Blown 03 GT
Front drag wheel and tire setup?
What are the benefits to using these at the strip and also could the be use as a temp spare? I was thinkin you could replace the spare wit two drag wheels and tire so they are right there for the track and if u got a flat ud be set. I got one the other night and in upstate new york its impossible to find shop wit the tires i need in stock and im gettin tired of havin to stay under 50mph with the spare while they are ordered. It was a thought and was wonderin what you guys thought of it.
mm's nitrous mod
2000 mustang gt
11.79@115.83 (old set up)
cars benefit from front runners for a few reasons. ligheter, narrower to cut through the air, less rotating mass. you can run a front runner on the street as long as the wheels and tires are dot approved and will handle the weight of the car.
Threads Similar to: Front drag wheel and tire setup?
| Tire Setup | StangAddiction | 5.0 Mustangs | 6 | October 7th, 2007 09:24 PM |
| Best drag setup for 91 notch | cams-shelbycobra07 | General Tech | 7 | August 13th, 2007 10:13 AM |
| Tire pressure for drag radials? | fomocoro | 2005 - 2010 | 21 | May 11th, 2007 07:33 AM |
| Drag Suspension Setup? | 5.0newbee | 5.0 Mustangs | 8 | March 2nd, 2007 12:35 PM |
| Biggest Tire And Rim Setup Possible | 5.0 street stanger | 5.0 Mustangs | 3 | October 15th, 2006 01:50 AM |
