September 26th, 2007 03:46 PM |
| when you buy underdrive pulleys | matfernan1 | 99-04 | 21 | September 26th, 2007 01:55 AM |
| Underdrive Pulleys | justinsstang | V6 Mustangs | 6 | February 24th, 2007 04:14 AM |
| Underdrive Pulleys | 97stanger | V6 Mustangs | 26 | February 22nd, 2007 11:29 PM |
| Underdrive Pulleys | jerb43 | 96-98 | 5 | October 24th, 2006 12:05 PM |
